No recent travel & transport from BBC stories as at 11:35 26 Apr 2025
April 26, 2025, 11:35:38 *
Author Topic: Car Share - an idea who's time is coming?  (Read 1105 times)
« on: September 28, 2021, 06:39:42 »
Car Share - a way to reduce the number of cars travelling on our roads, saving fuel and reducing congestion and the need to build more roads by making use of empty seats that are already there.  Talked about and tried in the past, is the current (blip?) in fuel supplies a trigger to encourage us along this greener path, and make it work widely?   See my blog at http://grahamellis.uk/blog271.html ...
Ralph Ayres
« Reply #1 on: September 29, 2021, 10:27:32 »
Car share has probably fallen out of favour thanks to the pandemic and I suspect it will take some time to recover.
Longer-term though, car share is more flexible than public transport in terms of the route taken (it will generally be door-to-door) but less so re timing.  It needs two or more people who can work or have to work pretty much identical hours which is if anything becoming less common as working practices change.  Leisure trips (going to the same show) are more likely but that probably happens more generally already.
« Reply #2 on: September 29, 2021, 11:02:46 »
I did car-share with a colleague in 2000 - his car had some fuel in it, mine was almost empty at kick-off time. Even though we lived fairly close, and worked the same hours most days, we found it hard to cooperate closely enough and did not persist with the arrangement.
Since then, hours had already become more adaptable, and  now the common days of travel to work will be fewer for office workers at least. So presumably the scope for this kind of car-sharing will be much less too.
It would take a big "push" from outside factors to make up for this lack of "pull" factors (i.e. those relating to the people concerned). Maybe something like the big green fuel price hike implied by the government's decarbonisation plans, dressed up in some way that placates the Tory back benches (and others) but would not help office workers commuting by car?
