Travel & transport from BBC stories as at 18:35 04 Apr 2025
- Popcorn, chemicals and aircraft - the British winners and losers
16/04/25 - Walk from Chetnole
4th Apr (1966)
Release of Great St Trinians Train Robbery (*)
17:28 Weston-Super-Mare to London Paddington
18:20 London Paddington to Didcot Parkway
18:51 Filton Abbey Wood to Bristol Temple Meads
19:08 Bristol Temple Meads to Gloucester
19:24 Reading to Gatwick Airport
19:54 Reading to Gatwick Airport
20:10 Gloucester to Bristol Temple Meads
17:29 Bristol Temple Meads to London Paddington
17:38 Bristol Temple Meads to Worcester Foregate Street
18:04 Didcot Parkway to London Paddington
19:51 Worcester Foregate Street to Bristol Temple Meads
April 04, 2025, 18:49:31 *
[109] Gordon Pettitt 12/04/34 - 31/03/25
[79] 185 years of Reading Station
[70] Daily Mile - coming to Melksham for April
[51] [OTD] Senior Railcard launched 1st April 1975
[49] Changes to the Highway Code
[41] Fratton to Bristol Temple Meads
Author Topic: Where was JayMac today, 30th October 2024?  (Read 4910 times)
« on: October 30, 2024, 20:21:30 »
I don't think this is too difficult to guess, even with the panel blanked out.
PrestburyRoad
« Reply #1 on: October 30, 2024, 20:38:24 »
I don't know the answer, but the box looks too immaculate to be an operational one on network Rail, so I think it's on a preserved line.  I do know that the GWSR was in use today because I saw an engine in steam at Cheltenham Racecourse station, so I'll guess Toddington or maybe Winchcombe on GWSR.
« Reply #2 on: October 30, 2024, 20:43:18 »
Sorry, not a box on the GWSR.
You are right about this box being immaculate. Very friendly Bobby too.
« Reply #3 on: October 30, 2024, 21:19:44 »
Blue Anchor signal box, West Somerset Railway?
« Reply #4 on: October 30, 2024, 21:42:43 »
Not Blue Anchor, sorry.
Merthyr Imp
« Reply #5 on: October 30, 2024, 22:02:05 »
Ingrow?
« Reply #6 on: October 30, 2024, 22:20:26 »
Williton signal box
« Reply #7 on: October 30, 2024, 23:44:55 »
Yep Williton. Asked if I could pop up to the box after trains were out of section and bobby had completed his duties. He had 90 minutes before next train. I have been in this box before but can't find the photos. When I was here previously there were fewer levers in use. Today there are 24, with 23 in use. Two further levers to the side for crossing gates interlock.
I did a drone flight here filming two trains passing. All the staff were friendly and genuinely interested in the drone footage. No concerns about what I was going to do after I explained my flight plan, competence and insurance. Whenever possible, as a courtesy, I'll inform anyone who may have concerns about a drone.
Later, at another location I didn't have such a friendly interaction. I've detailed that in my 'Stations from the air' thread available to established forum members.
Witham Bobby
« Reply #8 on: October 31, 2024, 10:24:12 »
It's been a hot minute since I was there, too.  Probably 10 years.  And before that (gulp) the best part of fifty years ago now, when I could often be found here
I'm so pleased to see the place well looked after and the developments such as EKT working and an illuminated diagram
« Reply #9 on: October 31, 2024, 11:27:07 »
Maybe our Witham Bobby can answer but what does lever 1 unlock/release?
« Reply #10 on: October 31, 2024, 11:43:42 »
Witham Bobby
« Reply #11 on: October 31, 2024, 13:11:07 »
Well, it used to be the Up Distant Signal on the end of that one.  The GW» (Great Western - used as an abbreviation for the area / lines under the Great Western franchise, as opposed to FGW which includes "First", the company operating them too. For tickets - about) usually used "fixed distant" signals at passing places on single lines.  As in fixed at "caution" in order to remind drivers of the speed restriction entering the loop.  This would perhaps be 15 or 20mph.  When the Minehead Branch was upgraded in the 1930s, the pointwork at each end of the loops was laid-out for 40mph running, and automatic token exchange apparatus was installed.  So fast trains could rocket past places like Williton and Blue Anchor without having to loose much speed and time.  So, workable distant signals were installed.  If the section ahead was clear, and the token had been obtained, the signalman could load up the auto exchanger with the token and clear the signals, including the distant, and later watch the train clatter past.
When we came to re-open the line, we took the decision (encouraged by the Railways Inspectorate) to use only fixed distant signals.  With a 25mph line speed limit (or 40mph for DMUs (Diesel Multiple Unit)) there would be no time saving by having these signals workable
Now, as the picture shows, the lever is a release, for the ground frame that gives access off the Down Loop into the yard.  The shunter needing to make a move into or out of the yard will call-up the bobby and ask for a release, which enables the ground frame to be used at the location, to shift the points.  Once the release lever in the 'box is reversed, all the levers for the running signals that could lead to conflicting moves will be locked normal, so that the signals can't be cleared.
I don't know the exact setup at Williton for this, but it's usual for the signaller reversing the release lever resulting in a key in normally locked an instrument at the ground frame to becoming released.  The key can then be inserted in a lock on the ground frame to enable its levers to be operated.  When the shunting operations are complete and the running line is again clear, and the levers in the ground frame have been set back to their usual positions, the key can be removed from the lock and put back into the instrument, the signaller advised, following which the release lever in the 'box can be restored to normal, and the running signal levers are then freed to be operated.
You'll note that the top of the lever has been cut off.  The lever is in effect a switch, needing not much effort to work.  You wouldn't want to put your weight behind it and give a big swing.  The shortness of the lever is a reminder.  Helpful in not ending up on your a*se
« Reply #12 on: October 31, 2024, 19:58:15 »
Thanks WB!
Deleted another question when I realised I had access to the S-R-S diagram for the box when the distant signals were worked. A lot more red levers in JM's photo than in BR (British Rail(ways)) days!
Many thanks, Oxonhutch (heritage railway signalman).
« Last Edit: November 01, 2024, 08:21:39 by Oxonhutch » Logged
« Reply #13 on: October 31, 2024, 23:06:34 »
The signallar explained to me that many of the semaphores are motor operated now, after the signalling was upgraded. Same for the points. The furthest mechanical 'pull' from that box is 667yds to signal 20. Can't quite read the lever in my photo. I think 20 is the Down Main Distant Starter.
« Last Edit: November 01, 2024, 00:34:44 by JayMac » Logged
Worcester_Passenger
« Reply #14 on: November 01, 2024, 08:20:28 »
Why are there so many instruments and bells on the shelf?
