Travel & transport from BBC stories as at 21:35 17 Apr 2025
- Travellers warned to expect Tenerife hotel protests
- Watch: BBC joins retirees aboard China's 'silver trains' that aim to boost economy
17th Apr (2010)
20:28 Paignton to Exmouth
20:55 Paignton to Exmouth
21:56 Exmouth to Exeter St Davids
23:21 Swindon to Gloucester
April 17, 2025, 21:46:42 *
[318] Fifteen years of the Transwilts CRP
[96] Spreading wings for a few days
[59] 2025 - Service update and amendment log, Swindon <-> Westbury...
[43] St Erth station - facilities, footbridge, improvements, incide...
[38] Oxford station - facilities, improvements, parking, incidents ...
[37] Too young to travel on that ticket?
Linked Events
  • Steam across Wilts & Somerset: April 17, 2008
Pages: [1] 2 3 ... 11
Author Topic: Steam engine 34067 'Tangmere' - merged posts  (Read 106337 times)
Phil
« on: March 30, 2008, 12:13:48 »
For those of you of a nostalgic bent  - West Country class 34067 Tangmere is due to arrive in Salisbury from  Waterloo at 12.30 on 17th April. Due to arrive Westbury at around 13:20 (after taking on water), Bath at 1400ish and Bristol 1430ish.
Scheduled to leave Bristol Temple Meads station at 1733 picking up from Bath at 1750hrs. Back to Salisbury at around 1915hrs then on to Waterloo again.
« Reply #1 on: March 27, 2015, 14:23:58 »
RAIB (Rail Accident Investigation Branch) reports
RAIB is investigating an incident that occurred at 17:25 hrs on Saturday 7 March 2015, in which train reporting number 1Z67, the 16:35 hrs service from Bristol Temple Meads to Southend, passed a signal at danger on the approach to Wootton Bassett junction, Wiltshire. The train subsequently came to a stand across the junction. The signal was being maintained at danger in order to protect the movement of a previous train. However, at the time that the SPAD (Signal Passed At Danger - very bad!) occurred, this previous train had already passed through the junction and was continuing on its journey. No injuries, damage or derailment occurred as a result of the SPAD.
Wootton Bassett junction is situated between Chippenham and Swindon stations on the Great Western main line and is the point at which the line from Bristol, via Bath, converges with the line from South Wales. It is a double track high speed junction which also features low speed crossovers between the up and down main lines (see figure below for detail).
The junction is protected from trains approaching on the up main from Chippenham by signal number SN45, which is equipped with both the Automatic Warning System (AWS (Automatic Warning System - an arrangement of permanent magnets and electro-magnets that convey information about the associated signal to the train driver)) and the Train Protection and Warning System (TPWS (Train Protection and Warning System)). This signal is preceded on the up main by signal SN43, which is also equipped with AWS and TPWS. The maximum permitted line speed for trains approaching the junction from this direction is normally 125 mph. However, on 7 March, a temporary speed restriction (TSR (Temporary Speed Restriction)) of 85 mph was in place on the approach to signal SN45. A temporary AWS magnet had been placed on the approach to signal SN43 to warn drivers of this TSR.
The train which passed signal SN45 at danger consisted of steam locomotive number 34067 ^Tangmere^, and its tender, coupled to 13 coaches. The locomotive is equipped with AWS and TPWS equipment.
The RAIB^s preliminary examination has shown that, at around 17:24 hrs, train 1Z67 was approaching signal SN43 at 59 mph, when it passed over the temporary AWS magnet associated with the TSR. This created both an audible and visual warning in the locomotive^s cab. However, as the driver did not acknowledge this warning within 2.7 seconds, the AWS system on the locomotive automatically applied the train^s brakes. This brake application should have resulted in the train being brought to a stand. In these circumstances, the railway rule book requires that the driver immediately contact the signaller.
The RAIB has found evidence that the driver of 1Z67 did not bring the train to a stand and contact the signaller after experiencing this brake application. Evidence shows that the driver and fireman instead took an action which cancelled the effect of the AWS braking demand after a short period and a reduction in train speed of only around 8 mph. The action taken also had the effect of making subsequent AWS or TPWS brake demands ineffective.
Shortly after passing the AWS magnet for the TSR, the train passed signal SN43, which was at caution. Although the AWS warning associated with this signal was acknowledged by the driver, the speed of the train was not then reduced appropriately on the approach to the next signal, SN45, which was at danger. Because of the earlier actions of the driver and fireman, the TPWS equipment associated with signal SN45 was unable to control the speed of the train on approach to this signal.
As train 1Z67 approached signal SN45, the driver saw that it was at danger and fully applied the train^s brakes. However, by this point there was insufficient distance remaining to bring the train to a stand before it reached the junction beyond SN45. The train subsequently stopped, standing on both the crossovers and the up and down Badminton lines, at around 17:26 hrs. The signalling system had already set the points at the junction in anticipation of the later movement of 1Z67 across it; this meant that no damage was sustained to either the train or the infrastructure as a result of the SPAD.
The RAIB has found no evidence of any malfunction of the signalling, AWS or TPWS equipment involved in the incident.
