Travel & transport from BBC stories as at 01:15 22 Apr 2025
- Passengers evacuate Delta plane after engine fire
01:15 Reading to London Paddington
22:00 Hereford to London Paddington
22:45 London Paddington to Port Talbot Parkway
An additional train service has been planned to operate as shown 22/04/25 00:07 Cardiff Central to Bristol Temple Meads
April 22, 2025, 01:23:37 *
[96] Fortuitous connections ... and an App which fails to offer the...
[82] Firstgroup's rail division trading 'ahead of expectations'
[68] Eyesight rules for motorists unsafe, says coroner
[56] West Somerset Railway - Bishops Lydeard to Minehead (merged po...
Author Topic: Henley Regatta Service - 2022  (Read 6763 times)
« on: June 29, 2022, 11:10:38 »
I assume this is for some "operational reason" - but the usual Twyford to Henley and Henley to Twyford arrivals and departures have been replaced by a circular service.
Makes for a rather confusing CIS (Customer Information System) display
Mark A
« Reply #1 on: June 29, 2022, 12:16:09 »
Not convinced that everyone will know what a 'Circular route' means in that context.
Not that the majority will immediately think "It's been some time since the railway had the ambition to extend the Henley branch to Marlow, in which case we could certainly have Twyford - Bourne End (reverse) - Maidenhead (reverse) - Twyford."
« Reply #2 on: June 29, 2022, 12:47:29 »
It means that Wargrave now has four trains per hour to Twyford  Grin
sunshinehappyness
Newbie
« Reply #3 on: June 30, 2022, 15:12:51 »
The timings are no different from normal - every 30 minutes, service pattern obviously skips Shiplake in one direction.  I can see they might need to build in a couple more minutes dwell time (hence the skip) and I wonder if this circular route is so they can say every service still stops at all stations?
« Reply #4 on: July 01, 2022, 19:28:05 »
Came past Twyford on P4 today (11h30) heading to PAD» (Paddington (London) - next trains) and the blazers and summer dresses were squeezed into 4 Turbos tighter than any Bakerloo scrum that I have ever seen. And the queue out onto the forecourt was huge. Can't have been a pleasant 10 minutes for the revellers but looked highly profitable for GWR (Great Western Railway).
« Reply #5 on: July 01, 2022, 20:08:43 »
It’ll be no more profitable for GWR (Great Western Railway) had there be double the number of passengers.   Wink
« Reply #6 on: July 01, 2022, 21:19:09 »
So is there any motivation for GWR to encourage people to use the train, or is that now a task of the ministry?
« Reply #7 on: July 01, 2022, 22:39:03 »
.....how about "Five go to Henley"?
They spent a fair few £ on the Enid Blyton campaign, could try to squeeze a few drops out of that?
« Reply #8 on: July 01, 2022, 22:45:02 »
We don't have the text of GWR's NRC, but SWR» (South Western Railway - about)'s is available and no doubt the structure will be much the same. There are, inevitably, incentives. These are listed, but most of the numbers of pounds and some of the key details are omitted. But here's a list of the components of that calculation, and what they are can be guessed. One amount of money is given: the maximum performance based fee is £1,092,307.69 per period.
£PBF = OP (Original Poster / topic starter) + CS + SQ + FIN + BM
£PBF   shall have a value between zero and the Maximum Performance Based Fee in relation to the relevant PBF Assessment Period;
OP    means the sum (in pounds sterling) that is zero or a positive number representing the Operational Performance Fee calculated in accordance with the Applicable Assessment Methodology;
CS    means the sum (in pounds sterling) that is zero or a positive number representing the Customer Satisfaction Fee calculated in accordance with the Applicable Assessment Methodology;
SQ    means the sum (in pounds sterling) that is zero or a positive number representing the Service Quality Standards Fee calculated in accordance with the Applicable Assessment Methodology;
FIN   means the sum (in pounds sterling) that is zero or a positive number representing the Financial Performance Fee determined in accordance with paragraph 2.3; and
BM   means the sum (in pounds sterling) that is zero or a positive number representing the Business Management Fee calculated in accordance with the Applicable Assessment Methodology.
There are two ways of calculating £FIN, depending on something (Shapps, I think):
FIN(Cost) + FIN(Revenue) + FIN(TT)   or
FIN(Profit) + FIN(TT)
For operational performance, the further breakdown is:
The value of OP for the purposes of the formula set out in paragraph 2.2 of Chapter 7.2 shall be calculated as the aggregate of the calculations performed with respect to each Reporting Period in the relevant PBF Assessment Period pursuant to paragraphs 2.2 to 2.4 of this Appendix 5 to Chapter 7.2 (as applicable), in respect of each of:
(a) TOC (Train Operating Company) on Self Cancellations;
(b) TOC Minutes Delay;
(c) Short Formations;
(d) T-3;
(e) T-15; and
(f) All Cancellations.
In most cases that I can see, upper and and lower target levels are defined and the relevant payment component scales from zero to its defined maximum over that range. A lot of words are involved in this process (I can't guarantee that none were harmed).
« Last Edit: July 02, 2022, 12:17:54 by stuving » Logged
« Reply #9 on: July 02, 2022, 11:40:48 »
So, to sum up Stuving's post.  There's a lot less incentive than there was before.
« Reply #10 on: July 02, 2022, 12:29:24 »
...........and let's face it, they never tried particularly hard when there was.
