No recent travel & transport from BBC stories as at 14:55 10 Jan 2025
13:30 Bristol Temple Meads to London Paddington
14:37 Didcot Parkway to London Paddington
14:40 Windsor & Eton Central to Slough
14:45 West Ealing to Greenford
15:00 Greenford to West Ealing
15:00 Bristol Temple Meads to London Paddington
15:15 West Ealing to Greenford
15:30 Greenford to West Ealing
13:26 Weston-Super-Mare to London Paddington
13:32 London Paddington to Cheltenham Spa
13:42 Exeter St Davids to London Paddington
13:56 Newbury to London Paddington
14:53 London Paddington to Worcester Foregate Street
11:27 Carmarthen to London Paddington
12:59 Cheltenham Spa to London Paddington
13:15 Plymouth to London Paddington
13:50 London Paddington to Great Malvern
13:50 Cardiff Central to London Paddington
13:55 Paignton to London Paddington
14:00 London Paddington to Bristol Temple Meads
January 10, 2025, 14:56:50 *
[98] Mick Lynch announces retirement as head of RMT
[52] Westminster Hall debate : Railway services to South West
[46] Birthday trip, Melksham to Penzance - 28th January 2025
[25] A Beginner's Guide to the Great Western "Coffee Shop" Passenge...
Author Topic: Constant cancellations!  (Read 11671 times)
gpn01
« on: August 25, 2011, 09:01:37 »
All this week I've received an early morning SMS alert to say that 07.08 Maidenhead to Paddington cancelled due to over running engineering work. No message this morning so thought hurrah! But no. It was cancelled anyway. I have a 1st class season ticket and a perk is the free trolley service and newspaper on 07.08. So I'm unimpressed at this poor service.
« Reply #1 on: August 25, 2011, 09:12:25 »
All to do with the over-run of engioneering works on the Cotswold Line. Should be ok tomorrow.
insider
« Reply #2 on: August 25, 2011, 19:36:57 »
On Monday & Wednesday the 03:57 Swansea to Paddington called at MAI (Maidenhead station) (07:12) vice the 05:02 Worcester SH to Paddington Service.
On Tuesday there were "operational reasons" that the Swansea to Paddington didn't call.
Today (Thursday) the 05:02 was meant to run as scheduled. The decision to remove Maidenhead was due to late running (24 mins late Dep Charlbury) and this was posted to JourneyCheck at 06:40 and a text should have followed??
« Reply #3 on: August 25, 2011, 19:52:04 »
I don't think 'stations removed from stopping pattern' generstes a text. Full cancellations do.
gpn01
« Reply #4 on: August 25, 2011, 23:58:00 »
Whilst stopping the 03:57 from Swansea (isn't that the UK (United Kingdom)'s officially most overcrowded train?) at 07:12 is with good intent it doesn't help when the fact doesn't appear on the noticeboard and so if early enough everyone crams on to the 07:03 (which doesn't have sufficient 1st class seats).  Or, with the expectation that the 07:08 is cancelled you take a few more minutes on the journey and arrive in time for the 07:19 - by which time the 07:12 will have gone.
anthony215
« Reply #5 on: August 26, 2011, 00:14:56 »
I knew that the 03:57 Swansea - London Paddington service was busy but i didnt think it was that overcrowded, i think it is either the service before it  or the 1 after it from Reading which is the uk's most overcrowded, thruth be told these class 180's which are hoped to be coming to FGW (First Great Western) are badly needed heck hopefully if crossrail does come to Reading that might help provide some relief.
Anyway with FGW having some class 319's from around 2016 is it possible to have 3 of these attached together in the peaks forming a 12 carriage train to run between Oxford/Reading  to London Pddington?
Edited to fix quote.
« Last Edit: August 26, 2011, 15:29:02 by inspector_blakey » Logged
« Reply #6 on: August 26, 2011, 07:56:53 »
The 07:03 does not have sufficient standard accommodation for its normal loading let alone space if the 07:08 is canned 1st class being least of the 07:03's problems.
Its quite simple Maidenhead does not have adequate provision at that time of the day, there is unlikely to be any easing until Crossrail metro services start and the GWML (Great Western Main Line) electrification.
« Reply #7 on: August 26, 2011, 08:54:19 »
Amd you'll be lucky to retain any fast trains then! Semi (skip stop maybe) fast maybe...
« Reply #8 on: August 26, 2011, 10:42:36 »
Maybe even lucky to get semis. If Crossrail does stupidly terminate trains at Maidenhead they'll be all stations Shenfield or Abbey Wood
« Reply #9 on: August 26, 2011, 11:09:16 »
But surely if Crossrail terminates at Maidenhead, then the next "flight" of trains out will call there for connection purposes?  So you'll have London to Reading trains express to Maidenhead then all stations to Reading.
« Reply #10 on: August 26, 2011, 11:14:05 »
And the same in treverse - All stations from Reading to Maidenhead in the morning to connect with CrooRail then fast to PAD» (Paddington (London) - next trains).
MOre of a problem for MAI (Maidenhead station) if CrossRail starts back from Reading, methinks
« Reply #11 on: August 26, 2011, 11:18:48 »
I'd advise against falling into the media's 'most overcrowded train in the UK trap' - It's a very dynamic situation and what was hand counted (how accurate will those results be?!) on one day as the busiest train that day, may not be the next.  For example, loadings on the stoppers from Ealing Broadway towards Hayes will swell greatly if a packed District Line train and a couple of Central Line trains have terminated in between trains - often to the extent that plenty are left unable to board.  Now, if a train is so busy that you can't get on then surely it's got to be at least equal to the most overcrowded train of the day?!  This happens day-in, day-out to passengers at Ealing, and, coming the other way, Southall.
Ditto at Reading where if a train is late in the peaks and a fast hasn't left for 10 minutes or so, then huge swathes of people build up and then cram on the first to arrive.  Some wise souls wait for a couple of minutes if one is due behind, but not many.
« Reply #12 on: August 26, 2011, 14:13:23 »
At present the fast and semis can cross at Rushcombe, Maidenhead East, Slough West and Dolphin JN depending on whether there is Slough stop as well.
Crossrail practically take over the Relief Lines from Maidenhead so that anything from Reading has to cross at Rushcombe unless Maidenhead West Crossovers (left handed are reinstated). Also they are expecting freight to be on the Main Lines otherwise why build the flyunder at Acton?
Crossrail won't work West of Padd.
gpn01
« Reply #13 on: August 26, 2011, 23:19:51 »
Quite depressing to see that the Crossrail estimated time calculator (at http://www.crossrail.co.uk/) shows the estimated time from  Maidenhead to Paddington to be 37 minutes.  That's almost double the time taken on the 07:08 (which operated on time today....hurray!) which arrives at Paddington at around 07:28.
hertzsprung
Jr. Member
« Reply #14 on: August 26, 2011, 23:53:31 »
Many of the MAI (Maidenhead station)-PAD» (Paddington (London) - next trains) fast/semi-fast services take more than 40 minutes crawling along being a stopping service.  At the risk of derailing this thread, is there a reason why FGW (First Great Western) couldn't run fewer, longer trains?  Wouldn't this provide the same capacity, but prevent the fast and semi-fast services from getting stuck behind stoppers?
