« Reply #120 on: May 20, 2020, 10:53:40 » |
Will be some lengthy delays. Two IETs▸ (one in each direction) have struck the cows. One train has a broken windscreen, the other is blocking Wootton Bassett Junction.
« Reply #121 on: May 20, 2020, 11:45:15 » |
12:16 Westbury to Swindon due 13:01
12:16 Westbury to Swindon due 13:01 will be cancelled.
This is due to animals on the railway. 13:14 Swindon to Westbury due 13:55
13:14 Swindon to Westbury due 13:55 will be cancelled.
« Reply #122 on: May 20, 2020, 13:27:30 » |
14:16 Westbury to Swindon due 15:01 will be terminated at Chippenham.
It will no longer call at Swindon.
This is due to animals on the railway. Unit will then be used to provide a shuttle between Chippenham and Bath Spa. 15:14 Swindon to Westbury due 15:55
15:14 Swindon to Westbury due 15:55 will be cancelled.
This is due to animals on the railway. 16:25 Westbury to Swindon due 17:08
16:25 Westbury to Swindon due 17:08 will be cancelled.
« Reply #123 on: May 20, 2020, 14:20:08 » |
But then back down to Westbury on the evening 'peak' service. 17:36 Swindon to Westbury due 18:17 17:36 Swindon to Westbury due 18:17 will be started from Chippenham. It will no longer call at Swindon. It will be delayed at Chippenham and is expected to be 9 minutes late. This is due to animals on the railway.
I hope the late start is to let the bus from Swindon arrive, but I fear it's to let the train from Bath arrive. Through train, Bath to Melksham ... now there's a novel idea
« Reply #124 on: May 20, 2020, 16:29:21 » |
18:39 Westbury to Swindon due 19:21
18:39 Westbury to Swindon due 19:21 will be terminated at Chippenham.
This is due to animals on the railway earlier today. 20:45 Swindon to Westbury due 21:26
20:45 Swindon to Westbury due 21:26 will be started from Chippenham.
« Reply #125 on: June 12, 2020, 15:19:22 » |
15:14 Swindon to Westbury due 15:55 15:14 Swindon to Westbury due 15:55 will be diverted between Chippenham and Trowbridge. It will no longer call at Melksham. It will be delayed due to the diversion and is expected to be 7 minutes late. This is due to a fault with the signalling system.
« Reply #126 on: June 12, 2020, 16:50:49 » |
16:25 Westbury to Swindon due 17:08 16:25 Westbury to Swindon due 17:08 will be diverted between Trowbridge and Chippenham. It will no longer call at Melksham. It will be delayed due to the diversion and is expected to be 10 minutes late. This is due to a fault with the signalling system.
« Reply #127 on: June 12, 2020, 17:54:06 » |
17:36 Swindon to Westbury due 18:17 will be diverted between Chippenham and Trowbridge. It will no longer call at Melksham. It will be delayed due to the diversion and is expected to be 7 minutes late. This is due to a fault with the signalling system.
« Reply #128 on: June 12, 2020, 19:08:07 » |
18:39 Westbury to Swindon due 19:21 18:39 Westbury to Swindon due 19:21 will be diverted between Trowbridge and Chippenham. It will no longer call at Melksham. It will be delayed due to the diversion and is expected to be 10 minutes late. This is due to a fault with the signalling system. Further Information
Reginald25
« Reply #129 on: June 12, 2020, 19:12:12 » |
As the Melksham route is clearly not in use and trains diverting via Bathampton and BOA, was a bus service laid on automatically without request. And more generally, when more passengers start using the train, would a bustitution service be able to accomodate everyone with the required social distancing?
« Reply #130 on: June 16, 2020, 17:11:10 » |
16:25 Westbury to Swindon due 17:08 16:25 Westbury to Swindon due 17:08 has been delayed between Melksham and Chippenham and is now 10 minutes late. This is due to congestion. No problem ... not due back out until 17:36.
« Reply #131 on: June 17, 2020, 16:40:46 » |
Same train, different day 16:25 Westbury to Swindon due 17:08
16:25 Westbury to Swindon due 17:08 is being delayed at Westbury. This is due to a broken down train. Was held at Westbury for 10 minutes to let the 14:15 diverted service from Plymouth to go in front to avoid a broken down freight train at Bedwyn. It called at Westbury and will call at Swindon so anyone making an end to end journey could have caught it and not been inconvenienced.
« Reply #132 on: June 19, 2020, 05:35:37 » |
05:17 Westbury to Swindon due 05:59 05:17 Westbury to Swindon due 05:59 is being delayed at Westbury. This is due to a fault on this train.
« Reply #133 on: June 19, 2020, 06:01:18 » |
Now running but 16 minutes late.
« Reply #134 on: June 19, 2020, 15:20:25 » |
16:25 Westbury to Swindon due 17:08 16:25 Westbury to Swindon due 17:08 will be cancelled. This is due to failure of the electricity supply earlier today. Further Information 17:36 Swindon to Westbury due 18:17 17:36 Swindon to Westbury due 18:17 will be cancelled. This is due to failure of the electricity supply earlier today. Err ... diesel train ?
