Travel & transport from BBC stories as at 08:35 13 May 2025
* US cuts tariffs on small parcels from Chinese firms like Shein and Temu
 today - Melksham TUG / AGM
tomorrow - West Wiltshire RUG
17/05/25 - Summer Timetable Starts
18/05/25 - Portishead RNLI 10 anniversary
13th May (1985)
Melksham Station reopened (link)
08:38 Marlow to Bourne End
08:48 Bourne End to Marlow
08:58 Marlow to Maidenhead
16:21 Bourne End to Marlow
16:52 Bourne End to Marlow
17:29 Bourne End to Marlow
09:32 Maidenhead to Marlow
10:00 Marlow to Maidenhead
10:33 Maidenhead to Marlow
10:59 Marlow to Maidenhead
11:33 Maidenhead to Marlow
11:59 Marlow to Maidenhead
12:34 Maidenhead to Marlow
13:00 Marlow to Maidenhead
13:33 Maidenhead to Marlow
13:59 Marlow to Maidenhead
14:33 Maidenhead to Marlow
15:38 Maidenhead to Marlow
May 13, 2025, 08:39:13 *
[93] Go-Op Cooperative - proposals for additional rail services
[49] Champion Reflections
[38] [otd] 13th May (1985) - Melksham Station re-opened
[33] trainee drivers will be allowed to drive trains from age 18
[18] Shortage of train crews on Great Western Railway - ongoing dis...
[11] Day trip to Chetnole - and a walk to Maiden Newton - report an...
Author Topic: FOSW and the Night Rivera  (Read 5287 times)
159jim
« on: December 15, 2010, 21:49:53 »
Hi!
I'm getting a 8-In-15 day FOSW (Freedom of (the) South West Rover) rover, and could I use this ticket on the Night Riveara?
Thanks,
Jim.
« Reply #1 on: December 15, 2010, 22:21:21 »
You can, of course, use the FOSW (Freedom of (the) South West Rover) Rover on its own in this area:
http://www.nationalrail.co.uk/managed/promotions/pra7ebd70a04000400ab63191d753a5b/areaMap/Freedom_of_South_West.pdf
So absolutely fine to use it on the Night Riviera between Penzance and Taunton (seated - Sundays excepted*) or vice versa.
However, should you wish to use the Sleeper beyond Taunton, you can use your Rover in combination with a walk-up ticket to/from Taunton** (if the Night Riviera is on its usual route). You still need to pay extra if you want a berth.
*The Sunday Sleeper doesn't call at Taunton, so you can only use your FOSW Rover from the south-west as far as Exeter St Davids.
**It's also potentially possible to use a FOSW Rover in combination with a ticket to/from Westbury, but this option is a bit of a grey area. Using a FOSW Rover in combination with a walk-up fare to/from Westbury is possibly allowed under the terms of the National Rail Conditions of Carriage (para. 19 part (c)). The Night Riviera doesn't call at Westbury but the combination of a 'Leisure Travel Pass' (which is what the FOSW is) plus a walk up ticket precludes the need for the service you are on needing to call at the point where your tickets split. Whether the Westbury avoiding line fulfils this criteria is open to debate.
« Last Edit: December 15, 2010, 22:37:58 by bignosemac » Logged
« Reply #2 on: December 16, 2010, 11:34:02 »
Bear in mind the 9am restrictions on the FOSW (Freedom of (the) South West Rover) rendering it useless unless you are on the up/down Friday workings
« Reply #3 on: December 16, 2010, 12:07:32 »
It would be valid any day on the Up Sleeper as far as Taunton though. And beyond in combination with a TAU» (Taunton - next trains)-RDG (Rail Delivery Group, or Reading station, depending on context)/PAD» (Paddington (London) - next trains) ticket.
« Reply #4 on: December 16, 2010, 12:32:21 »
Well yes, however if merely using the fosw rover you are stranded in Taunton till 9am
« Reply #5 on: December 16, 2010, 15:08:50 »
**It's also potentially possible to use a FOSW (Freedom of (the) South West Rover) Rover in combination with a ticket to/from Westbury, but this option is a bit of a grey area. Using a FOSW Rover in combination with a walk-up fare to/from Westbury is possibly allowed under the terms of the National Rail Conditions of Carriage (para. 19 part (c)). The Night Riviera doesn't call at Westbury but the combination of a 'Leisure Travel Pass' (which is what the FOSW is) plus a walk up ticket precludes the need for the service you are on needing to call at the point where your tickets split. Whether the Westbury avoiding line fulfils this criteria is open to debate.
Presumably - without debate - you could split in this way at Bruton.   What happens with the split if the service runs via Yeovil Junction or via Temple Meads on the night in question?
« Reply #6 on: December 16, 2010, 15:13:15 »
You are invalid!
« Reply #7 on: December 16, 2010, 15:53:55 »
So best be sure of its route before deciding where to split!!
« Reply #8 on: December 16, 2010, 17:22:06 »
You are invalid!
Do we know for sure that that is the case.  you could still be taking the same "route"  as shown for example in the rooting guide (which doesn't show avioding lines) despite actually running over different bits of track.
