Travel & transport from BBC stories as at 20:35 28 Apr 2025
28th Apr (1996)
19:13 Salisbury to Bristol Temple Meads
19:29 Gatwick Airport to Reading
19:47 Bristol Temple Meads to Frome
20:58 Frome to Westbury
21:33 Westbury to Salisbury
22:11 Salisbury to Bristol Temple Meads
17:36 London Paddington to Plymouth
19:15 Paignton to Exmouth
19:44 Paignton to Exmouth
20:54 Exmouth to Barnstaple
21:26 Exmouth to Paignton
16:15 Penzance to London Paddington
April 28, 2025, 20:36:12 *
[228] Chiltern Railways: an update on rolling stock / services
[66] Driving licences and tests - ongoing discussion, merged topics
[49] Station Jim’s whereabouts
[46] Thames Valley infrastructure problems causing disruption elsew...
[41] North Cotswold line - driver route knowledge
[32] Stop orders as cover for cancelled services
Author Topic: Heathrow Connect Unit 360 205  (Read 9329 times)
« on: August 15, 2011, 10:59:45 »
Caught this unit form Ealing to Hayes last night on a Connect service.
Only one genuine passenger to LHR plus I think an overcarry who was desparately looking out as it left Hayes.
Was suprised to find it branded in Heathrow Express colours! Minus internal TV (Thames Valley, or TeleVision, depending on context) screens. Whereas 204 still in Connect colours.
Also if it's branded Heathrow Express has it been ATP (Automatic Train Protection) fitted?
« Reply #1 on: August 15, 2011, 14:11:03 »
It's used almost exclusively on the Heathrow Express shuttle service from Terminals 1/2 to Terminal 4, though if there's a shortage of availability on the Connect Class 360's then it can occasionally turn up on one of them.  It's fitted with ATP (Automatic Train Protection), as are the other 4 trains used on the Connect service - ATP is fitted to both main and relief lines as far as Airport Junction.
inspector_blakey
« Reply #2 on: August 15, 2011, 15:15:26 »
They must have to take some serious precauations to stop the driver on the T123 to T4 shuttle going absolutely stir-crazy! Bumbling between Paddington and Heathrow all day would be bad enough, but I can't imagine what it must be like to go back and forth on a journey of a couple of minutes underground for an entire shift. I wonder if they borrowed some rostering patterns from the Waterloo and City drivers on LUL (London Underground Ltd)...
« Reply #3 on: August 15, 2011, 15:24:53 »
There's usually an agreed number of trips that any driver can do on the trip like that....similar to the 2 or 3 round trips Reading / Basingstoke before they (usually) go off on a Gatwick run.
« Reply #4 on: August 15, 2011, 18:10:34 »
Thanks for the info Industry Insider that's one puzzle solved.
Should have realised the 360s would have ATP (Automatic Train Protection) fitted. Didn't realise the Reliefs were fitted to Airport Jnction.
« Reply #5 on: August 15, 2011, 22:22:37 »
Heathrow Connect services PA (Public Address (broadcast loudspeaker announcements) or Passenger Assist (railway staff providing physical assistance to passengers with mobility issues), depending on context) currently announces this station as something like "Heathrow Terminals 1 and 3" or "Heathrow Central for Terminals 1 and 3". Can't remember which one they use but this is because Terminal 2 closed  a year or 2 ago, has been demolished, but will be rebuilt as a larger terminal. Terminal 1 will eventually close. Can't remember if T2 will expand into where T1 is now or if it just takes over the existing T1 piers and stands.
« Reply #6 on: August 16, 2011, 13:25:21 »
Yep, sorry, I meant Terminals 1 & 3.
HexDriver
Jr. Member
« Reply #7 on: August 18, 2011, 23:00:27 »
Maximum amount of trips are blocks of 6 round trips which means that drivers get lots of breaks and as theres two drivers (one at each end) its seen as a good opportunity to read a book or should i say almost essential.
Interestingly 360205 has seats in a 2 2 configuration which gives the impression of having a lot more space compared to the other units
« Reply #8 on: August 19, 2011, 11:32:25 »
Thanks for that, HexDriver - I didn't realise they'd altered the seating as well.  Is there any reason why they chose to convert a Class 360 over using one of their Class 332's?  There's 14 of them, and by all accounts always seems to be a fair few sitting spare in the depot.
HexDriver
Jr. Member
« Reply #9 on: August 22, 2011, 11:38:44 »
At the depot they always have at least one spare should something happen to a hex unit in service while the others are having their various exams done because the units are used a lot more intensively than say fgw units
