« Reply #300 on: August 06, 2022, 15:36:21 » |
16:24 Warminster to Swindon due 17:25 17:35 Swindon to Westbury due 18:17 18:35 Westbury to Swindon due 19:25 19:35 Swindon to Westbury due 20:16
19:35 Swindon to Westbury due 20:16 will be cancelled. This is due to a shortage of train crew.
« Reply #301 on: August 07, 2022, 17:32:06 » |
16:43 Frome to Swindon due 17:34 was terminated at Westbury.
It will no longer call at Trowbridge, Melksham, Chippenham and Swindon. This is due to a shortage of train crew. 17:44 Swindon to Salisbury due 18:55
17:44 Swindon to Salisbury due 18:55 will be started from Westbury. It will no longer call at Swindon, Chippenham, Melksham and Trowbridge. This is due to a shortage of train crew.
« Reply #302 on: August 08, 2022, 18:41:09 » |
18:34 Westbury to Swindon due 19:21 20:45 Swindon to Westbury due 21:26
20:45 Swindon to Westbury due 21:26 will be cancelled. This is due to a problem with line-side equipment. Odd one ...
« Reply #303 on: August 08, 2022, 18:55:54 » |
Freight train has tripped a hot axle box detector near Kintbury on the Berks & Hants.
« Reply #304 on: August 08, 2022, 20:38:56 » |
And what has this to do with the TransWilts
« Reply #305 on: August 08, 2022, 22:13:47 » |
The following were diverted via Melksham
14:15 Penzance to London Paddington 17:36 London Paddington to Plymouth
Several others were planned to be diverted but at the last moment (and after a brief delay at Reading for the 18:04) ran via Newbury as booked.
« Reply #306 on: August 10, 2022, 16:51:35 » |
16:25 Westbury to Swindon due 17:08
16:25 Westbury to Swindon due 17:08 will be starting late from Westbury and is expected to be 25 minutes late. This is due to train crew being delayed by service disruption.
« Reply #307 on: August 11, 2022, 16:24:51 » |
20:06 Westbury to Cheltenham Spa due 22:05 will be cancelled.
« Reply #308 on: August 14, 2022, 07:18:01 » |
For the completion of records - all trains cancelled yesterday due to ASLEF» strike action. Typically this thread reports only on changes made on the day, but we must remember that passengers are equally unable to use trains removed from the timetable a week ahead as they are trains removed from the timetable an hour ahead! This morning, the direct train to Weymouth no longer goes to Weymouth: 11:41 Swindon to Weymouth due 14:00
11:41 Swindon to Weymouth due 14:00 will be terminated at Westbury. It will no longer call at Frome, Bruton, Castle Cary, Yeovil Pen Mill, Thornford, Yetminster, Chetnole, Maiden Newton, Dorchester West, Upwey and Weymouth. This is due to a shortage of train crew.
« Reply #309 on: August 14, 2022, 12:52:05 » |
Looks like it is running through to Weymouth but delayed at Westbury for 22 minutes to maintain connections.
« Reply #310 on: August 14, 2022, 14:46:12 » |
And the next one ... 13:41 Swindon to Weymouth due 15:51 13:41 Swindon to Weymouth due 15:51 has been delayed at Swindon and is now 10 minutes late.
This is due to the train departing late to maintain customer connections. It does make common sense to maintain connections - especially onto infrequent services
« Reply #311 on: August 14, 2022, 18:04:50 » |
18:24 Frome to Swindon due 19:17
18:24 Frome to Swindon due 19:17 will be cancelled.
This is due to more trains than usual needing repairs at the same time. 19:29 Swindon to Westbury due 20:11
19:29 Swindon to Westbury due 20:11 will be cancelled.
« Reply #312 on: August 15, 2022, 04:51:45 » |
06:35 Salisbury to Cheltenham Spa due 09:03
06:35 Salisbury to Cheltenham Spa due 09:03 will be started from Westbury. It will no longer call at Salisbury and Warminster. This is due to a shortage of train crew.
« Reply #313 on: August 15, 2022, 05:47:48 » |
06:11 Swindon to Southampton Central due 08:07 will be terminated at Westbury. It will no longer call at Dilton Marsh, Warminster, Salisbury, Romsey and Southampton Central. This is due to a shortage of train crew.
« Reply #314 on: August 16, 2022, 04:26:19 » |
07:37 Westbury to Swindon due 08:19 08:45 Swindon to Westbury due 09:26
08:45 Swindon to Westbury due 09:26 will be cancelled. This is due to a shortage of train crew . Oh dear - isn't the 07:37 (07:53 off Melksham) one of the "priority trains" only cancelled as a last resort? Never mind - next train at 10:02 and I'm sure employers won't mind their staff being late ...
