Travel & transport from BBC stories as at 14:55 12 Jan 2025
- 'My partner hid and secretly waved off my ship': LGBT veteran monument revealed
- Peak District roads shut due to 'selfish' parking
 14/01/25 - Rail Sale starts
12th Jan (2009)
A quiet day in previous years (link)
12/01/25 10:55 Cardiff Central to Penzance
12/01/25 14:30 London Paddington to Exeter St Davids
14:50 Penzance to Exeter St Davids
15:00 London Paddington to Plymouth
15:20 Plymouth to Gunnislake
16:11 Gunnislake to Plymouth
17:23 Swansea to London Paddington
17:44 Plymouth to Gunnislake
18:28 London Paddington to Weston-Super-Mare
18:35 Gunnislake to Plymouth
18:58 London Paddington to Bristol Temple Meads
20:08 Trowbridge to Cardiff Central
20:25 Avonmouth to Bristol Temple Meads
20:37 Trowbridge to Bristol Temple Meads
21:05 Weston-Super-Mare to Bristol Temple Meads
21:28 London Paddington to Bristol Temple Meads
22:30 Cardiff Central to Bath Spa
22:35 Bristol Temple Meads to Trowbridge
15:08 Trowbridge to Cardiff Central
16:05 Trowbridge to Cardiff Central
16:35 Severn Beach to Weston-Super-Mare
17:37 Barnstaple to Exeter Central
18:25 Cardiff Central to Trowbridge
19:25 Cardiff Central to Trowbridge
10:00 London Paddington to Penzance
17:25 Cardiff Central to Trowbridge
January 12, 2025, 15:09:27 *
[166] Sunday Times Travel supplement - 14 page rail special
[76] Westminster Hall debate : Railway services to South West
[46] The User Group onion
[35] one pound flat rate bus fares in Devon and Torbay area.
[32] Shortage of train crews on Great Western Railway - ongoing dis...
[20] Mick Lynch announces retirement as head of RMT
Author Topic: Opportunities to do more engineering while things are quiet  (Read 2422 times)
« on: May 06, 2020, 16:09:07 »
One of the questions asked recently - "does the reduction in train services at present allow for engineering works on trains and track to be caught up on?".
Certainly the reduction of services has allowed the remaining ones to run much more reliabely ... ppms and cancellation rates against key route schedules being  dramatically improved.  Dark humour joke is that railways run far better without passengers; reallity is that removal of congestion, and a better availability of crew and trains, has done wonders.
For significant engineering works, there's a great deal of preparation to be done ahead of time and I would expect little to be brought forward.  So I am surprised and delighted to pick up from the Daventry Express works to Kilsby tunnel on the West Coast main line:
But Network Rail's engineers are using the lull in regular services and May's two Bank Holiday weekends to start work early on replacing track and improving drainage in the 1½-mile long tunnel, which is usually used by around 400 trains each day between London and Birmingham.
Kilsby Tunnel is on a two track section of the main line; there are four track from London to Roade, where the second pair ("slow" lines) loop off to the east to Pass thrrough Northampton and then head north through Long Buckby to rejoin the main line just south of Rugby.  So not all that long a diversion, but I can recall wheel-squealing tight curves into Northampton and a bit of a nightmare when there are problmes on the direct line at normal traffic levels.
The second part of my question - catching up on trains mainenance - I don't know.  On one hand, social distancing in the workshops.  On the other hand, stuff is not running as many miles and getting to need service anything like as quick!
« Reply #1 on: May 06, 2020, 21:37:34 »
It might have been a good time to get working on the Portway Station now that the Severn Beach Line is on a much reduced commuter service.
« Reply #2 on: May 07, 2020, 13:58:46 »
Yes, Northampton is certainly not geared up to take express trains!  Not only have you got the very slow 20mph restriction immediately south of the station, which there is little prospect of doing anything about, but the layout through and north of the station and then onwards to Rugby is pretty restrictive:  Twenty or thirty through the station area, raising to sixty for quite a long stretch until after the curves north of the town, and then finally 75mph through to Rugby.
