No recent travel & transport from BBC stories as at 07:15 10 Jan 2025
10th Jan (1863)
06:19 Par to Plymouth
06:51 Reading to Redhill
07:20 London Paddington to Oxford
08:36 Redhill to Reading
09:00 Oxford to London Paddington
06:57 Cardiff Central to Bristol Temple Meads
06:58 Penzance to St Ives
07:17 Didcot Parkway to London Paddington
08:34 London Paddington to Didcot Parkway
January 10, 2025, 07:22:08 *
[94] Thumpers for Dummies
[71] Railcard Prices going up
[58] Thames Valley infrastructure problems causing disruption elsew...
[50] Outstanding server / web site issues
Author Topic: Signalling in Cornwall  (Read 3392 times)
Zoe
« on: July 14, 2009, 18:41:42 »
Hi, I'm a little confused as to how things work.  Penzance to St Erth, St Erth to Roskear and Roskear to Truro are under absolute block so trains would simply be handed off using bell codes.  East of Truro things get a little more complicated to as the handoff to Par is to a TCB (Track Circuit Block) section.  I have read that in the up direction Truro has to request to Par to send the trains but on the down trains are sent automatically.  How is this done?  Does this also apply to the Par/Lostwithiel handoff?  How are trains handed from Lostwithiel to Liskeard (both under TCB) and finally how does Liskeard link to Plymouth PSB (Power Signal Box)?  Sorry if I'm getting a bit technical here and thanks to anyone that can help with this.
« Reply #1 on: July 15, 2009, 10:44:59 »
In AB as you say the signalmen communiate by bell codes and the box in advance (the one to which the train is proceeding) will unlock the section starter signal by giving Line Clear on the block instrument. The train can then proceed.
Where TCB (Track Circuit Block) is in use the signals are locked by the track circuits in advance. So that the signalman in the rear can pull off as soon as the relavent track circuits are clear and the train can proceed. The signalman in the rear will let the signalman in advance know the train is coming by usually by some form of Train Describer.
Depending on age and type of train describers if a box works TCB both ways on the same line the train description can be passed automatically between boxes or the signalman has to pass it on manually.
In both cases the safety of the train is maintained because the section starter can't be pulled until either Line Clear has been obtained form the box in advance under AB or the relevant track circuits are clear under TCB.
Boundaries between different types of signalling even in TCB areas can be problematic getting the interfaces right between different ages and types of equiment can be tricky and be subject ot failure. As it fails safe there is no danger to the trains but a failure  can cause delays. The Slough Old (Panel) to Slough New (IECC (Integrated Electronic Control Centre)) interface has cause caused problems in the past particularly on the Up Main.
Exactly how Par and Truro work I'll leave to the locals.
winterbourne
« Reply #2 on: July 15, 2009, 16:03:21 »
Penzance through to Lostwithiel pass trains using the absolute block system. There are pockets of TCB (Track Circuit Block), and IB sections but the "sections" are absolute block. Lostwithiel to beyond uses TCB. Lostwithiel & Liskeard use traditional block bells to describe trains, and then Liskeard starts the Train Describer to Plymouth & yonder.
Par & Truro is complicated as there is no requirement on the Up for Par to see the tail lamp, as there is an axle counter section. This could have been adapted to TCB years ago, but remained AB for some reason.
Hope this helps. Contact me off forum if you need to.
Best wishes
