Travel & transport from BBC stories as at 23:55 19 Apr 2025
20/04/25 20:11 Weymouth to Bristol Temple Meads
April 20, 2025, 00:05:37 *
Pages: 1 [2] 3 4
Author Topic: Trains reversing beyond the station  (Read 38642 times)
« Reply #15 on: September 20, 2018, 00:39:12 »
XC (Cross Country Trains (franchise)) trains terminating at Southampton usually run through to either up or down side loops, but there’s a single XC train that arrives just after the morning peak that runs down to Totton Yard, it takes up most of the turn round time:
http://www.realtimetrains.co.uk/train/C78203/2018/09/27/advanced
SWR» (South Western Railway - about) and XC use proper dedicated reversing sidings just beyond Bournemouth, these are in the ideal middle of the formation, complete with full length staff platforms.
« Reply #16 on: September 20, 2018, 07:23:07 »
Goodness - a lot more of this goes on than I had noted!
Can someone confirm - on the same basis:
1. train from Bristol direction can reverse at Bradford Junction having terminated at Bradford-on-Avon
2. train from Swindon direction can reverse at Bradford Junction having terminated at Melksham
3. train from Bristol or Swindon can terminate at Trowbridge and reverse at Heywood Road Junction
brooklea
« Reply #17 on: September 20, 2018, 08:06:32 »
Yes, all three of those scenarios are possible.
Thatcham Crossing
« Reply #18 on: September 20, 2018, 09:15:30 »
Newbury, where the new wires have been extended westwards beyond the station to enable electric-only turnbacks via a cross-over just west of the Station.
Apparently the wires go far enough to reverse a 12-coach 387 (if that were ever needed?)
rogerpatenall
« Reply #19 on: September 20, 2018, 10:57:06 »
Poole - certainly in XCountry days, and perhaps still so.
« Reply #20 on: September 20, 2018, 12:41:59 »
Yes, that’s another where empty down trains run beyond into a siding and come back into the up platform later, in the normal offpeak pattern they seem to be in the sidings around 45 mins or so.  Poole S.S. On realtimetrains if interested.
Going back a few years, when Southern’s Brighton <> Southampton first started, many of them ran on to just beyond Southampton, and IIRC ('if I recall/remember/read correctly') often reversed from a position on the slow lines.  Helpfully the slows west of Southampton are the centre pair of the four running lines, so this isn’t as conflicting as you’d think.
As of today, there are a couple of Southern shunts each day, one via the down loop, and one the up loop.  I dare say they could be about retaining route knowledge in case it goes pear shaped:  http://www.realtimetrains.co.uk/search/advanced/SOU/2018/09/27/0000-2359?stp=WVS&show=non-passenger&order=wtt&toc=SN
« Last Edit: September 20, 2018, 12:52:34 by paul7755 » Logged
« Reply #21 on: September 20, 2018, 13:03:50 »
One train a day reverses twice outside of Newbury to get into position
http://www.realtimetrains.co.uk/train/C43689/2018/09/20/advanced
« Reply #22 on: September 20, 2018, 13:08:06 »
Doesn’t Cardiff Central not have bi-directional signalling?
It does, but usually operationally easier to go out and come back in to a different platform
plymothian
« Reply #23 on: September 20, 2018, 16:08:41 »
There are lots of places where a train could turn back due to operational reasons, which is different to where they regularly turn back.
For instance, at Topsham trains terminating short run beyond the platform to switch sides, the same can happen at Exeter Central before St James Park.  At Highbridge and Burnham trains can shunt via the loop to return to Bristol.  During the Cowley blockage trains terminating at Tiverton Parkway reversed via Tiverton loops.
« Reply #24 on: September 20, 2018, 16:27:44 »
Taunton.
The weekday 1355 arrival from Cardiff Central terminates on the down main, the island platform 3. It then heads back up the down main, crosses over to the up main, reverses and heads down that line onto the up relief and then into the up bay platform 6.
Two reasons for doing this move. Firstly, to keep up route knowledge of the reverse into platform 6, and second, to clear platform 3 for a terminating service from London.
« Last Edit: September 20, 2018, 16:34:22 by bignosemac » Logged
4064ReadingAbbey
« Reply #25 on: September 20, 2018, 17:40:03 »
Also Reading. Some Southbound terminating XC (Cross Country Trains (franchise)) trains run further East to the loop off the Down Relief at Kennet Bridge, reverse there and come back later to pick up their return working.
FarWestJohn
« Reply #26 on: September 20, 2018, 18:27:28 »
Also gets the unit off the Portsmouth direct line.
« Reply #27 on: September 20, 2018, 22:12:33 »
Epsom
Plenty of SWR» (South Western Railway - about) and Southern Terminators from London. Some stay on the platform, others continue to the sidings.
Bob_Blakey
« Reply #28 on: September 20, 2018, 22:28:40 »
SWR» (South Western Railway - about) services from the Waterloo line generally use the New Yard at EXD» (Exeter St Davids - next trains) to swap from Platform 3 to P1.
Thatcham Crossing
« Reply #29 on: September 21, 2018, 07:55:42 »
GWR (Great Western Railway) 16x's at Gatwick reverse or stable between runs beyond the Station, don't they?
Pages: 1 [2] 3 4
