Travel & transport from BBC stories as at 00:35 29 Apr 2025
29th Apr (1973)
23:05 Bristol Temple Meads to Exeter St Davids
17:50 Penzance to London Paddington
April 29, 2025, 00:38:16 *
Author Topic: New train deliveries remain stalled as passengers wait  (Read 1984 times)
« on: March 12, 2019, 06:50:53 »
From Rail News
PROBLEMS with software and other technical issues are now delaying the delivery of more than a hundred new trains.
Some lines are making do with reduced services or life-expired trains as a result, while the reopening of one new route has been put back indefinitely until its rolling stock is given the all-clear.
Not (any) new stories, but a worrying pattern and the article isn't complete in its list.
« Reply #1 on: March 12, 2019, 09:22:43 »
No mention for example of Hull Trains....so thet've 'borrowed' a GWR (Great Western Railway) Castle class HST (High Speed Train (Inter City class 43 125 units)) from the south west in the meantime.
« Reply #2 on: March 12, 2019, 10:01:10 »
Short set but are they using "Castles" - video I have seen shows (I think) 5 carriages, 1.5 first class, and doors with 'andles on the outside ... but then they may be swapping sets around.
No mention of 802 delays on the Bedwyns
« Reply #3 on: March 12, 2019, 10:08:25 »
As I understand the current situation (might change tomorrow of course Roll Eyes), is that some of the 'Castle' sets are initially going to be slam door so that they can get them into service earlier (i.e. by the December 2019 timetable change).
« Reply #4 on: March 12, 2019, 10:16:43 »
Yes - I heard of short HSTs (High Speed Train (Inter City class 43 125 units)) working with slam doors.   Lots of questions ... Would they have the loos changed by then to ensure a disabled loo and no track dumping on each train?  Would they be able to keep to the (new) timetable with shorter station dwells since the train manager would have to walk up and down if whenever someone left a door open on an unstaffed platform?  Would they still be called "Castles"?
« Reply #5 on: March 12, 2019, 12:25:43 »
Software and computer problems seem to be a growing problem.
Many of the IET (Intercity Express Train - replacement for HSTs (manufactured by Hitachi in Kobe, Japan)) failures have been "computer says no" rather than a physical component breaking, dropping off, or catching fire.
And the IET design is now at least 5 years old, so newer trains for other parts of the network are potentially even more complicated with more things for the computers "to say no to"
« Reply #6 on: March 12, 2019, 12:49:12 »
Yes, mind you it's a bit of a double-edged sword that one.  Some of the 'computer says no' incidents might have prevented the much worse situation of a component breaking, dropping off or catching fire!
Asset monitoring such as Hitachi Rail Europe receiving a real time message sent automatically from the train saying an engine is poorly is much better than that only being discovered when 'on the shed' that night as it allows better maintenance planning and reduces the number of failures that occur in service when a 'poorly' engine turns into something more terminal.
On the flip side, spurious faults can be an annoying source of unnecessary delay, so it is important that on board computers work properly, and with new trains it does seem to take an age for them to settle down.  There are signs that the IET software is improving though - witness the recent HSS (High Speed Services) performance and reliability statistics which simply would not be that good if the trains were regularly sitting down in service.
« Reply #7 on: March 12, 2019, 13:20:15 »
Has ATP (Automatic Train Protection) ever got to a state of really being considered reliable? Quite a lot of train faults used to be attributed to that as I recall.
« Reply #8 on: March 12, 2019, 13:46:26 »
I'd say it's pretty reliable.  There are usually a few locations where the brake is automatically applied due to trackside equipment issues, which causes delays, though nothing too severe (especially now as the brake on IETs (Intercity Express Train - replacement for HSTs (manufactured by Hitachi in Kobe, Japan)) can be fully recovered much quicker than on HSTs (High Speed Train (Inter City class 43 125 units)) where you could often be brought down to a crawl).  Failure of the on-board equipment is pretty rare given the number of times it is used per day.
