« Reply #285 on: July 18, 2022, 21:23:18 » |
20:45 Swindon to Westbury due 21:26 will be cancelled.
« Reply #286 on: July 19, 2022, 21:30:22 » |
And the reason today ... 20:45 Swindon to Westbury due 21:26
20:45 Swindon to Westbury due 21:26 has been cancelled. This is due to a shortage of train crew.
« Reply #287 on: July 19, 2022, 21:32:58 » |
20:06 Westbury to Cheltenham Spa due 22:05
20:06 Westbury to Cheltenham Spa due 22:05 will be started from Swindon. It will no longer call at Westbury, Trowbridge, Melksham and Chippenham. It is being delayed at Swindon. This is due to trespassers on the railway.
« Reply #288 on: July 20, 2022, 06:51:55 » |
06:35 Salisbury to Cheltenham Spa due 09:03 Facilities on the 06:35 Salisbury to Cheltenham Spa due 09:03. Toilet facilities are not available.
« Reply #289 on: July 21, 2022, 11:46:31 » |
11:05 Swindon to Westbury due 11:47
11:05 Swindon to Westbury due 11:47 is being delayed between Chippenham and Melksham and is now expected to be 10 minutes late. This is due to a late running freight train. No problem, as long as the infrequent connections to Exeter and Yeovil, and the hourly one to Portsmouth, are maintained
« Reply #290 on: July 22, 2022, 06:50:23 » |
07:37 Westbury to Swindon due 08:19
07:37 Westbury to Swindon due 08:19 will be starting late from Westbury and is expected to be 5 minutes late. This is due to a shortage of train crew. Logging for completeness - not really a serious issue
« Reply #291 on: July 22, 2022, 06:51:49 » |
07:37 Westbury to Swindon due 08:19 will be starting late from Westbury and is expected to be 5 minutes late. This is due to a shortage of train crew. Logging for completeness - not really a serious issue Knock on from 06:39 Bristol Temple Meads to Westbury due 07:27
06:39 Bristol Temple Meads to Westbury due 07:27 is being delayed at Bristol Temple Meads and is now expected to be 15 minutes late. This is due to a shortage of train crew.
« Reply #292 on: July 22, 2022, 07:40:08 » |
07:37 Westbury to Swindon due 08:19 08:45 Swindon to Westbury due 09:26 09:46 Westbury to Swindon due 10:34 11:05 Swindon to Westbury due 11:47 12:17 Westbury to Swindon due 12:59 13:15 Swindon to Westbury due 13:56 14:16 Westbury to Swindon due 15:01 15:14 Swindon to Westbury due 15:58 16:25 Westbury to Swindon due 17:08 17:36 Swindon to Westbury due 18:20 18:34 Westbury to Swindon due 19:21 20:45 Swindon to Westbury due 21:26
Facilities on the 20:45 Swindon to Westbury due 21:26. Disabled toilet facilities are not available. This is due to a fault on this train.
Additional Information We are sorry this service has no accessible toilet facilities today. As issues go, not a huge one ... others may differ if caught short
« Reply #293 on: July 24, 2022, 16:52:59 » |
18:24 Frome to Swindon due 19:17
18:24 Frome to Swindon due 19:17 will be started from Westbury. It will no longer call at Frome. This is due to a broken down train.
« Reply #294 on: July 31, 2022, 17:53:03 » |
16:43 Frome to Swindon due 17:34
16:43 Frome to Swindon due 17:34 has been delayed at Westbury and is now 17 minutes late. This is due to overcrowding because of an earlier cancellation.
« Reply #295 on: August 01, 2022, 21:22:35 » |
20:45 Swindon to Westbury due 21:26 is being delayed at Swindon and is now expected to be 5 minutes late. This is due to the train departing late to maintain customer connections. Good call ...
« Reply #296 on: August 02, 2022, 13:43:11 » |
13:15 Swindon to Westbury due 13:56 will be diverted between Chippenham and Trowbridge. It will no longer call at Melksham. It is being delayed between Chippenham and Trowbridge and is now expected to be 7 minutes late. This is due to congestion.
« Reply #297 on: August 02, 2022, 14:03:21 » |
13:15 Swindon to Westbury due 13:56 will be diverted between Chippenham and Trowbridge. It will no longer call at Melksham. It is being delayed between Chippenham and Trowbridge and is now expected to be 7 minutes late. This is due to congestion. Ah Alterations to services between Westbury and Reading
Due to a broken down train between Westbury and Reading the line towards Reading is blocked.
Train services running to and from these stations may be delayed by up to 30 minutes or diverted between Reading and Taunton. Pewsey will not be served. Disruption is expected until 14:30 02/08.
« Reply #298 on: August 02, 2022, 14:22:09 » |
and now correct calling pattern again but delayed 13:15 Swindon to Westbury due 13:56
13:15 Swindon to Westbury due 13:56 is being delayed between Chippenham and Melksham and is now expected to be 30 minutes late. This is due to a broken down train. Two tracks, Now!
« Last Edit: August 02, 2022, 14:33:39 by grahame »
« Reply #299 on: August 03, 2022, 05:21:38 » |
05:17 Westbury to Swindon due 05:59 05:17 Westbury to Swindon due 05:59 will be cancelled. This is due to a broken down train.
06:11 Swindon to Southampton Central due 08:07 06:11 Swindon to Southampton Central due 08:07 will be cancelled. This is due to a broken down train.
