Travel & transport from BBC stories as at 20:55 15 Jan 2025
- Three arrests after boy, 14, killed on London bus
- Trainee gas engineer, 20, wins £7.5m in lottery
 18/01/25 - TLRS AGM, Taunton
15th Jan (2015)
RoSCo Eversholt changes hands (link)
20:50 St Erth to St Ives
21:05 St Ives to St Erth
21:20 St Erth to St Ives
21:37 St Ives to St Erth
22:30 St Erth to St Ives
22:48 St Ives to Penzance
January 15, 2025, 21:12:07 *
[235] Train departed 3 minutes earlier than scheduled
[143] Changing content of the domain home page as the new Coffee Sho...
[36] England's Best Loved Lost Railway: The Somerset & Dorset Joint...
[34] North Cotswold line delays and cancellations - 2025
[30] Eastern Airways to start Southend - Newquay service
[25] Return of the BRUTE?
Author Topic: Keeping vehicles and pedestrians apart [DotD - 31.3.2020]  (Read 1055 times)
« on: March 31, 2020, 07:17:49 »
From my walk through Melksham on Sunday - new railings on the river bridge which will help keep pedestrians and vehicles apart. Been going on for a while - the other side now being done.
To my knowledge, no pedestrians have been hurt by vehicles mounting the pavement ... it has been suggested to me the the footways are weak, and the real concern is that a heavy vehicle on the footway could cause the bridge to collapse.
« Reply #1 on: March 31, 2020, 12:33:52 »
Many bridges of that sort of age would have been widened at some time in the last century, and it was often the case that if a new pedestrian pavement was being added on one or both sides then the underlying arch wouldn’t necessarily need to be as strong as for the vehicle carriageways.  It might be obvious if viewed from underneath?
They may also be worried about the parapet strength with regard to vehicle impact, the new railings will protect against that as well.
« Reply #2 on: March 31, 2020, 14:06:44 »
Not only bridges of that age - this has been done to some of the overbridges on the M4 (built c1969-71), although I think the habit of some who parked on the "pavements" on the bridges to sit and watch the traffic go by did not help.
« Reply #3 on: March 31, 2020, 20:59:10 »
Its a long time since I was involved in bridge design (about 1980) but IIRC (if I recall/remember/read correctly) the carriageway is designed to a full traffic load including an abnormal vehicle, but the worst loading case for a footway was a single accidental HGV wheel load of 113 kN (about 11 tons).
Unless the bridge deck had badly deteriorated I am not sure that a parked car would have much effect, but a parked multi axle HGV might as it could have more than one wheel load acting at once.  I suggest that the barrier is most likely to be to keep HGV's off the footway therefore.