Really that 75mph should be at least 90mph (there has been talk of that over the years), and the whole track layout immediately north of the station could do with optimising.  I have a friend who's a driver on the WCML (West Coast Main Line) and his heart sinks when he gets diverted that way!
Worth watching on the OTT (Open Train Times website) map at the moment as you can see how slowly everything moves, how many extra trains there are, and how long the expresses being diverted take to weave through Northampton:  https://www.opentraintimes.com/maps/signalling/lec4#T_NMPTN
« Reply #3 on: May 07, 2020, 19:30:10 »
While its seems to a great idea, however it should be remembered that NR» (Network Rail - home page) maintenance teams have been impacted by the virus or having to self isolate, the same applies to the contractors, I suspect the ToC's will have had similar issues,
Maintaining the social distancing has meant many tasks which require staff to work closer than 2 metres to each other to be assessed, this has taken time to re asses tasks to be compliant with Covid-19 restrictions and still safe to do, to issue the PPE and guidance on when a how to use it and dispose of.
Don't forget the separation also applies in mess rooms, briefings, welfare facilities (toilets and showers), office, vans
and finally having off the shelf shovel ready projects by which I mean all the designs signed off, tools, equipment, martial, machines, staff etc ready to go
« Reply #4 on: May 18, 2020, 08:39:41 »
From our GWR (Great Western Railway) contact at the end of last week (question had been raised at our liaison meeting a few days earlier)
Hitachi and maintenance of IETs (Intercity Express Train) - There is a great deal of work being completed on the two fleets at the moment and we are working closely with Hitachi to ensure they are using the time as efficiently as possible. We have effectively been cycling the sets between ‘stored units’ and ‘service units’, which enables Hitachi to get as many modifications completed on the units as possible with the materials and resources they have – once a unit is completed it is released and an alternative unit is stopped for modifications.  They have made good progress with modifications, customer facing defects, deep cleans and work is underway on the TMS software update.
Thatcham Crossing
« Reply #5 on: May 18, 2020, 08:56:54 »
......I wonder if they've fixed the issues (with the DOO (Driver-Only Operation (that is, trains which operate without carrying a guard)) cameras) so that IET (Intercity Express Train)'s can be used on the Bedwyn's without a TM(resolve)?
« Reply #6 on: May 18, 2020, 09:37:38 »
We seem to have diverged into IET (Intercity Express Train) thread territory.  For the latest on that see here:
http://www.firstgreatwestern.info/coffeeshop/index.php?topic=18792.msg288518#msg288518
Thatcham Crossing
« Reply #7 on: May 18, 2020, 13:59:39 »
Maybe so, maybe not. I saw this was relevant to the thread title as it is engineering of a sort, and it has been well-documented that the IET fleet has been much more lightly-used during lockdown than in normal times.
Anyway, I don't see any recent update on this in the IET thread so will ask on there.
What I can see locally is that there are no IET's on the Bedwyn's at the moment, presumably as the turbo's which have returned can be run DOO (Driver-Only Operation (that is, trains which operate without carrying a guard)), which I assume is preferable during the current situation.
« Reply #8 on: May 18, 2020, 15:54:13 »
They’re only running to and from Reading so a Turbo is preferable - means they can use P1-3 at Reading.
« Reply #9 on: May 18, 2020, 19:35:58 »
Isn't platform 3 long enough to turn a 5 car train ... Bournemouth Voyagers - or is that a just the shorter carriages.
« Reply #10 on: May 18, 2020, 22:17:54 »
Yes, Platform 3 is long enough for a 5-car Voyager/Turbo (as are Platforms 1 and 2), but at between 120-124 metres none of them are long enough for a 5-car IET (Intercity Express Train) at a nominal 130 metres.  I think one might just fit in behind the signal on Platform 3 as it's a little way off the platform (and, uniquely for Reading, ground mounted), but it doesn't feature in the SDO (Selective Door Opening) system, so use of it would require manual door selection and obviously isn't encouraged.
« Reply #11 on: May 22, 2020, 17:13:19 »
More likely that the pandemic is used as an excuse for missing the deadline. This is WECA» (West of England Combined Authority - about), you know.
« Reply #12 on: May 23, 2020, 16:24:47 »
Now that you say it, it seems so obvious.  Silly me.
