No recent travel & transport from BBC stories as at 10:35 13 Apr 2025
16/04/25 - Walk from Chetnole
13th Apr (1854)
First (broad gauge) train ran complete line from Oxford via Worcester to Wolverhampton (link)
13/04/25 08:23 London Paddington to Swansea
13/04/25 08:29 Weston-Super-Mare to London Paddington
13/04/25 09:35 Swindon to Cheltenham Spa
09:38 Bristol Temple Meads to Worcester Shrub Hill
13/04/25 09:55 Bristol Parkway to London Paddington
13/04/25 11:27 Carmarthen to London Paddington
13/04/25 11:30 London Paddington to Bristol Temple Meads
13/04/25 12:30 Swindon to Cheltenham Spa
12:32 London Paddington to Paignton
13:02 London Paddington to Plymouth
13:21 Exeter St Davids to London Paddington
13:41 Gloucester to Bristol Temple Meads
13/04/25 14:00 Cheltenham Spa to Swindon
14:32 London Paddington to Exeter St Davids
13/04/25 16:35 London Paddington to Swansea
19:00 London Paddington to Bristol Temple Meads
19:29 Swindon to Cheltenham Spa
21:36 Barnstaple to Exeter St Davids
09:35 Severn Beach to Weston-Super-Mare
09:37 Barnstaple to Exeter Central
13/04/25 10:02 London Paddington to Penzance
11:54 Worcester Shrub Hill to Bristol Temple Meads
12:09 Portsmouth Harbour to Cardiff Central
13:41 London Paddington to Great Malvern
14:02 London Paddington to Penzance
13/04/25 14:09 Portsmouth Harbour to Cardiff Central
14:41 London Paddington to Great Malvern
14:58 Cardiff Central to Penzance
16:47 Bristol Temple Meads to Castle Cary
16:58 Great Malvern to London Paddington
20:11 Exeter Central to Barnstaple
21:00 Cheltenham Spa to Swindon
09:18 Cardiff Central to Portsmouth Harbour
April 13, 2025, 10:41:28 *
[75] Probably one of the ugliest dolls I have seen around
[56] Great Western Railway: on-board catering, buffets, Travelling ...
[46] A36 Closed Limpley Stoke August to Spring 2025
[44] Delays on Devon services - merged posts, ongoing discussion
[43] Thank goodness for a kettle!
[41] 25th May 2025 - SWR Franchise expires and services Nationalise...
Author Topic: Cotswold Line - 2021 Delays and Cancellations  (Read 15473 times)
Witham Bobby
« on: March 03, 2021, 11:04:52 »
Signalling troubles on the Oxford Panel controlled section from Wolvercote towards Ascott-u-Wychwood today
Several delays and short workings, including
08:13 Worcester Shrub Hill to London Paddington due 10:24
08:13 Worcester Shrub Hill to London Paddington due 10:24 has been delayed at Charlbury and is now 32 minutes late.
charles_uk
thewalkingpage
« Reply #1 on: June 15, 2021, 16:33:00 »
It's warm but not excessively so. However:
Alterations to services between Charlbury and Evesham
Due to a speed restriction because of high track temperatures between Charlbury and Evesham trains have to run at reduced speed on all lines.
Train services running through these stations may be delayed by up to 20 minutes or revised. Disruption is expected until the end of the day.
There's been delays throughout the day and similarly yesterday, some in excess of twenty minutes.
That said, I've no idea how many are actually been affected. I've been working from home for fifteen months now.
Moderator
« Reply #2 on: June 15, 2021, 16:45:41 »
There were a couple of restrictions following the bridge replacement work, including one long one of 50mph for nearly three miles on the single line section.  I imagine the track hasn't been stressed yet allowing those restrictions to be lifted, and the heat has meant 50mph has been restricted further to 20mph.
Witham Bobby
« Reply #3 on: September 15, 2021, 09:53:05 »
09:50 London Paddington to Hereford due 12:43
09:50 London Paddington to Hereford due 12:43 will no longer call at Slough.
This is due to this train hitting an obstruction on the line.
[/i]
I don't suppose this amendment will have affected may passengers for the OWW (Oxford Worcester and Wolverhampton) line, but it does seem to have arisen from a bit of an odd reason
Witham Bobby
« Reply #4 on: September 17, 2021, 13:40:34 »
Delays to services between Worcester Shrub Hill and Oxford
Following urgent repairs to a bridge between Worcester Shrub Hill and Oxford all lines will be reopened shortly.
