No recent travel & transport from BBC stories as at 22:55 04 Apr 2025
16/04/25 - Walk from Chetnole
4th Apr (1966)
Release of Great St Trinians Train Robbery (*)
22:03 London Paddington to Bristol Temple Meads
22:10 Severn Beach to Bristol Temple Meads
22:20 Paignton to Exeter St Davids
22:24 Bristol Temple Meads to Severn Beach
22:40 Severn Beach to Bristol Temple Meads
23:06 Bristol Temple Meads to Westbury
23:08 Severn Beach to Bristol Temple Meads
20:50 Bristol Temple Meads to Weymouth
21:21 Bristol Parkway to Portsmouth & Southsea
20:23 Swansea to London Paddington
21:53 London Paddington to Worcester Shrub Hill
22:51 London Paddington to Worcestershire Parkway
An additional train service has been planned to operate as shown 23:11 Westbury to Frome
April 04, 2025, 22:57:12 *
[102] Gordon Pettitt 12/04/34 - 31/03/25
[74] 185 years of Reading Station
[66] Daily Mile - coming to Melksham for April
[56] Where was Red Squirrel 25/3/2025
[47] [OTD] Senior Railcard launched 1st April 1975
[46] Changes to the Highway Code
Pages: 1 ... 12 13 [14] 15 16 ... 114
Author Topic: Crossrail/Elizabeth Line. From construction to operation - ongoing discussion  (Read 687794 times)
« Reply #195 on: March 13, 2012, 18:00:26 »
What are these PR (Public Relations) people like?
They are saying the boring machines were 'revealed' today.
So they must have been hidden before?   Roll Eyes
They were 'unveiled' in an earlier press release in December - I guess they have to use every buzzword in the spinmaster's dictionary...
« Last Edit: March 13, 2012, 18:07:49 by paul7755 » Logged
« Reply #196 on: March 13, 2012, 19:45:27 »
Well, they need a bit of spin: those boring machines don't just pop up out of the ground, you know ...  Tongue Roll Eyes Grin
anthony215
« Reply #197 on: March 16, 2012, 22:09:36 »
I have read on WNXX (Stored Unserviceable, Mainline Locos HQ All Classes) that there has been some problems trying to fit the TBM's  under the steel framework  which is errected over the portal at the royal oak end.
« Reply #198 on: March 17, 2012, 07:12:52 »
I did notice the first TBM had gone so far and it is taller than one of the frames ................. ooooooooooops  Grin ............ but they are continuing with the fit out
« Reply #199 on: April 03, 2012, 11:43:27 »
An article on the Crossrail project which is well worth a read:
http://www.theengineer.co.uk/in-depth/the-big-story/what-lies-beneath-excavating-crossrails-tunnels/1012220.article#comments
Meanwhile a nice shiny 10-car length platform extension is nearing completion on the Down Main platform at Hayes & Harlington.  Not sure why that was chosen first, but with the exception of a bridge demolition near Iver it's the first sign of visible works on the GWML (Great Western Main Line) route.
« Reply #200 on: April 04, 2012, 10:53:48 »
Though the revised Airport Junction is hot on its heels.  You can see initial work on the retaining wall if you look left just as you pass under the flyover as you head away from London.
http://www.networkrailmediacentre.co.uk/Press-Releases/NETWORK-RAIL-STARTS-WORK-FOR-HEATHROW-CROSSRAIL-SERVICES-1a41/SearchCategoryID-8.aspx
Boppy
« Reply #201 on: April 04, 2012, 13:21:33 »
Having read the description of how this junction is to be changed I'm still having trouble picturing the new viaducts and track layout.  Is there a diagram of how it will finally look anywhere?
Thanks,
Boppy.
« Reply #202 on: April 04, 2012, 13:27:49 »
This diagram, originally posted by Paul, shows the likely new layout.  It's certainly going to look quite different!
http://www.rail-reg.gov.uk/upload/pdf/s18-xrail-appx2_single_line_GW.pdf
« Reply #203 on: May 04, 2012, 23:02:48 »
Phyllis has started her work:
http://www.crossrail.co.uk/news/press-releases/crossrails-first-tunnel-boring-machine-breaks-ground-at-royal-oak#.T6RRLcVG3YQ
The spoil conveyor system and loading sidings are also nearing completion, so it won't be long before the first spoil train leaves from Westbourne Park.
Oxman
« Reply #204 on: May 05, 2012, 00:20:33 »
I was struck by how pristine it all looks. Won't last, of course!
Boppy
« Reply #205 on: May 08, 2012, 12:22:59 »
Thanks IndustryInsider for pointing me towards Paul's diagram post.
I can now imagine how it will look and yes it does indeed appear quite a bit of work will be done to enable that Up Airport line as well.
Thanks,
Boppy.
« Reply #206 on: May 08, 2012, 18:43:37 »
Also thanks for Paul's post. One little addition that I've always thought would increase operational flexibility would be to put a connection from the bay platform 5 at Hayes to the Hayes Goods loop there appears to be room over the canal bridge. It is only a short length and would need a short lenth of wire as well. It would mean a Down train  for the bay would cross at Southall West onto the goods loop and run to the bay and not run wrong line blocking the Up Relief as now. At the same time an Up train could leave the bay and depart Up Relief passing the incoming train which will already be on the goods loop.
Thus clearing the down relief at Southall West and only blocking the Up Releif for a crossing move rather than a wrong line run.
I reckon it would require  4 of these new signal units, two point motors and 2 new route indications on existing signals.
« Reply #207 on: May 09, 2012, 11:58:33 »
That would indeed be a more sensible layout, though that goods loop can often be occupied for several hours by stone trains going into, or waiting to leave, the Hayes Tarmac unloading siding.  It also acts as a run-round loop for other freight services.
« Reply #208 on: May 10, 2012, 22:17:14 »
It's an unfortunate accident of the English language that these very interesting machines are called "boring machines". After all these years, dirt is now being dug! I look forward to getting on the train at Stapleton Road, and asking for "Tottenham Court Road, please".
Btline
« Reply #209 on: May 10, 2012, 23:56:34 »
I doubt they'll be direct trains from Bristol.
Besides you'll just ask for London Terminals won't you? (or London Zone 1)
