No recent travel & transport from BBC stories as at 16:35 26 Apr 2025
16:02 Westbury to Gloucester
April 26, 2025, 16:43:23 *
[148] Standardisation of Time and the Railway Clearing House
[82] Intoxicated person plan needed on Tube - coroner, April 2025
[56] BBC TV Licensing - ongoing discussion
[53] HS2 - Government proposals, alternative routes and general dis...
[48] Experiences of a newcomer(?) to rail travel
Author Topic: Only connect  (Read 4221 times)
« on: September 13, 2021, 23:18:13 »
Next in the sequence, and why? (One each please)
1. 1877, 1969, 1984, 1992
2. 05:33, 07:20, 07:52
3. 1, 1, 2, 3, 5
4. New Brighton, Ellesmere Port, West Kirby
5. MPK, MSO (Motor Standard Opens), MTH, MOT, MTG
6. Campaigner, Ranger, Champion
7. Beef, Duck, Hake
brooklea
« Reply #1 on: September 14, 2021, 06:56:37 »
6. Fusilier; in numerical order, the name of the next surviving member of the Western Class locomotives.
D1010 Western Campaigner, D1013 Western Ranger, D1015 Western Champion, D1023 Western Fusilier
PrestburyRoad
« Reply #2 on: September 14, 2021, 08:21:02 »
3. 8; Fibonacci sequence - or maybe grahame wanted a different railway-related answer?
« Reply #3 on: September 14, 2021, 08:27:51 »
You're correct ... I slipped just that one general sequence into the railway-specific ones. But I'm sure that someone will come up with a rail answer to!
Yes indeed.  I was looking at a warship sequence too, but I don't think enough have been preserved. I wonder why - personally I found them more artistic looking that the westerns.
« Reply #4 on: September 14, 2021, 09:49:52 »
I thought there must be SOME link between trains and Fibonacci - and came across the following:
https://mast.queensu.ca/~math9-12/manual/TrainsManual.pdf
Counting Trains
This is quite an interesting activity. In line with my big theme of par- allel structures, it presents the students with two worlds:
The Fibonacci world. A sequence of integers generated with one of the simplest of all recursive generators: . This is an abstract world which contains many unexpected patterns, some of which we will encounter here.
The trains world. A sequence of integers with a concrete realization (number of trains of a fixed length) giving us a powerful access to the surprising patterns of the Fibonacci world.
In this unit the students are challenged to provide proofs for some of the well-known Fibonacci formulae by invoking properties of the structure of trains.
Edit - rewritten part of my post which got lost in submission ...
« Last Edit: September 14, 2021, 10:01:28 by grahame » Logged
« Reply #5 on: September 14, 2021, 13:50:31 »
4 - Birkenhead (stations on the Wirral served by Northern Rail, but they don't seem to be in the right order?)
« Reply #6 on: September 14, 2021, 14:01:38 »
Not Birkenhead - you're headed in the right direction, but the answer goes a little further.
« Reply #7 on: September 14, 2021, 14:04:44 »
Then is it Chester, as the fourth (and last) Merseyrail (Wirral Line) terminus? But I've no idea what the chosen order is about.
PS: It's distance from Hamilton Square (or beyond), isn't it?
« Last Edit: September 14, 2021, 14:11:57 by stuving » Logged
« Reply #8 on: September 14, 2021, 14:42:26 »
It is indeed Chester ... and the order is the typical sequence of departures from Liverpool ... it's not 100% the same all the time, but once the other three have left it's pretty much certain the next one will be to Chester!
« Reply #9 on: September 14, 2021, 15:45:58 »
5: DBG - Mottisfont & Dunbridge - next station in alphabetical order
« Reply #10 on: September 17, 2021, 08:33:51 »
4 sequences worked out, 3 to go.   Anyone?
3. 1, 1, 2, 3, 5
Fibonacci series - 8 is next (Prestbury Road)
Departures from Liverpool for the Wirral - Chester is next (Stuving)
Station codes in alphabetic order of station names - DBG is next (Oxonhutch)
Surviving Westerns - Fusilier is next (Brooklea)
7. Beef, Duck, Hake
« Reply #11 on: September 17, 2021, 09:12:14 »
... (One each please)
Is this a continuous restriction, or does the 24 hour override apply?
« Reply #12 on: September 17, 2021, 09:19:15 »
The 24 hours override applies through grandfather rights  Grin ... please do ahead and fill in the other(s)
« Reply #13 on: September 17, 2021, 09:28:19 »
1: 1994, the fourth derailment at Morpeth, Northumberland - 1992 was a collision between two trains.
brooklea
« Reply #14 on: September 17, 2021, 09:32:13 »
2. 10:02 Northbound train departures from Melksham on a weekday (although this doesn’t quite fit as the sequence would be 05:33, 07:20, 07:51, 10:02)