Train services running through these stations will be delayed. Disruption is expected until 14:30 17/09.
Customer Advice
Replacement road transport has begun operating between Worcester Shrub Hill and Oxford via Moreton-in-Marsh although this is proving difficult to resource, and is very limited. ... [snip]
[/i]
No fun if you've wanted to use the OWW (Oxford Worcester and Wolverhampton) today
Witham Bobby
« Reply #5 on: September 24, 2021, 14:57:50 »
13:18 Hereford to London Paddington due 16:24
13:18 Hereford to London Paddington due 16:24 will be started from Oxford.
It will no longer call at Hereford, Ledbury, Colwall, Great Malvern, Malvern Link, Worcester Foregate Street, Worcester Shrub Hill, Worcestershire Parkway Hl, Pershore, Evesham, Honeybourne, Moreton-In-Marsh, Kingham, Charlbury and Hanborough.
The corresponding Down working, 1W01 0950 ex Padd was in trouble at Twyford and caped at Oxford
Newbie
« Reply #6 on: October 05, 2021, 09:29:59 »
Yesterday morning’s disruption demonstrated yet again the problems caused by the single line section at the Oxford end of the line.
The 0514 WOS» (Worcester Shrub Hill - next trains) to PAD» (Paddington (London) - next trains) hit a deer somewhere near Charlbury, and proceeded at slow speed to Oxford, where it arrived 50 late and was cancelled.
It in turn delayed the 0550 PAD to GMV (Great Malvern station), which was 13 late at Charlbury.
The 0448 HFD» (Hereford - next trains) to PAD was delayed by both – first following the 0514, then waiting for the 0550 to clear the single line. It arrived at Oxford 51 late and at Paddington 46 late.
« Reply #7 on: October 05, 2021, 09:48:52 »
Welcome to the forum, 2251.   It's (another) good example of just how much the halving of some lines from 2 tracks to 1 has decimated capacity.  At least - thank goodness - one track remained. That said, even with two tracks, hitting an animal on the line and bringing a train to a halt would probably close the second line, at least for a brief check?
charles_uk
thewalkingpage
« Reply #8 on: October 13, 2021, 14:21:49 »
Today was my first visit to my work place since March last year. It actually felt remarkably normal: the cycle to my local station, the walk from my destination to the office, the office systems and everything. Even my train journeys seemed very normal: the morning service was over ten minutes late waiting for a delayed service to clear the single track between Wolvercote and Charlbury and my lunchtime train home:
11:50 London Paddington to Hereford due 14:41 was terminated at Oxford.
It will no longer call at Hanborough, Charlbury, Kingham, Moreton-In-Marsh, Evesham, Worcestershire Parkway Hl, Worcester Shrub Hill, Worcester Foregate Street, Malvern Link, Great Malvern, Colwall, Ledbury and Hereford.
with the return 15:18 HFD» (Hereford - next trains):PAD» (Paddington (London) - next trains) cancelled.
edit to remove errant comma
« Last Edit: October 13, 2021, 14:41:34 by charles_uk » Logged
« Reply #9 on: October 13, 2021, 19:31:12 »
.....welcome back to GWR (Great Western Railway), it's like you've never been gone!  Roll Eyes
« Reply #10 on: November 02, 2021, 10:54:18 »
Poor show by West Midlands Railway on the western half of the route today: both the 17.39 and 18.48 from Hereford are cancelled, leaving a 3hr+ gap in services between Hereford and Great Malvern across the evening peak. Ongoing staff shortage, I presume.
Moderator
« Reply #11 on: November 02, 2021, 11:06:42 »
Yes, they’ve been struggling more than most TOCs (Train Operating Company) recently.  Their new Class 196s are very delayed in entering service as well - it’s now almost two years since the first one was built.
charles_uk
thewalkingpage
« Reply #12 on: November 12, 2021, 15:29:37 »
The signalling problems between Didcot Parkway and Swindon/Oxford have been reported elsewhere but the impact on Cotswold Line services has been significant. In terms of services to the Cotswolds:
1W25 1250 London Paddington to Worcester Foregate Street
This service was cancelled due to a signalling systems failure (IF).
13:50 London Paddington to Great Malvern due 16:13 has been cancelled.
14:50 London Paddington to Worcester Foregate Street due 17:12 has been cancelled.
And whilst not on JourneyCheck yet, National Rail Enquiries is showing the following 15:20 Paddington to Worcester Foregate Street as being cancelled too. A number of return runs to London beginning to show up as cancellations too.
No suggestions of any alternative arrangements in place.
