Travel & transport from BBC stories as at 01:35 02 Apr 2025
- Police shoot man dead at railway station
- Virginia Giuffre grateful for 'love and support' after car crash
16/04/25 - Walk from Chetnole
No 'On This Day' events reported for 2nd Apr
02/04/25 04:45 Redhill to Gatwick Airport
02/04/25 05:11 Gatwick Airport to Reading
20:22 Reading to Shalford
21:30 Shalford to Reading
01/04/25 23:45 London Paddington to Penzance
April 02, 2025, 01:50:30 *
[184] On this day. South Australia's triple decker train experiment.
[69] Extreme Day Trips
[44] Press release from Pilning
[26] Easyjet (re)opens Southend Airport operation
[26] Spare parts issue stops trains
[18] It's not the train that's the problem...
Author Topic: question about Landore viaduct at Swansea  (Read 3935 times)
infoman
« on: March 20, 2023, 12:29:14 »
I have a date of 1978-1979 when most, if not all, the metal work was replaced although the supports are orginal.
Any further info would be much appreciated.
Phantom
« Reply #1 on: March 20, 2023, 12:56:57 »
Not sure if you have seen these John?
https://en.wikipedia.org/wiki/Landore_Viaduct
https://www.visitswanseabay.com/swansea-bay-at-home/doorstep-detectives/landore-viaduct/
« Reply #2 on: March 20, 2023, 13:20:10 »
What sort of thing do you want to know? I can find a couple of newspaper pieces from 1978, though 1979 is off the end of the archive!
Work started on June 12th 1978 on the westbound track at the Neath end, and was due to end at the other end in December, though the river bridge span was retained. All the wrought iron plate girders in the approach spans were replaced with modern steel, each span temporarily replaced by a "helper" for the half still in use.
The eastbound half was due to take from December until April 1979. Note that this was not a case of two separate structures, but the strength was in the girders underneath and half were swapped at a time. You can see now that there are rivetted plates joining the spans together in the middle, so presumably these were put in in situ.
The result was that the weight limit (RA) was increased, and the speed restriction went up from 20 to 40 mph.
infoman
« Reply #3 on: March 20, 2023, 18:02:33 »
Thank you both for your replys,
was the line shut into Swansea for the twelve months or was it done shutting one side and then the other or was bus replacement in operation?
« Reply #4 on: March 20, 2023, 18:58:57 »
One side at a time, leaving a single line in use, but closed Sunday mornings (23:30-11:30) for the actual swapping over of the spans and supports. Most of the construction work was done with one line open. Some trains were, apparently, diverted and buses would run to Neath/Port Talbot. The main contractors were Redpath, Dorman, Long (Contracting) Limited and Adamson-Butterley Limited.
I'm guessing that the diverted trains would be ones that reversed in Swansea and went on via Llanelli, and were instead sent along the Briton Ferry line missing SWA» (Swansea - next trains).
