« Reply #105 on: September 11, 2016, 17:05:03 » |
Journey planners are showing Wales bound trains calling at Pilning on the 22nd and 29th October (the two Saturdays after the Severn Tunnel blockade) and the poster at the station - shown above - shows changes from 5th November. So are there two more trains?
Yes. Bridge removal not happening during the blockade. Your post includes the "From 5th November" poster that's up at Pilning. I didn't wonder "why" at the time, but it was recently confirmed that there are the trains calling towards Wales for a couple more Saturdays after the blockade.
« Last Edit: September 11, 2016, 18:13:16 by grahame »
« Reply #107 on: September 15, 2016, 07:07:48 » |
Many thanks for those links and pictures. As an update (or is that downdate?) removal of the footbridge has slipped back a few weeks in Network Rail's schedule, and the final train towards Cardiff probably calls on 29th October. See http://www.realtimetrains.co.uk/train/C47762/2016/10/29/advanced . This is inline with Bobm's post earlier in this thread (sat month) which tells of alternative arrangements from 5th November.
« Last Edit: September 15, 2016, 08:47:35 by grahame »
Kempis
« Reply #108 on: September 15, 2016, 22:24:45 » |
As an update (or is that downdate?) removal of the footbridge has slipped back a few weeks in Network Rail's schedule, and the final train towards Cardiff probably calls on 29th October. See http://www.realtimetrains.co.uk/train/C47762/2016/10/29/advanced . This is inline with Bobm's post earlier in this thread (sat month) which tells of alternative arrangements from 5th November. Thanks, grahame. I think that's a change in plan -- when I was at Pilning, I saw one poster showing the new arrangements from 5 November, as shown earlier in the thread, and another poster showing replacement bus services in the interim. Anyway, just as well the event was called NotTheLastTrain! The local people did well to decorate the platform with English and Welsh flags, I thought.
The Tall Controller
« Reply #109 on: September 15, 2016, 23:19:47 » |
It was a change it plan, but this was made around a month ago.
The other poster you saw is dated up to the end of the Severn Tunnel works (21 October) so its validity doesn't cover whatever is beyond it.
Kempis
« Reply #110 on: October 29, 2016, 10:37:29 » |
So the actual last train to call at the northbound platform at Pilning is scheduled for today, leaving Temple Meads at 15.21 and arriving at Pilning at 15.40, with removal of the footbridge perhaps commencing later this weekend. We won't be there, but would be interested to hear any reports.
Noggin
« Reply #112 on: November 03, 2016, 11:19:37 » |
Of course if you lift it, you have to provide new steps, so you are probably classed as new construction which has to meet modern regs and accessibility requirements.
Note also that the new safety rules relating to electrification also require parapets to be higher to keep people away from wires, so the bridge would probably require modification anyway.
« Reply #113 on: November 03, 2016, 12:06:45 » |
Now that the down platform is closed, how are GWR▸ complying with their Service Level Commitment? That requires one call in each direction on Saturdays.
Have the got the necessary derogation to ignore the SLC▸ , or has it been amended?
« Reply #114 on: November 03, 2016, 12:15:48 » |
Maybe they will continue to call but for pick-up only!
« Reply #115 on: November 03, 2016, 12:23:25 » |
Or institute a bus replacement? That would count
« Reply #116 on: November 03, 2016, 12:41:17 » |
There are two Up trains now calling on Saturday; so would they say, if pressed, that you "just" need to change (at BRI» or STJ▸ , presumably)? The timings kind of work in some cases, but not for all four directions.
Kempis
« Reply #117 on: November 03, 2016, 22:00:41 » |
Of course if you lift it, you have to provide new steps, so you are probably classed as new construction which has to meet modern regs and accessibility requirements. Perhaps -- though at Stapleton Road, where the footbridge also had to be raised to allow clearance for electrification, a new footbridge without ramps was installed. However, there is currently level access to both platforms there; I'm not sure how access will be provided to what will become the island platform after the four tracking. Note also that the new safety rules relating to electrification also require parapets to be higher to keep people away from wires, so the bridge would probably require modification anyway. Yes -- such parapets have recently been installed on the bridge carrying the railway path (on the old Midland line) over the railway near Lawrence Hill. Now that the down platform is closed, how are GWR▸ complying with their Service Level Commitment? That requires one call in each direction on Saturdays.
Have the got the necessary derogation to ignore the SLC▸ , or has it been amended? As stuving has said, passengers have been advised to travel via Severn Tunnel Junction. There doesn't appear to be a formal easement in place, but I understand tickets to Pilning will be accepted without the need to pay an extra fare. For the outward journey, one can still depart Pilning at 08.32 and arrive at Temple Meads at 08.53 as before. For the return journey: - Previously, one could depart Temple Meads at 15.21 and arrive at Pilning at 15.40.
- Now, one must depart Temple Meads at 12.21, change at Severn Tunnel Junction (arrive at 12.48 and depart at 13.25) and arrive at Pilning at 13.34 (an extra Pilning stop in the Bristol-bound direction has been provided on this train).
So a return journey is still possible, but with a double-back at STJ▸ and a much shorter time in Bristol (or for journeys elsewhere). I don't know whether that is enough to ensure compliance with the SLC.
« Reply #118 on: November 03, 2016, 23:52:21 » |
Any questions to GWR▸ on the SLC▸ will probably be countered with ticket sale information.
I suspect they'd state that no one was making the return journey. With just 68 recorded journeys last year...
I'd just hope that the proper legal derogation of thr SLC has been obtained. Pilning may be a special case, but if a TOC▸ is allowed to vary SLC arbitrarily, this case could be the thin end of the wedge.
« Reply #119 on: November 03, 2016, 23:57:55 » |
Not really a case of GWR being allowed to vary SLC. Rather GWR being effectively forced to.
