Travel & transport from BBC stories as at 08:35 29 Apr 2025
29th Apr (1963)
Bristol Bus Boycott announced (*)
08:06 Bristol Temple Meads to Gloucester
08:23 London Paddington to Oxford
08:25 Reading to Gatwick Airport
08:45 Truro to Falmouth Docks
09:09 Gloucester to Weymouth
09:15 Falmouth Docks to Truro
09:30 Gatwick Airport to Reading
09:59 Gatwick Airport to Reading
05:23 London Paddington to Swansea
05:55 Bristol Temple Meads to Penzance
05:57 Swansea to London Paddington
06:47 Bristol Temple Meads to Penzance
06:52 Weston-Super-Mare to London Paddington
06:54 Taunton to London Paddington
07:00 Gloucester to Plymouth
07:24 Taunton to London Paddington
07:52 Reading to Gatwick Airport
08:11 Gloucester to Frome
09:18 London Paddington to Cardiff Central
09:32 London Paddington to Cheltenham Spa
10:30 London Paddington to Weston-Super-Mare
04:54 Plymouth to London Paddington
06:38 Weymouth to Gloucester
07:34 Redhill to Reading
08:15 Truro to Falmouth Docks
08:15 Falmouth Docks to Truro
08:45 Falmouth Docks to Truro
08:54 Reading to Gatwick Airport
09:38 Bristol Temple Meads to Worcester Foregate Street
April 29, 2025, 08:51:00 *
[361] Chiltern Railways: an update on rolling stock / services
[56] Doublebagging, Rawdoggers, Barebackers
[49] Driving licences and tests - ongoing discussion, merged topics
[36] Station Jim’s whereabouts
[34] Thames Valley infrastructure problems causing disruption elsew...
[30] North Cotswold line - driver route knowledge
Author Topic: Severn Beach line long-distance anomalies  (Read 1056 times)
« on: December 01, 2022, 09:27:51 »
An Off Peak return from Temple Meads to Gloucester is £11. An Anytime return from the inner half of the Severn Beach line to Temple Meads is £2. Yet an Off Peak return from eg Redland to Gloucester is £15.20. Even if allowing for two singles at £1.50 each rather than a return, that's still £1.20 more than buying separate tickets. What's the explanation for this? Perhaps it's something at Gloucester rather than the Beach line, as it was effectively zero up to Leeds. I hope the answer isn't "split tickets at Cam & Dursley"!
« Reply #1 on: December 01, 2022, 10:59:05 »
I used to find it best to buy a return ticket from Redland to Bristol (Severn Beach Line) and the a separate return from TM (Train Manager, or Ticket Machine, or Temple Meads (Bristol), depending on context) to Cheltenham for a day trip as it would save me quite a bit.  For example, with an "advanced middle age" Railcard, an open return TM to Cheltenham is £7.50 and the Redland to TM day return is £1.30 making a total of £8.80.  A Redland to Cheltenham open return is £10.  There had been times when the saving was even greater.
This pales into insignificance should you purchase a Redland to Kidderminster (for example) open return ticket on the GWR (Great Western Railway) App.  Temple Meads to Kidderminster (again with Railcard) open return £42.40 while from Redland it's £51.65.
I should add that if you travel in other directions from the Beach line, such as heading south, southwest or east, this seems not to be an issue.
« Reply #2 on: December 01, 2022, 11:51:22 »
Yes. Well for the sake of fewer bits of card to lose it might be considered worth paying the extra £2.20, but not if I were going to Kidderminster! But I was really wondering why this happens? I recall a similar instance of finding a single from Ashchurch to Filton Abbey Wood cost more than to Temple Meads and the reason for this was explained that fares from TM (Train Manager, or Ticket Machine, or Temple Meads (Bristol), depending on context) are set by GWR (Great Western Railway) whereas that FAW to ASC (Area Signalling Centre) fare is set by Cross Country. Although I don't think there are any XC (Cross Country Trains (franchise)) trains that stop at Filton? Could it be something similar here?
« Reply #3 on: December 01, 2022, 15:27:21 »
It doesn't seem to be just with FGW (First Great Western) to XC (Cross Country Trains (franchise)) services either.  For example, Redland Station to Leominster works out as £13.40 more (again with railcard) than the same open return journey from Temple Meads.  It's FGW services to Newport and the Transport for Wales from there.
With my local station being Redland, I'm quite careful to check for these anomalies.
