No recent travel & transport from BBC stories as at 16:15 10 Jan 2025
 14/01/25 - Rail Sale starts
10th Jan (1863)
13:50 London Paddington to Great Malvern
14:54 Cardiff Central to London Paddington
15:00 Bristol Temple Meads to London Paddington
16:00 Henley-On-Thames to Twyford
16:32 Great Malvern to London Paddington
16:59 Cheltenham Spa to London Paddington
13:42 Exeter St Davids to London Paddington
14:53 London Paddington to Worcester Foregate Street
15:14 Exeter Central to Barnstaple
13:15 Plymouth to London Paddington
13:55 Paignton to London Paddington
15:30 Bristol Temple Meads to London Paddington
15:59 Cheltenham Spa to London Paddington
16:31 Barnstaple to Exeter St Davids
17:15 Exeter Central to Barnstaple
January 10, 2025, 16:23:20 *
[98] Mick Lynch announces retirement as head of RMT
[52] Westminster Hall debate : Railway services to South West
[46] Birthday trip, Melksham to Penzance - 28th January 2025
[25] A Beginner's Guide to the Great Western "Coffee Shop" Passenge...
Author Topic: Plymouth to Totnes signalling delays again  (Read 3593 times)
GBM
« on: May 24, 2023, 06:32:51 »
Travelled to Exeter (Okehampton and Barrnstable) yesteday.
Noticed the early trains via and off Plymouth to Newton were delayed by up to 30 minutes with signalling problems, but only on the up line.
Down trains unaffected.
Our train was only 6 late luckily.
Todays early delays up to 30 minutes.
Is the signalling system on the up not liking the early sun!
(Not sure where to post, so mods please move as appropriate)
GBM
« Reply #1 on: May 24, 2023, 06:38:08 »
Now updated on journeycheck
Delays to services between Plymouth and Totnes
Due to a fault with the signalling system between Plymouth and Totnes trains have to run at reduced speed on the line towards Totnes.
Train services running through these stations may be delayed by up to 30 minutes. Disruption is expected until 09:00 24/05.
GBM
« Reply #2 on: May 24, 2023, 07:25:21 »
Now pushed back to 11am
Train services running through these stations may be delayed by up to 30 minutes. Disruption is expected until 11:00 24/05.
Also knock on delayed up train from Plymouth will be late leaving Paddington for Newquay.
GBM
« Reply #3 on: May 24, 2023, 08:32:16 »
Train services running through these stations may be delayed by up to 30 minutes. Disruption is expected until 14:00 24/05.
« Reply #4 on: May 24, 2023, 09:22:07 »
The issue is with Exeter Panel's first up signal E1.  Trains are having to be talked past it at danger.  However it means a train has to pass Totnes Station before the following one can be released from UM230 at Aish.  The delays are occuring because there are eight miles between the two signals.   As you can see a queue quickly develops.
Map from Open Time Trains
