Travel & transport from BBC stories as at 21:35 10 Jan 2025
 14/01/25 - Rail Sale starts
19:36 London Paddington to Worcester Shrub Hill
20:59 Cheltenham Spa to London Paddington
January 10, 2025, 21:49:32 *
[124] Thames Valley infrastructure problems causing disruption elsew...
[109] Westminster Hall debate : Railway services to South West
[67] Ryanair sues 'unruly' passenger over flight diversion
[60] Mick Lynch announces retirement as head of RMT
[56] 'Railway 200' events and commemorations 2025
[44] GWR Advance Purchase sale - January 2025
Author Topic: Wet, wet, wet - where?  (Read 3104 times)
« on: July 27, 2021, 17:33:29 »
Inspired by floods at Yeovil
Where are these?   (one each, please, for first 24 hours)
1.
2.
3.
4.
5.
6.
7.
brooklea
« Reply #1 on: July 27, 2021, 17:46:52 »
1. Newbury
Zoe
« Reply #2 on: July 27, 2021, 17:47:49 »
6 is Penzance.
Clan Line
« Reply #3 on: July 27, 2021, 18:07:10 »
5.  The car wash at Warminster Station.
« Reply #4 on: July 27, 2021, 18:20:56 »
3 is still Melksham
PhilWakely
« Reply #5 on: July 27, 2021, 20:17:32 »
2. Dawlish
« Reply #6 on: July 28, 2021, 10:13:05 »
All correct so far - just 4. and 7. (the historic ones!) to work out.  Clue - both stations shown are now closed.
chuffed
« Reply #7 on: July 28, 2021, 10:48:04 »
WOT..no Taunton? Is this a first for a picture quiz??  Grin
Witham Bobby
« Reply #8 on: July 28, 2021, 15:31:35 »
4 is Glastonbury
Witham Bobby
« Reply #9 on: July 28, 2021, 16:10:57 »
7 - Corsham? Maybe.  Would be a lot easier if that station nameboard was clearer  Cheesy
« Reply #10 on: July 28, 2021, 16:24:09 »
All correctly worked out.
1 Newbury - brooklet
2 Dawlish - PhilWakely
3 Melksham - Stuving
4 Glastonbury - Witham Bobby
5 Warminster - Clan Line
6 Penzance - Zoe
7 Corsham - Witham Bobby
 I couldn't find a picture of Taunton Station flooded - probably too high.   Best I could find:
Clan Line
« Reply #11 on: July 28, 2021, 18:57:48 »
To digress slightly............
The frequent flooding under the line at Warminster Station defied many attempts over quite a few years to solve the problem. One "solution" (pun intended) involved fixing two vertical rulers to the walls of the underbridge to indicate the depth of the water to approaching drivers. However.................the rulers were so far back from the lowest point of the road under the bridge that there would have to be at least 18" (45.72 cm  Wink) of water under the bridge before even the Zero marks on the rulers were reached. I never actually saw the water get anywhere near the zero mark !
« Reply #12 on: July 28, 2021, 20:15:34 »
Presumably, the logic of that was to make sure drivers could see the marks in time - there being no point putting them where the water was, because they would only be seen too late.
Clan Line
« Reply #13 on: July 29, 2021, 10:08:48 »
To pass under the bridge needs a 90° turn on entry and exit, so the rulers were directly in front of the approaching drivers, and were visible before any flood water would be seen. The driver needs to know the deepest depth of the water, not that there is no measurable water at the rulers, which were located outside of the bridge. The "zero" mark on the rulers should have started at 18" not at 0". Apart from which, as I said, the water never reached the rulers anyway.................................absolutely pointless. Even with the rulers, the depth of water was still unknown.
froome
« Reply #14 on: July 29, 2021, 14:17:47 »
In my opinion a more important point about the flooding under the bridge in Warminster is that it is the only route a wheelchair user, someone pushing a push chair or pram, or a cyclist can exit the station if they have got off on the south-eastbound platform. It has happened to me with a bike, though only with very minor flooding which I could get through.
Imagine what happens if you are in a wheelchair and find yourself rounding a corner and coming face to face with 18" of water to go through...
