Travel & transport from BBC stories as at 17:35 11 Jan 2025
- Germany says Russian 'shadow' ship stuck in Baltic Sea
- Gritters blocked in by '200 cars' in Peak District
 14/01/25 - Rail Sale starts
11th Jan (2012)
17:20 Guildford to Reading
17:38 Weymouth to Frome
19:19 Frome to Weymouth
14:48 London Paddington to Carmarthen
January 11, 2025, 17:45:21 *
[95] one pound flat rate bus fares in Devon and Torbay area.
[54] Mick Lynch announces retirement as head of RMT
[46] Rail passengers face another difficult year, warn MPs
[41] Millions of train tickets to be discounted next week
[40] Thames Valley infrastructure problems causing disruption elsew...
[36] Westminster Hall debate : Railway services to South West
Pages: 1 ... 3 4 [5]
Author Topic: Two rail workers killed in collision with train, near Port Talbot - Wed 3 July 2019  (Read 36030 times)
« Reply #60 on: November 12, 2020, 11:42:15 »
The RAIB (Rail Accident Investigation Branch) published its report on this today here.
"The accident occurred because the three track workers were working on a line that was open to traffic, without the presence of formally appointed lookouts to warn them of approaching trains. They were carrying out a maintenance activity which they did not know to be unnecessary. All three workers were almost certainly wearing ear defenders, because one of them was using a noisy power tool, and all had become focused on the task they were undertaking. None of them was aware that the train was approaching until it was too late for them to move to a position of safety. Subsequent acoustic measurements have shown that they would not have been able to hear the train?s warning horn.
"The system of work that the controller of site safety had proposed to implement before the work began was not adopted, and the alternative arrangements became progressively less safe as the work proceeded that morning and created conditions that made an accident much more likely."
« Reply #61 on: November 12, 2020, 23:04:55 »
A quote from the recommendations of the report with potentially far reaching consequences:
10 The intent of this recommendation is to explore ways of reducing the risk
to staff who work on or near the track by creating more opportunity for
safe access to the track when trains are not running.
Network Rail, in consultation with the Department for Transport, relevant
transport authorities, ORR» (Office of Rail and Road formerly Office of Rail Regulation - about) and other railway stakeholders, should
investigate ways of optimising the balance between the need to operate
train services and the need to enable safe access to the track for routine
maintenance tasks. Options for consideration should include:
a) the provision of gaps in the train service, during daylight off-peak
hours, to enable timely and safe access for maintenance staff
b) greater use of alternative routes or bidirectional lines to achieve the
above
c) increased availability and utilisation of weekend and night time
possessions for cyclical maintenance tasks.
Any reasonably practicable measures that are identified should then be
implemented in accordance with a timebound plan (paragraph 359b).
MVR S&T
« Reply #62 on: November 12, 2020, 23:26:11 »
Should and must have different meanings in this context. there are no musts in this quote, so only a sugestion to change anything.
« Reply #63 on: November 12, 2020, 23:38:41 »
Hence potentially
« Reply #64 on: November 13, 2020, 18:32:23 »
above
There is a big drive to do more work on nights, however there are knock on effects, some are.
There has been an increase in slip, trip, fall injuries to staff due to night work (apparently is dark at night ....... who knew!! )
Less staff available during to day to react to faults and failures
Increased complaints from lineside neighbours due to noise and light pollution from the work lights
Passengers may see a reduction in late night services
« Reply #65 on: February 13, 2021, 11:49:04 »
On electrified routes, it should be possible to provide night time work lighting affixed to the OHLE gantries. A permanent installation but only turned on when needed. This would greatly reduce the risk of trips and falls.
In extreme weather it might be worth turning on the lights in order that the infrastructure and surroundings may be kept under close observation.
« Reply #66 on: February 13, 2021, 17:23:10 »
Whilst it sounds like a good idea there are a number of issues.
OLE (Overhead Line Equipment, more often "OHLE") structures on the GW (Great Western) am 100 metres apart, therefore quite powerful lighting would be required, this could be hazardous to train drivers on adjacent open lines.
The OLE structures are not high enough with the 100 metre spacing and would cause shadows in the middle area which would increase the slips trips and fall hazards
Where fixed light has been installed at junctions, even with correct direction of the light fittings and shielding complaints from lineside neighbours due to the light pollution almost renders them useless.
The maintenance of the lights is problematical.
The reason I am sceptical .................. it has already been tried on the West Coast Mainline at a number of junctions and was remove quite quickly because of the issues above and few more.
With battery and LED technology we have today site lighting is easier to deal with.
Most staff slip trips and falls are actually getting in and out of the van or off loading the vans and walking down access stairs and paths to the line side
« Reply #67 on: February 13, 2021, 18:52:08 »
From my experience as a passenger passing works for nearly two decades - aren't the works at night usually lit by temporary site lighting at a low level that seems to illuminate track works quite well?
« Reply #68 on: February 13, 2021, 22:18:49 »
Lighting will need a voltage significantly below 50/25kV. This will require a step down power supply which essentially means an additional low voltage power supply in parallel with the traction power.  This would be an additional cost with the only offset being that it could presumably be supported on the OLE (Overhead Line Equipment, more often "OHLE") infrastructure. The cost would therefore be significant.  Far better to take power from the 650V signalling power supply where that is present.
« Reply #69 on: February 14, 2021, 07:44:16 »
The portable / mobile lighting provides both task lighting (200 Lux plus) and general illumination 10 / 20 Lux).  The one thing that fixed lighting on columns cannot provide easily in task lighting portable / mobile is able to provide the task lighting.
The 650V signalling supplies generally do not have the capacity to provide site lighting loads.  Signalling Power Supplies are also a safety critical system using them for general supplies would pose a risk to the safety critical system.  Also the transitory nature of track works means the cost of modifying the 650V system against the times it would be used probably would not have the cost saving benefit.
NR» (Network Rail - home page) are trialling portable tower lighting with LED lights that are battery powered that have sola / wind generation which means at night they run on battery during the day when not in use the sola and wind charge the batteries, they also have a small generator to charge the batteries.  The great thing about these is they are silent at night, the generator only runs is need during the day
