No recent travel & transport from BBC stories as at 08:55 27 Apr 2025
08:44 London Paddington to Great Malvern
08:58 Great Malvern to London Paddington
09:15 Bristol Temple Meads to Weston-Super-Mare
10:10 Weston-Super-Mare to Severn Beach
13:11 Worcester Foregate Street to London Paddington
13:30 Bristol Temple Meads to Westbury
14:35 Severn Beach to Weston-Super-Mare
14:40 Westbury to Bristol Temple Meads
21:00 Bristol Temple Meads to Avonmouth
21:28 Avonmouth to Bristol Temple Meads
22:06 Portsmouth Harbour to Westbury
08:00 Bristol Temple Meads to Penzance
10:54 Exmouth to Paignton
11:35 Severn Beach to Weston-Super-Mare
12:53 Paignton to Exmouth
14:07 London Paddington to Cardiff Central
14:10 Portsmouth Harbour to Cardiff Central
14:50 Penzance to Exeter St Davids
15:10 Weston-Super-Mare to Severn Beach
16:08 Weston-Super-Mare to Severn Beach
16:10 Portsmouth Harbour to Cardiff Central
16:48 Bristol Temple Meads to Castle Cary
19:10 Portsmouth Harbour to Cardiff Central
An additional train service has been planned to operate as shown 09:25 Exeter St Davids to Penzance
09:55 Bristol Temple Meads to Penzance
April 27, 2025, 09:10:00 *
[100] Penryn to Melksham - summary and some pictures from 25.4.2025
[90] Standardisation of Time and the Railway Clearing House
[56] Solar power between the lines
[50] Intoxicated person plan needed on Tube - coroner, April 2025
[49] Weymouth - station, facilities, improvements, events and incid...
Author Topic: Crew shortages - Thames Valley Branches  (Read 8089 times)
« on: October 31, 2019, 08:18:10 »
Just a co-incidence that two branches are loosing service today?  Or is there a background cause such as preparations for December 15th when TfL» (Transport for London - about) take over many services and GWR (Great Western Railway) will require less drivers?
08:39 Windsor & Eton Central to Slough due 08:45
08:39 Windsor & Eton Central to Slough due 08:45 will be cancelled.
08:42 Greenford to West Ealing due 08:53
08:42 Greenford to West Ealing due 08:53 will be cancelled.
« Reply #1 on: October 31, 2019, 17:37:45 »
Maidenhead - Marlow virtually wiped out
« Reply #2 on: October 31, 2019, 23:16:43 »
Only Henley running properly then!
« Reply #3 on: November 01, 2019, 18:31:43 »
The train crew travel by passenger service from Reading booing on point so if the TV (Thames Valley) service between Reading and Pad has problem then the crew straggle also they might get reassigned.  The other issue with the Marlow branch is the second unit in the peaks which runs ECS (Empty Coaching Stock) from Reading Depot which means it can get cancelled if there are problems on the Reliefs
« Reply #4 on: November 01, 2019, 20:48:57 »
Surely if there are problems between Reading & Paddington someone has sufficient common sense to put the crew in a taxi?  Roll Eyes
« Reply #5 on: November 01, 2019, 22:56:35 »
If that’s the best option they would, yes.  Waiting for the next train 15 minutes later would usually be a far quicker option in the case of Reading to Maidenhead.
« Reply #6 on: November 02, 2019, 07:26:04 »
There were multiple cancellations between Reading and Paddington due to crew shortages. The fact that the Marlow services were wiped out would suggest that common sense did not prevail.
« Reply #7 on: November 02, 2019, 10:36:35 »
To me it suggests the decision was taken to sacrifice the Marlow branch to run more services on the main line, or 'reassigned' as Electric Train put it.  If you're short on drivers, is it more sensible to provide more driver only main line trains than cover a branch line which is more easily and effectively replaced by road transport?
« Reply #8 on: November 02, 2019, 18:38:40 »
Take great care not to twist your ankle in the holes you leave when you move the goalposts  Wink
« Reply #9 on: November 02, 2019, 23:29:12 »
Eh?
