Travel & transport from BBC stories as at 20:35 21 Apr 2025
- Passengers evacuate Delta plane after engine fire
21st Apr (1958)
17:50 Penzance to London Paddington
Additional 18:13 Reading to Swansea
18:37 London Paddington to Swansea
18:45 London Paddington to Great Malvern
19:04 Great Malvern to London Paddington
19:07 London Paddington to Bristol Parkway
19:29 Gatwick Airport to Reading
19:59 Gatwick Airport to Reading
20:06 Westbury to Cheltenham Spa
20:07 Basingstoke to Reading
20:07 London Paddington to Didcot Parkway
20:10 Gloucester to Bristol Temple Meads
20:10 Reading to Newbury
20:16 Newbury to Bedwyn
20:17 Newbury to Reading
20:21 Reading to Basingstoke
20:34 St Ives to St Erth
20:35 Reading to Newbury
20:35 Basingstoke to Reading
20:38 Didcot Parkway to London Paddington
20:44 Bedwyn to Newbury
20:48 Reading to Oxford
20:50 St Erth to St Ives
20:52 Reading to Basingstoke
20:56 Worcester Foregate Street to London Paddington
20:59 Cheltenham Spa to London Paddington
21:00 London Paddington to Plymouth
21:01 Basingstoke to Reading
21:02 Oxford to Reading
21:05 St Ives to St Erth
21:05 Newbury to Bedwyn
21:05 Reading to Newbury
21:07 London Paddington to Didcot Parkway
21:08 Newbury to Reading
21:15 London Paddington to Oxford
21:20 St Erth to St Ives
21:22 Reading to Basingstoke
21:30 Basingstoke to Reading
21:37 St Ives to St Erth
21:37 Bedwyn to Newbury
21:44 Didcot Parkway to Reading
21:46 Bristol Temple Meads to Severn Beach
21:46 Twyford to Henley-On-Thames
21:56 Newbury to Reading
21:57 Newbury to Bedwyn
22:01 Henley-On-Thames to Twyford
22:08 Newbury to Reading
22:10 Reading to Newbury
22:13 Basingstoke to Reading
22:21 Reading to Didcot Parkway
22:25 Bedwyn to Newbury
22:30 St Erth to St Ives
22:30 London Paddington to Bedwyn
22:38 Didcot Parkway to Reading
22:40 Severn Beach to Bristol Temple Meads
22:47 Newbury to Bedwyn
22:47 Newbury to Reading
22:48 St Ives to Penzance
22:53 Didcot Parkway to Reading
23:07 Oxford to London Paddington
23:17 Bedwyn to Reading
Additional 23:36 Westbury to Bristol Temple Meads
23:45 Bristol Temple Meads to Frome
16:00 London Paddington to Penzance
16:15 Penzance to London Paddington
17:00 London Paddington to Penzance
17:28 London Paddington to Taunton
17:37 London Paddington to Carmarthen
18:15 Penzance to Exeter St Davids
18:30 London Paddington to Plymouth
19:00 London Paddington to Plymouth
19:24 Reading to Gatwick Airport
19:45 Great Malvern to London Paddington
19:59 Cheltenham Spa to Swindon
April 21, 2025, 20:46:29 *
[108] Fortuitous connections ... and an App which fails to offer the...
[93] Firstgroup's rail division trading 'ahead of expectations'
[77] Eyesight rules for motorists unsafe, says coroner
[64] RNLI station celebrates 10 years of saving lives - Portishead,...
[56] Yeovil Railway Centre - South chord project
[53] Every way to travel between Devon/Cornwall to London rated
Author Topic: Problem at Westbury 1st Feb 2019  (Read 9304 times)
« on: February 01, 2019, 08:54:34 »
The 1A71 Plymouth to Paddington has failed at Fairwood Jn, around 0715. Currently holding up 1A72 ex Plymouth, 1A73 ex Plymouth and 2D03 ex Weymouth.
The Westbury avoider seems closed on Traksy, presumably weather related.
rogerw
« Reply #1 on: February 01, 2019, 09:13:16 »
Also appears to be a track circuit failure on the up main east of Westbury which will cause further delays when everything gets moving.
