No recent travel & transport from BBC stories as at 09:55 10 Jan 2025
08:36 Redhill to Reading
10:38 Bristol Temple Meads to Worcester Foregate Street
January 10, 2025, 10:07:13 *
[79] Ryanair sues 'unruly' passenger over flight diversion
[69] Thumpers for Dummies
[56] Westminster Hall debate : Railway services to South West
[52] Railcard Prices going up
[44] Mick Lynch announces retirement as head of RMT
Author Topic: Bodmin/Liskeard disruption  (Read 6030 times)
GBM
« on: October 26, 2019, 08:29:42 »
From Journeycheck
Cancellations to services between Bodmin Parkway and Liskeard
Due to a fault with the signalling system between Bodmin Parkway and Liskeard the line towards Plymouth is closed.
Train services running through these stations may be cancelled or delayed. Disruption is expected until 09:00 26/10.
I thought these were manual boxes, and as such, almost impervious to weather related disruption.
No electronics, etc.
GBM
« Reply #1 on: October 26, 2019, 09:02:05 »
Train services running through these stations may be cancelled, delayed by up to 30 minutes or revised. Disruption is expected until 12:00 26/10.
« Reply #2 on: October 26, 2019, 09:18:41 »
Due to a track circuit failure.  Even old mechanical boxes often use track circuits.
« Reply #3 on: October 26, 2019, 09:28:03 »
The line between Lostwithiel and Liskeard, through Bodmin Parkway, is Track Circuit Block controlled by Solid State Interlocking (SSI (Solid State Interlocking)) with some track circuits, but mostly axle counters.  The control panel (NX type) is located in Par Signalbox.
« Last Edit: October 26, 2019, 10:11:28 by SandTEngineer » Logged
GBM
« Reply #4 on: October 26, 2019, 09:32:07 »
Thank you both for your replies, much appreciated.
Zoe
« Reply #5 on: October 26, 2019, 19:45:39 »
Isn't it just the interlocking that is located at Par, with control from an NX panel in Lostwithiel or has this now been moved?
« Reply #6 on: October 26, 2019, 20:33:34 »
Whoops.  To the naughty corner.  Your'e correct of course.  I was getting confused because its a new panel installed earlier this year.  I should know better....... Roll Eyes
GBM
« Reply #7 on: October 27, 2019, 10:26:48 »
As I'm elderly and now confused!
Lostwithiel has a remote control unit (situated at Par).  If NR» (Network Rail - home page) are trying to centralise everything, why not control Lostwithiel from Par?
rogerw
« Reply #8 on: October 27, 2019, 12:10:50 »
Manual signals ans points at Lostwithiel
Zoe
« Reply #9 on: October 27, 2019, 13:52:37 »
Lostwithiel signal box controls the signals in the station area with levers and also the down Intermediate Block Signal at Treverrin via a switch on the block shelf.  There is also a panel in the box which controls the single line at Largin (Lostwithiel took this over when Largin box closed in 1991) plus some new signals recently installed in the Bodmin Parkway area.  The panel communicates with the interlocking (at Par) which in turn communicates with the points and signals (it's a bit more complicated than that but I don't want to start getting too technical on here).
