Travel & transport from BBC stories as at 20:35 09 Jan 2025
 today - Bath Railway Society
9th Jan (2004)
18:56 Exmouth to Paignton
19:15 Paignton to Exmouth
19:17 Exeter Central to Barnstaple
19:25 Exmouth to Paignton
20:19 Exeter Central to Barnstaple
17:52 Trowbridge to Great Malvern
18:18 London Paddington to Swansea
18:30 London Paddington to Weston-Super-Mare
18:34 London Paddington to Cheltenham Spa
January 09, 2025, 20:37:59 *
[149] Railcard Prices going up
[126] 'Railway 200' events and commemorations 2025
[97] Thumpers for Dummies
[53] Ryanair sues 'unruly' passenger over flight diversion
[34] Mick Lynch announces retirement as head of RMT
Author Topic: buses that clean the air  (Read 2198 times)
infoman
« on: June 20, 2019, 20:23:54 »
Can't find this mentioned any where else,if it has been mentioned please delete.
https://www.bbc.co.uk/news/uk-england-hampshire-48704743
« Last Edit: June 20, 2019, 22:02:19 by Red Squirrel » Logged
« Reply #1 on: June 20, 2019, 20:36:42 »
Not seen it before ... and seems sensible.
Western Pathfinder
« Reply #2 on: June 20, 2019, 22:53:28 »
This first appeared on the radar just about a year ago iirc,the idea is not a new one ,Saab/Scania trucks did try something very similar in the early 2000s and before that Saab GB (Great Britain) had a demonstration unit using two of their cars ,an old 99 and new 900 which was one of the first Catalyst equipped models,the exhaust from the older vehicle was measured and then fed into the air intake of the newer catalyst equipped car and then measured a second time,it of course was very much cleaner,no surprise there you might think, however this testing was carried out in central London,and the air from the second exhaust measuring was in fact cleaner than that the fresh air that was feeding the older car in the first place !..
« Reply #3 on: June 24, 2019, 11:48:36 »
The two systems are not the same.
The earlier one treated the exhaust gases and claimed these to be cleaner than the surrounding air, which was the case if only certain pollutants were considered.
The equipment fitted to the bus is not connected to the exhaust. It is a simple air filter that removes fine particulates from the surrounding air. Such particulates are dangerous to health and removing them is desirable.
Neither system removes carbon dioxide which is the principle cause of climate change.
Carbon dioxide emissions would in fact be slightly increased due to the weight of the extra equipment.
