« on: July 11, 2019, 07:54:23 » |
As at 07:53 this morning
Due to a speed restriction over defective track between Slough and Windsor & Eton Central fewer trains are able to run. Impact: Train services running to and from these stations may be cancelled. Disruption is expected until the end of the day. Customer Advice: The trains that leave Slough at 30 minutes past the hour and Windsor at 39 minutes past the hour, will be cancelled. Please note that there are no toilet facilities on this service.
« Reply #1 on: July 11, 2019, 09:34:18 » |
Due to a speed restriction over defective track between Slough and Windsor & Eton Central fewer trains are able to run. Impact: Train services running to and from these stations may be cancelled. Disruption is expected until the end of the day. Customer Advice: The trains that leave Slough at 30 minutes past the hour and Windsor at 39 minutes past the hour, will be cancelled. Please note that there are no toilet facilities on this service. If I recall rightly the track defect was on the down main on Monday with a 5mph speed limit over the affected section. Is this a new disease which is contagious and has now spread to the Slough to Windsor single line whilst the down main has recovered following successful treatment over Tuesday night.
« Reply #2 on: July 11, 2019, 09:38:29 » |
The repair work on the Down Main has removed the points accessing the branch line. So the unit on the Windsor shuttle is currently trapped on the branch with no access to a depot for refuelling or water.
« Reply #3 on: July 11, 2019, 10:41:40 » |
I saw this morning that the crossing casting has been removed and plain-lined for the Down Main
« Reply #4 on: July 11, 2019, 11:25:44 » |
Suggestion elsewhere that it might be there for a few weeks, refuelled at the permanent way access point "on the curve". I wonder how long that unit has to go to an exam?
Ralph Ayres
« Reply #5 on: July 11, 2019, 15:11:45 » |
Presumably the reduction to an hourly service is to save fuel rather than due to a lack of time to make 2 trips per hour. The train normally only uses the points at the start and end of the day so there's effectively no change at other times.
« Reply #6 on: July 11, 2019, 16:35:07 » |
Normally a 20 minute service so quite a reduction.
« Reply #7 on: July 11, 2019, 16:56:22 » |
As I read it, the service is reduced by one service an hour and not to one service an hour. Gaps of 20 minutes and 40 minutes.
« Reply #8 on: July 11, 2019, 16:59:34 » |
I would also imagine with GWR▸ 'knowing' how long it will be there, that it will not be racking up too many miles towards its next examination/service. That, I imagine, would halt the service completely.
« Reply #9 on: July 11, 2019, 17:35:33 » |
Maybe not the best situation in the middle of the tourist season.
Anyway if I have to go to Windsor for work it will obviously easier to cycle from Slough.
« Reply #10 on: July 15, 2019, 10:55:42 » |
I understand unit refuelled successfully Friday night. No mention of Loo emptying!
Part ordered for point estimated completion 12th August.
GWR▸ have re-timed Windsor's. Every 30 minutes is quite good because there is now a 2 minute cross platform connection half hourly fast from Pad (Oxford and Cotswold line).
Every 20 minutes doesn't fit so there is wait at Slough off two trains.
Coming back is not so good as there is a 15 minute wait at Slough.
« Reply #11 on: July 15, 2019, 10:58:57 » |
I should imagine the toilets will be locked out of use as the trip is only five minutes anyway! The 30-minute interval service is the sensible thing to do - let's hope the train doesn't suffer any kind of failure!
« Reply #12 on: August 17, 2019, 07:53:22 » |
Looks like the unit trapped on the branch might be freed soon. The main lines through Slough are closed for part of Sunday to presumably allow the points to be re-instated. Then early on Monday morning there is a path to get the unit "home" - http://www.realtimetrains.co.uk/train/C24066/2019/08/19/advanced
« Reply #13 on: August 18, 2019, 07:44:12 » |
Summer staycation for the unit?
