No recent travel & transport from BBC stories as at 12:55 03 May 2025
 today - Walk to Pilning
3rd May (2018)
13:00 Greenford to West Ealing
13:07 Reading to Basingstoke
13:15 West Ealing to Greenford
13:30 Greenford to West Ealing
13:53 Basingstoke to Reading
16:04 Bristol Temple Meads to Bristol Parkway
16:48 Bristol Parkway to Bristol Temple Meads
14:37 Reading to Basingstoke
15:24 Basingstoke to Reading
16:07 Reading to Basingstoke
16:53 Basingstoke to Reading
17:37 Reading to Basingstoke
18:23 Basingstoke to Reading
19:05 Reading to Basingstoke
19:55 Basingstoke to Reading
20:37 Reading to Basingstoke
21:23 Basingstoke to Reading
22:05 Reading to Basingstoke
22:55 Basingstoke to Reading
May 03, 2025, 13:11:04 *
[192] Subtle train time changes
[91] A very easy riddle
[86] In memory of the Weymouth Harbour Tramway on the anniversary o...
[56] Steam excursion - except there's much more diesel than steam!
[56] Service reduction - Coombe Junction
[15] Taplow-Hassocks
Pages: 1 2 3 [4] 5 6 ... 39
Author Topic: 2019 - TransWilts cancellation and amendments log  (Read 140111 times)
phile
« Reply #45 on: January 25, 2019, 10:48:46 »
I hope the toilets at Melksham station are in good working order, Graham, as Journey Check states that the unit today is toiletless and that station toilets should be used Smiley Smiley
 Grin Grin
I wonder if arrangement are being made to have the loos at Trowbridge remain open once the staff go off duty ...
In all seriousness, lack of loos on the train is very minor compared to complete lack of trains.
Distance is a factor here, I've seen instances of toiletless trains betwen Cardiff and Portsmouth.
« Reply #46 on: January 25, 2019, 12:36:11 »
As we recently discovered, Melksham is the home of the earth closet......if anywhere can cope, Melksham can...........Graham- bring your shovel just in case! 🙂
« Reply #47 on: January 30, 2019, 12:09:46 »
11:47 Westbury to Swindon due 12:32
11:47 Westbury to Swindon due 12:32 has been cancelled.
Additional Information
Customers will be required to use the next available service.
12:49 Swindon to Frome due 13:40
12:49 Swindon to Frome due 13:40 will be started from Westbury.
It will no longer call at Swindon, Chippenham, Melksham and Trowbridge.
Last Updated:30/01/2019 12:04
« Reply #48 on: January 31, 2019, 13:41:49 »
19:32 Westbury to Cheltenham Spa due 21:33
19:32 Westbury to Cheltenham Spa due 21:33 will no longer call at Melksham.
This is due to forecasted severe weather.
Last Updated:31/01/2019 13:27
20:08 Swindon to Westbury due 20:49
20:08 Swindon to Westbury due 20:49 will no longer call at Melksham.
Reginald25
Moderator
« Reply #49 on: January 31, 2019, 13:48:45 »
Does this mean it's running via some other route than BOA to Thingley or cancelled completely? If its a forecast weather issue, is the weather at MKM» (Melksham (Station code) - next trains) likely to be worse than elsewhere on the route?
« Reply #50 on: January 31, 2019, 14:20:52 »
The trains concerned will be reversing at Bathampton.
Limited investment / maintenance in pointwork that's able to function reliably in severe weather at the end of the single line means that Network Rail close the line through Melksham as a precaution at times.  Of course proper solution would be to provide proper robust infrastructure like they do in most other places (there are some loops and crossovers out of use too when the weather gets bad, but I don't know of any other complete lines!)
« Reply #51 on: January 31, 2019, 14:39:25 »
Or station watchmen at Thingley and Bradford Junctions to "babysit" the points.
Celestial
« Reply #52 on: January 31, 2019, 14:40:01 »
The Met Office is currently predicting no snow in Melksham until around 9pm, so it seems a bit premature to close the line by 7.30. I expect it will still be closed tomorrow after the 1cm of "heavy snow" has fallen too.  Angry
« Reply #53 on: January 31, 2019, 15:19:17 »
I see the 19:32 from Westbury has been removed from the list of amended services.   I assume that means it will now run through Melksham - although positive confirmation of that rather than just removing any reference to it would be better in my opinion.
« Reply #54 on: January 31, 2019, 16:15:01 »
20:08 ex Swindon now running booked route too.
« Reply #55 on: February 01, 2019, 14:34:41 »
18:32 Westbury to Swindon due 19:21
18:32 Westbury to Swindon due 19:21 will be cancelled.
This is due to severe weather preventing train crew getting to work.
20:08 Swindon to Westbury due 20:49 will be cancelled.
« Reply #56 on: February 08, 2019, 07:04:00 »
12:20 Westbury to Swindon due 13:02
Facilities on the 12:20 Westbury to Swindon due 13:02.
Toilet facilities are not available.
We apologise for the inconvenience this may cause.
Also the return trip and the 19:32 Westbury to Cheltenham Spa via Swindon
« Reply #57 on: February 08, 2019, 10:06:13 »
All aboard the cross legged express! 😣
« Reply #58 on: February 11, 2019, 10:09:49 »
09:46 Westbury to Swindon due 10:32
09:46 Westbury to Swindon due 10:32 will no longer call at Melksham.
It is being delayed at Westbury.
This is due to a points failure.
Last Updated:11/02/2019 10:01
« Reply #59 on: February 11, 2019, 10:32:07 »
10:47 Swindon to Westbury due 11:28
10:47 Swindon to Westbury due 11:28 will be started from Chippenham.
It will no longer call at Swindon.
Last Updated:11/02/2019 10:28
