No recent travel & transport from BBC stories as at 12:15 10 Jan 2025
January 10, 2025, 12:29:14 *
[141] Ryanair sues 'unruly' passenger over flight diversion
[83] Mick Lynch announces retirement as head of RMT
[66] Westminster Hall debate : Railway services to South West
[32] A Beginner's Guide to the Great Western "Coffee Shop" Passenge...
[31] Thumpers for Dummies
[23] Bristol Rail Campaign AGM 2025
Author Topic: A bit slow off the mark  (Read 8067 times)
Moderator
« on: October 03, 2019, 10:20:16 »
Cycling UK (United Kingdom) have finally discovered GWR (Great Western Railway) (and LNER» (London North Eastern Railway - about)) bicycle provision:
https://road.cc/content/news/267162-cycling-uk-slams-awful-cycle-storage-gwrs-high-speed-trains
« Reply #1 on: October 03, 2019, 10:56:43 »
Sigh. I should dig back through my old email to find the date when I emailed Cycling UK (United Kingdom) to warn that this was coming and to suggest they might want to do some lobbying. Bit late now all the trains have been built...
« Reply #2 on: October 03, 2019, 13:06:16 »
There was a consultation with CUK and other cycling groups before the trains were delivered. Feedback was given and, I think, listened to, but the whole thing was done too late to change anything other than minor details. I'm not sure if the consultation was specifically for GWR (Great Western Railway) though – more likely it was by/for Hitachi – I know someone who was involved and she doesn't live in GWR-land (or LNER» (London North Eastern Railway - about)).
The fundamental problem is the use of hooks. It's space efficient in theory as it allows n bike spaces in less floor space, but in practice many people and many bikes can't use it: the people are not tall enough or strong enough, the bikes are too heavy or too long or too wide, and the spaces are not accessible independently of each other. And the whole business of lifting a bike onto a hook above head height on a moving, swaying train; at some point someone is going to drop a bike while doing this and injure themselves or, worse, someone else.
« Reply #3 on: October 03, 2019, 14:01:11 »
The specification required a space able to accommodate two of these: 'Full size ‘road’ bicycle with 25inch frame'.  Presumably it does that, even if it can't fit mountain bikes, hybrid bikes, bikes with extra fat tyres or big handlebars etc, or easy access maybe. The question then is why the DfT» (Department for Transport - about) were so specific about the type of bike.
« Reply #4 on: October 03, 2019, 15:44:13 »
I think you're suggesting the requirement should have been more specific, not less. That bicycle is one of four items listed as "largest of" its type - because the total size allowed is an important factor in overall train sdesign. But this kind of specification can never be exhaustive, or it turns into an interminable list of things and people spend all their time arguing about what's been left out. Really, it is for the recipient of the specification (Hitachi) to add the requisite common sense in interpreting the general requirement, which is:
TS1265 IEP (Intercity Express Program / Project.) Vehicles must incorporate a range of luggage stowage solutions. Each solution must ensure that the luggage is securely and safely stowed. The solution design must facilitate the ease of loading and unloading the luggage for the User Population.
If the user population has a reasonable need to bring and stow other types of bicycle, nothing in the specification can be interpreted as saying this should not be provided.
« Reply #5 on: October 03, 2019, 17:02:02 »
'Full size ‘road’ bicycle with 25inch frame' is both specific and unspecific. It implies drop bars but doesn't specify their width. It doesn't specify how the frame size is to be measured. It doesn't take account of the length of the bicycle, which is only loosely correlated with frame size. It doesn't specify tyre size. All these things can and do vary widely while still being a 'full size ‘road’ bicycle with 25inch frame'. It does rule out hybrids and mountain bikes, which tend to have wider bars and fatter tyres than 'road bikes', recumbents, which are almost always much longer, tandems ditto, and tricycles, which obviously are significantly wider.
« Reply #6 on: October 03, 2019, 17:52:13 »
My point was about specifications, and their underlying logic, not bicycles. If the requirement says "the subsystem shall work with X" you can't infer "the subsystem shall not work with anything other than X". Common sense has to be applied, especially in areas where the real requirement comes from messy things like the travelling public and has only been represented by examples.
The first technical director I knew had a catchphrase he'd often use when you presented the result of a project, explaining how it worked and would meed the requirements. He'd ask pointed technical questions, and end up with "but does it work?". There are always real-world requirements no-one has written down, but customers notice if you ignore.
« Reply #7 on: October 03, 2019, 20:53:08 »
It seems the cycle cupboards have been designed to fit the bikes in the specification with a passenger of at least average strength and height and not a huge amount else. Does that mean the brief was too specific (in determining too tightly the types of object) or not specific enough (because it should have "these objects and a whole lot of other stuff we don't have the space to list")? Whichever way you look at it, I suspect the overall lack of space to make the cupboards bigger was the constraining factor.
Moderator
« Reply #8 on: October 04, 2019, 07:05:36 »
Must admit that I tend to agree with comments on the Cycling UK (United Kingdom) site, that it was probably designed by somebody who doesn't use a bike; much as a lot of the road infrastructure for bikes.
One possible solution that works on Cross Country trains, put you cycle lock (locked) through the front wheel and use that to engage the hook on the train.
« Reply #9 on: October 04, 2019, 16:03:09 »
I can't see how that would work. Surely the as soon as you lift the bike up, the weight of the lock will cause the wheel to rotate so the lock as at the lowest point of the wheel?
Moderator
« Reply #10 on: October 05, 2019, 19:19:57 »
Brakes? Seen it done with a fat-tyred bike on Cross Country. Shouldn't be needed, but at least somebody was willing to try and use an inadequate system.
« Reply #11 on: October 26, 2019, 14:33:01 »
An LNER» (London North Eastern Railway - about) spokesperson said: “We gather feedback from customers with bikes and cycling organisations to help us understand how we can make potential improvements.
“We have also been working with Hitachi Rail and the [UK (United Kingdom)] Department for Transport to identify where modifications can be made to cycle storage.”
https://road.cc/content/news/268059-lner-rethink-dangerous-bike-storage-new-trains
