Travel & transport from BBC stories as at 10:15 19 Apr 2025
08:52 Worcester Foregate Street to Bristol Temple Meads
09:25 Par to Newquay
10:09 Gloucester to Westbury
07:45 London Paddington to Great Malvern
09:37 Reading to Basingstoke
10:23 Basingstoke to Reading
An additional train service has been planned to operate as shown 10:43 Fratton to Portsmouth Harbour
April 19, 2025, 10:18:30 *
Author Topic: A new concept for third rail electrification.  (Read 12421 times)
« on: January 08, 2019, 19:11:10 »
Without wishing to invoke the 'self praise is no recommendation' I have been known to come up with some good ideas in the past but none with such brilliance as to earn me my knighthood but heres hoping this idea will break the famine.
Has it ever been suggested that future third rail electrification schemes be controlled by the signalling system ?
Taking the Reading to Gatwick route for example.
At Wokingham if the route towards Gatwick is electrified and the signalling system was used to energise the routes 'live' rail one signalling section ahead of the train service and de-energised behind the service in conjunction with the signalling aspects rear of the train would that work.
Come on all you experts, tell me why it cant be done and thus deny me that knighthood.
All said with tongue in cheek of course.
« Reply #1 on: January 08, 2019, 19:27:03 »
I think one problem would be that no one would know whether the rail was live or not. People might become accustomed to it not being live and take even more risks.
« Reply #2 on: January 08, 2019, 19:41:17 »
More stupid those people then.
« Reply #3 on: January 08, 2019, 19:43:20 »
But a lot off such design issues are about protecting stupid people from themselves.
laird
« Reply #4 on: January 08, 2019, 19:59:48 »
You could switch like Crossrail from a signaller to a Traffic Manager they can then hold Signalling and Electrical skills.
But more fundamentally switching is ideally minimised to protect the switching equipment.
In terms of safety until proven and locked off no-one should be working near a bare conductor e.g. third rail so procedurally it wouldn't matter if it was switched on or off after each train.
« Reply #5 on: January 08, 2019, 20:51:45 »
[TiC] Yes, but they would only be electrocuted before being run-over!  Shocked [/TiC]
« Reply #6 on: January 08, 2019, 21:19:11 »
I think the main problem with this suggestion is that it contains the phrase 'future third rail electrification'. Syntactically and grammatically there is nothing wrong with this, but the same could be said of the phrase 'vegetarian butcher's shop'.
« Reply #7 on: January 09, 2019, 00:00:42 »
Yes so far as working on the line.
But if potential trespassers hear that it is only on when there is a train coming they are more likely to trespass and then get caught out!
« Reply #8 on: January 09, 2019, 05:07:41 »
......but only once! 😉
« Reply #9 on: January 09, 2019, 10:19:41 »
I wondered at first what the point of the suggestion was, but I guess it must be an attempt to make the system safe enough to overcome the ORR» (Office of Rail and Road, formerly Office of Rail Regulation - about)'s current stance of "over our dead regulatory body". But if so, why the half measures?
For trams, we have the Alstom re-invention of ground pick-up, which seems to have convinced several powers that be of its safety. In that case the tram itself covers the live contact so it's out of reach of reckless humans, and I think a similar shielding arrangement is needed here. So you would need the third rail to be encased in insulation, with electronically switched contacts all along it, and a much longer pick-up "ski" along the train with insulation on top if it too. To meet the gauging constraints this will almost certainly need to be flexible, so as to follow the shape of the third rail without sticking out too far. Since its length determines the spacing of contact points, and the number of those will be a cost driver, you may and up extending this contact bar to the full length of the train (or at least EMU (Electric Multiple Unit)).
Obviously it will all be a bit more expensive, but at least it could largely get rid of the problem of "gapping".
« Reply #10 on: January 09, 2019, 10:34:06 »
Yes and is in used today every day.
The traction current and the return current through Blackfriers station is squentially swithed through the platforms by the signalling track circuits.  This is part of the ad/dc traction power sepertaion.
The main problem in use on a "main line" would be having to energise sections in advance of the train also the conrail in the rear of the train will be live until the train has cleared the section.  There would not be any improvement in the safety of the system.  Inaddition often electrical sections a fed through due to a rectifier being out of use for maintenance or failure.
Technically posible but I doubt there would be much gained otherthan add an addition failure mode
onthecushions
« Reply #11 on: January 09, 2019, 23:45:16 »
So, set the direction control, brakes off, open the power controller, nobble the driver vigilance device and given suitable signal positions, you could do without the driver!
Hmmmm,
OTC
« Reply #12 on: January 31, 2019, 10:28:17 »
...the same could be said of the phrase 'vegetarian butcher's shop'.
The biter bit!
Unilever buys meat-free food company The Vegetarian Butcher
Acquisition of Dutch brand highlights scramble to tap into meat substitutes market
Unilever is buying the meat-substitute company The Vegetarian Butcher as it looks to cash in on the growing number of consumers turning their backs on meat.
Founded by the former cattle farmer Jaap Korteweg, the Dutch brand’s quirky products – which include “nochicken” nuggets and “chickburgers”, apparently with the same “taste and structure” as patties made out of chicken – have earned it a cult following among vegetarians and vegans.
The Guardian
