No recent travel & transport from BBC stories as at 11:55 11 Jan 2025
 14/01/25 - Rail Sale starts
11th Jan (2012)
11:19 Frome to Weymouth
11:50 London Paddington to Hereford
14:00 Bristol Temple Meads to London Paddington
08:48 London Paddington to Carmarthen
11:09 Gloucester to Bristol Temple Meads
11:24 Exmouth to Paignton
January 11, 2025, 12:00:35 *
[85] Thames Valley infrastructure problems causing disruption elsew...
[75] Westminster Hall debate : Railway services to South West
[56] TravelWatch SouthWest - merged posts
[53] North Cotswold line delays and cancellations - 2025
[46] one pound flat rate bus fares in Devon and Torbay area.
Author Topic: Viaduct scene in "Around the World in Eighty Days"  (Read 1566 times)
Marlburian
« on: December 28, 2021, 09:48:44 »
Anyone else viewing this TV version? I think that the railway scene may have been filmed in Romania. It features a vintage train trundling along a single track with vegetation growing between the sleepers. It comes to a damaged viaduct, with no support under one section of track. Understandably the crew don't want to proceed, but Phileas Fogg (hitherto depicted as a wimp) decides it can be done, to get an injured child to hospital.
First the coal has to be removed from the tender to lighten the load, then, once across, the one carriage is stripped of all its wood for fuel. (In the book this happened to the small ship crossing the Atlantic.) I hope that the carriage was a modern mock-up, not a vintage vehicle!
The plot itself wasn't at all convincing, but the filming was, even allowing for CGI (Computer-generated imagery). Presumably it was filmed on a semi-derelict line and the viaduct did look as if it were genuinely damaged.
Any thoughts on the locomotive used and on the filming?
(There was a similar scene in North West Frontier where, IIRC (if I recall/remember/read correctly), the loco's weight cause the rails to sag. This after the doughty escapees, led by Kenneth More, had previously unbolted a section of rail from behind their train to replace one that was missing in front of it.)
« Reply #1 on: December 28, 2021, 11:52:32 »
It’s a small point, given the ludicrousness every other detail of the plot, but I can’t help thinking that most of the sleepers would have stayed attached to the rails. This could allow you to suspend your critical faculties for a few minutes and almost believe that a train could have crossed the gap (though how far it would have got with no water on the boiler is another matter). But no! All the sleepers were gone, leaving two unsupported rails between which even the lightest of rail vehicles would obviously drop.
All rather silly.