The RAIB^s investigation will consider the factors that contributed to signal SN45 being passed at danger, including the position of the temporary AWS magnet associated with the TSR. The investigation will also examine the factors that influenced the actions of the train crew, the adequacy of the safety systems installed on the locomotive and the safety management arrangements.
Wootton Bassett
Wootton Bassett junction in 2012 - the lines shown from left to right are the Up Goods, Up Badminton, Down Badminton, Up Main and Down Main (image courtesy of Network Rail)
Wootton Bassett diagram
A diagram of the layout of Wootton Bassett junction - note that some features have been omitted for clarity (not to scale)
« Last Edit: March 27, 2015, 14:35:37 by bignosemac » Logged
« Reply #2 on: March 27, 2015, 14:45:29 »
I was initially confused when I saw the email alert summary for this investigation in my inbox. A direct service from Bristol TM (Train Manager, or possibly Ticket Machine, depending on context) to Southend? Only on reading further and remembering being told about it on the day did I realise it was a railtour.
« Reply #3 on: March 27, 2015, 14:47:14 »
It's unbelievable that crews still take chances with AWS (Automatic Warning System - an arrangement of permanent magnets and electro-magnets that convey information about the associated signal to the train driver)/TPWS (Train Protection and Warning System), but sadly some still do.
patch38
« Reply #4 on: March 27, 2015, 14:50:07 »
What is the procedure for a SPAD (Signal Passed At Danger - very bad!) under those circumstances? Is the driver immediately relieved from duty? If that's the case, where do you find a mainline-qualified steam driver at short notice?  Shocked
« Reply #5 on: March 27, 2015, 15:17:51 »
Don't these long distance steam railtours usually run with a relief crew? There always seem to be a lot of boiler suited folk around the engine when I see them at Bristol TM (Train Manager, or possibly Ticket Machine, depending on context).
« Reply #6 on: March 27, 2015, 16:48:00 »
I was confused further by reports of the fireman. Then the penny dropped!
« Reply #7 on: March 27, 2015, 16:52:07 »
I  thought that there was usually a Motive Power Inspector (or modern equivalent) on the foootplate but there is no reference to one in the report.
Most of the boiler suited people refered to by BNM are support staff to coal and water the loco not spare drivers.
« Reply #8 on: March 27, 2015, 22:44:59 »
From memory the train was held just outside Swindon station for about 10 minutes before continuing.  I only know because I could see the steam over the tops of the houses before hearing the train whistle and seeing the steam move along.  So if a relief crew did take over they were found in pretty short order, so likely to have been on the train.
« Reply #9 on: March 27, 2015, 23:20:35 »
I suppose for a relatively long journey such as Southend to Bristol and return, along with a loco change each way at Southall, it's quite possible there were two each of driver, fireman and guard booked anyway. Nearly 5  hours each way, plus those loco changes*, is a lot for one crew to do in a day.
*61306 LNER» (London North Eastern Railway - about) Thompson Class B1 'Mayflower' Southend-Southall-Southend.
34067 SR (Southern Railway / Southern Region / Scot Rail / Scottish Region (rather confusing - it depends on the context)) Battle of Britain Class 'Tangmere' Southall-Bristol-Southall.
« Reply #10 on: March 27, 2015, 23:45:58 »
... I could see the steam over the tops of the houses before hearing the train whistle and seeing the steam move along.
You can't see steam: what you see is water vapour.  Tongue Roll Eyes Grin
« Reply #11 on: March 27, 2015, 23:52:26 »
Or was it smoke!  Grin
« Reply #12 on: March 28, 2015, 00:01:53 »
Much more likely!  Wink Cheesy Grin
Alan Pettitt
« Reply #13 on: March 28, 2015, 15:59:49 »
I doubt that you can see water vapour either, one of its properties being that it is invisible to the naked eye, however it does become visible when it condenses into clouds of liquid droplets, commonly called steam (although, as already noticed this is a misnomer).
Cynthia
« Reply #14 on: March 29, 2015, 13:38:33 »
A little item that may be of interest to the other steam buffs on this Forum:
From Newbury Weekly News 19th March:
"Train buffs are chuffed - the steam train season has started.
Hungerford Camera Club member and steam fan Tony Bartlett said: "The first train of the year came through Newbury* and I was on Hungerford Common to get a shot of regular locomotive 'Tangmere' at the head of affairs."
Mr. Bartlett also snapped 'Mayflower' as it passed the common.
Built for the London and North Eastern Railway, 61306 Mayflower is one of two surviving B1 class locomotives, designed as mixed traffic locomotives capable of hauling express passenger trains as well as freight traffic.
Mayflower has two cylinders, six driving wheels, a firebox grate area of 30 sq ft and can operate at 75mph."
*Unfortunately the article doesn't say WHEN the engine came through Newbury.  Luckily it was a pre-April Fools' Day issue, or I might have been tempted to wonder whether they were extracting the Michael with a mid-sixties item!  There was a nice little photograph of the Mayflower accompanying the article, unfortunately when I went onto the NWN website this morning I couldn't find it.  Sorry folks.
Trying to break ones addiction to car travel is much harder than giving up ciggies!
