Travel & transport from BBC stories as at 23:15 28 Apr 2025
* Shuttered shops and unfinished haircuts - how a day without power unfolded
28th Apr (1996)
22:11 Salisbury to Bristol Temple Meads
22:30 London Paddington to Bristol Temple Meads
17:50 Penzance to London Paddington
April 28, 2025, 23:24:50 *
Author Topic: Hex/Connect Industrial Action 27th & 28th May  (Read 7289 times)
HexDriver
Jr. Member
« on: May 23, 2011, 06:04:10 »
Just to give prior warning to those of you who use the Heathrow Connect service, that due to industrial action taking place on the 27th and 28th May there will be no Heathrow Connect services operating and the Express service will only operate half hourly between 0800 and 2000 both days.
It remains to be seen whether FGW (First Great Western) services will stop additionally at Hanwell and West Ealing.
« Reply #1 on: May 23, 2011, 15:59:10 »
Might be pretty pointless industrial action if this latest volcanic erruption in Iceland closes air space over the UK (United Kingdom) again.
« Reply #2 on: May 27, 2011, 13:34:11 »
Most, if not all of them, apparently!  Grin
From FGW live updates:
11:37 Oxford to London Paddington due 13:31
This train has been revised.It will call additionally at: Hanwell.
Last Updated: 27/05/2011 12:04
12:07 Oxford to London Paddington due 14:01
12:37 Oxford to London Paddington due 14:31
12:42 London Paddington to Reading due 13:45
Last Updated: 27/05/2011 12:08
13:07 Oxford to London Paddington due 15:01
Last Updated: 27/05/2011 12:05
13:12 London Paddington to Reading due 14:17
13:37 Oxford to London Paddington due 15:32
13:42 London Paddington to Reading due 14:45
Last Updated: 27/05/2011 12:09
14:07 Oxford to London Paddington due 16:02
14:12 London Paddington to Reading due 15:13
14:37 Oxford to London Paddington due 16:31
Last Updated: 27/05/2011 12:06
14:42 London Paddington to Reading due 15:44
15:12 London Paddington to Reading due 16:13
Last Updated: 27/05/2011 12:11
20:37 Oxford to London Paddington due 22:32
This train has been revised.It will call additionally at: Southall, Hanwell and West Ealing.
Last Updated: 27/05/2011 12:07
20:42 London Paddington to Reading due 21:45
20:48 Reading to London Paddington due 21:48
This train has been revised.It will call additionally at: Southall and Hanwell.
21:12 London Paddington to Reading due 22:13
Last Updated: 27/05/2011 12:12
21:42 London Paddington to Reading due 22:46
22:10 London Paddington to Reading due 23:14
This train has been revised.It will call additionally at: West Ealing and Hanwell.
22:46 Reading to London Paddington due 00:03
This train has been revised.It will call additionally at: Hanwell and West Ealing.
johoare
« Reply #3 on: May 27, 2011, 14:46:41 »
I was hopeful, because of this, that for once we'd not have to slow down for airport junction this morning.. I was wrong... Roll Eyes Roll Eyes
« Reply #4 on: May 27, 2011, 14:54:08 »
The lack of useful info regarding Hanwell for example, on both FGW (First Great Western) & HConn websites is pretty bad. Next to nothing.
Hope posters are up at affected stations.
« Reply #5 on: May 27, 2011, 15:35:38 »
I've a feeling the Airport Junction problem on the Up Main is an endemic one. The ARS (Automatic Route Setting) in the IECC (Integrated Electronic Control Centre) doesn't seem to pick up a train on the Up Main far enough back down the line for the computer to crank up see if there's a Heathrow about and then decide it should perhaps clear the the Up Main and let it run. Hence the double yellow at West Drayton.
From Rushcombe to West Drayton the train has been under Slough (Old) and they let the signals run auto, if there are no crossing moves to fit in.
« Reply #6 on: May 27, 2011, 15:49:24 »
I assume that this is just the sort of problem the ERTMS (European Rail Traffic Management System. A future railway signalling system, with equipment located in the driver's cab, rather than lineside) upgrade would help with.
« Reply #7 on: May 27, 2011, 16:34:54 »
Any re-signaling would help if it moved the control boundary further West, the current one is the old Old Oak Common / Slough boundary, although there will always be the rules on conflicting movements and train headway (I'm not an S & T engineer and I am sure its more complex than tis)
« Reply #8 on: May 28, 2011, 09:20:15 »
From good source, as I understand it the ARS (Automatic Route Setting) picks up a train on the Up main at Langley which is around 3 mies from the infamous permanent double yellow at West Drayton that gives it 90 seconds for it to respond and set the route. Don't forget the signal at West Drayton has to be green otherwise an HST (High Speed Train (Inter City class 43 125 units)) will be slowed by the ATP (Automatic Train Protection) until the next signal releases the ATP. Not sure if signal has fixed ATP or a wire in front. A Turbo driver of course is not locked down so start to acerate as soon as they see the next signal if it's showing green.
