Travel & transport from BBC stories as at 01:15 10 Jan 2025
January 10, 2025, 01:16:24 *
[59] Thumpers for Dummies
Author Topic: Railway textures  (Read 3706 times)
« on: January 03, 2021, 22:59:18 »
From this morning. Can you identify them?
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
« Reply #1 on: January 03, 2021, 23:07:30 »
Photo 3 is a cat. Texture-wise, cats tend to be rather furry.
I hope you're not wanting a more detailed answer  Huh
TonyN
« Reply #2 on: January 03, 2021, 23:23:51 »
1 is a bench
« Reply #3 on: January 03, 2021, 23:27:51 »
5. is a very decrepit bicycle. I suspect it's the last one beside the marked footpath outside Melksham station, just before it enters the platform. Obviously its meaning is "cyclists keep off the footpath".
« Reply #4 on: January 04, 2021, 07:52:45 »
6. Is the tactile marking near the edge of a railway platform.  I hope you don't expect us to name which one!
« Reply #5 on: January 04, 2021, 07:54:06 »
Or does it only apply to decrepit cyclists, those riding decrepit bicycles?
« Reply #6 on: January 04, 2021, 08:17:39 »
I'm not sure how much I intended this to be a "formal" quiz ... some pretty impossible questions!   All taken yesterday morning at or around Melksham Station, and all features identified correctly so far.
Western Pathfinder
« Reply #7 on: January 04, 2021, 09:34:29 »
No7. Anti trespass obstacle at the end of the platform.
« Reply #8 on: January 04, 2021, 10:07:11 »
Each time I look at that, the eye/brain's interpretation is the "inside out" reverse 3D one - some kind of mysterious pigeon-holes. That doesn't make convincing sense, but it takes a while to flip to the right 3D model. Even knowing what it is, that's still true.
« Reply #9 on: January 04, 2021, 10:08:24 »
If you're not sure of that, I'm sure I'm even less sure of it.
« Reply #10 on: January 04, 2021, 10:37:53 »
Yeah ... I found that. A clearer picture ...
PrestburyRoad
« Reply #11 on: January 04, 2021, 10:44:09 »
1 is a bench
1 is not just a bench, it's a bl**dy cold bench - in the winter I'd rather stand
chuffed
« Reply #12 on: January 04, 2021, 11:03:28 »
Number 3 is the cat tile one. For dyslexics check the t & c's.  Grin
« Reply #13 on: January 04, 2021, 12:36:21 »
No. 6 is tactile marking specifically for proximity to a railway. The dots are hexagonally packed (offset) rather than square (inline) ones that you will find at a dropped kerb on the roadside. We had two deliveries of the latter type for our platform 4 construction at Princes Risborough returned to the supplier before the correctly textured railway ones - that we specifically ordered - were delivered.
This video by Tom Scott explains more.
« Reply #14 on: January 04, 2021, 13:58:04 »
8 is salt on tarmac - to avoid it icing up.
This was a welcome sight on the old Goring footbridge - thanks Colin!