« Reply #2 on: February 01, 2019, 09:17:19 »
Nigh on appalling weather conditions in the Bath, Bristol, North Somerset and Wiltshire areas this morning with heavy snow continuing to fall.
rogerw
« Reply #3 on: February 01, 2019, 11:00:16 »
Situation slowly returning to normal(ish).  1A71 still sat on platform 2.  It appears it was pushed into Westbury by 1A72.  1A73 now running 2½ hours late. 1A72 having shunted around the bad boy is now running 3 hours late. 2D03 cancelled at Westbury with 2D05 running 129 mins late and terminating at Bristol TM (Train Manager, or possibly Ticket Machine, depending on context). 1010 westbury to Warminster cancelled.
rogerw
« Reply #4 on: February 01, 2019, 12:37:14 »
Although Westbury problems now ended, the line is blocked between Bedwyn and Hungerford by a fallen tree. 1A81 diverted via Melksham
Update 1325: Line now reopened
« Last Edit: February 01, 2019, 13:26:02 by rogerw » Logged
« Reply #5 on: February 01, 2019, 14:09:51 »
Indeed, 1A72 pushed 1A71 into Platform 1 at Westbury. 1A73 then went through Westbury on to the B & H and then was stopped by the TCF (Track Circuit Failure). 1A72 reversed towards Clink Road then reversed again into platform 3 before continuing to Paddington where it arrived 3 1/4 hours late.
Thatcham Crossing
« Reply #6 on: February 01, 2019, 15:19:51 »
Not sure that's the case. 1A85 has been sat at or near Bedwyn for around 40 mins as I type (1520).
There also appears to be a Turbo (5K23) sat in the turnback siding for nearly an hour now.
« Reply #7 on: February 01, 2019, 15:58:42 »
A track machine (6Q54) has failed after hitting a tree.  Trees now removed, but 6Q54 needs rescuing and a loco is running from Westbury under the usual rescue headcode of 1Z99 (though obfuscated to 172L on OTT (Open Train Times website, or possibly 'over the top', depending on context) maps).  So, both lines are technically open, but the failed train is currently blocking the up line.
Thatcham Crossing
« Reply #8 on: February 01, 2019, 17:09:21 »
Looks like, after around 2 hours in the Bedwyn area, 1A85 has been moved to the down side and has re-traced it steps back towards Westbury (to presumably divert from there?).
1Z99 was also last seen proceeding towards the failed track machine, somewhere between Bedwyn and Hungerford.
« Reply #9 on: February 01, 2019, 17:34:15 »
1A85 cancelled at Bedwyn due to high winds according to RTT» (Real Time Trains - website)!
Trowres
« Reply #10 on: February 01, 2019, 17:44:51 »
1A85 seemed to disappear after Heywood Road Junction on its backtracking.
I'm wondering if it became the 1C88 Paddinton-Penzance which is currently (17:43) sitting at Westbury, and which Journeycheck indicates will be started from Westbury today (not Paddington).
It's being reported as "full and standing".
hoover50
Class 50 at Swindon
« Reply #11 on: February 01, 2019, 17:51:48 »
On OTT (Open Train Times website, or possibly 'over the top', depending on context) and Tracksy all the passing loops on the B&H (Berks and Hants - railway line from Reading to Taunton via Westbury) plus Newbury Racecourse platform 3 have the code KRS*
What does this mean?
« Reply #12 on: February 01, 2019, 17:52:37 »
Oh yea. Wonder if same reasons will occur in times of high winds WITHOUT the snow.
« Reply #13 on: February 01, 2019, 17:54:38 »
It stands for Key Route Strategy, meaning that some points are kept in one position in times of low temperatures and ice/snow to avoid them potentially failing when operated leading to problems.
« Reply #14 on: February 01, 2019, 17:57:44 »
Key Route Strategy. Access to these lines denied in case points get stuck, thus points giving access to the location must not be switched from the 'normal' position or summut like that.
