15:09 Liskeard to Looe
15:41 Looe to Liskeard
16:35 Par to Newquay
17:55 Newquay to Par
10:57 Paignton to Exmouth
12:26 Exmouth to Paignton
April 20, 2025, 03:51:20 *
Author Topic: Disruption between Bristol and Weston super Mare  (Read 3903 times)
« on: January 11, 2020, 08:40:06 »
A ‘late running freight train’ is causing all sorts of issues between Bristol and Weston super Mare and has been since first thing. Surely there’s more to it than just running late. Broken down perhaps or a sensitive cargo (nuclear)?
Due to a late running freight train between Bristol Temple Meads and Weston-Super-Mare the line towards Weston-super-Mare is blocked.
Train services running through these stations may be cancelled, delayed by up to 60 minutes or revised. Disruption is expected until 10:30 11/01.
« Reply #1 on: January 11, 2020, 10:26:16 »
It was a freight from Felixstowe which was stuck on the main line for over three hours waiting to be accepted into Bristol Freightliner yard.
« Reply #2 on: January 11, 2020, 12:06:29 »
Will be interesting to know who pays for the delays and cancellations that it caused.
GBM
« Reply #3 on: January 11, 2020, 15:12:52 »
May you please clarify "waiting to be accepted..."  Surely provided the signal(s) were good to go, the freight could just roll into the yard.  If the signals were against it and it had to wait (over three hours - really?) purely because of the signals, then it's a Network Rail fault.
« Reply #4 on: January 11, 2020, 15:13:17 »
This incident was initially attributed as "waiting for terminal/yard acceptance (AA)", applying to all the delayed and cancelled passenger services.
In the DAPR (Delay Attribution Principles and Rules), the list of codes has AA (Waiting Terminal/Yard acceptance) under freight terminal operating company causes". In section 4.2, explaining such incidents (Acceptance into Freight Terminals/Yards) in more detail, it has:
Circumstances: Incident within a yard/terminal, off Network Rail operated infrastructure, causing trains to be delayed entering into either that yard/terminal or an adjacent yard/terminal sharing the same connection to the Network.
Delay Code:  Appropriate A*, F* or M* Code
Incident Attribution:  Freight Operator(s) - separate Incident for each Operator involved (A##*)
Circumstances: Freight Operator of train waiting outside terminal/yard does not provide information on incident in terminal/yard
Delay Code:  AA
Incident Attribution:  Operator of train concerned
(I presume that by Freight Operator is means terminal operator.)
In any case, the contracts linking the train and terminal operators will cover who ultimately pays for it.
Celestial
« Reply #5 on: January 11, 2020, 15:17:24 »
I thought I read some months ago that the Bristol Freighliner yard had closed, and it's traffic rerouted to Pengam, which was more viable since the toll was removed on the bridge.
« Reply #6 on: January 11, 2020, 15:20:32 »
It means going off NR» (Network Rail - home page)'s network onto someone else's. That move can only happen (and only be signalled) after it is accepted by the operator of the other "network" - even if it's just a bit of track.
« Reply #7 on: January 11, 2020, 15:25:32 »
There were several movements last week - not every day, but at weekends in particular, and including to/from Felixstowe.
