Travel & transport from BBC stories as at 18:35 13 May 2025
- US cuts tariffs on small parcels from Chinese firms like Shein and Temu
 today - Melksham TUG / AGM
tomorrow - West Wiltshire RUG
17/05/25 - Summer Timetable Starts
18/05/25 - Portishead RNLI 10 anniversary
13th May (1933)
Bournemouth Trolley Bus opened (*)
18:29 Bourne End to Marlow
18:48 Marlow to Bourne End
18:59 Bourne End to Marlow
19:18 Marlow to Bourne End
19:29 Bourne End to Marlow
19:48 Marlow to Bourne End
19:58 Bourne End to Marlow
17:57 Reading to Basingstoke
20:08 Marlow to Maidenhead
20:38 Maidenhead to Marlow
21:04 Marlow to Maidenhead
21:38 Maidenhead to Marlow
22:04 Marlow to Maidenhead
22:37 Maidenhead to Marlow
23:03 Marlow to Maidenhead
23:50 Maidenhead to Marlow
16:32 London Paddington to Cheltenham Spa
17:00 London Paddington to Bristol Temple Meads
17:18 London Paddington to Swansea
17:28 Weymouth to Bristol Temple Meads
18:24 Newbury to Bedwyn
May 13, 2025, 18:41:36 *
[219] Champion Reflections
[46] [otd] 13th May (1985) - Melksham Station re-opened
[34] Go-Op Cooperative - proposals for additional rail services
[30] Inaugural nonstop run Kings Cross to Edinburgh - 1st May 1928
[28] HS2 - Government proposals, alternative routes and general dis...
[23] Night Riviera Sleeper train - between Paddington and Penzance
Author Topic: Jubilee Tube travels with doors wide open!  (Read 5651 times)
« on: September 04, 2018, 10:27:29 »
I hope the RAIB (Rail Accident Investigation Branch) are investigating!
https://www.standard.co.uk/news/london/shocking-moment-tube-train-travels-along-jubilee-line-with-passengers-on-board-and-doors-wide-open-a3926606.html
https://news.sky.com/story/amp/jubilee-line-tube-filmed-hurtling-along-with-doors-wide-open-11489882
CMRail
« Reply #1 on: September 04, 2018, 10:30:08 »
I saw this on twitter and couldn’t believe it. The safety features must be awful, the driver not paying attention and the passengers not using the emergency alarm handle. Awful.
« Reply #2 on: September 04, 2018, 10:40:46 »
I side with the passengers - the guy did tweet that there were at least 10 doors open. Assuming all one side in his carriage were open, would you stand and approach a vestibule where the draft is unknown & may suck you out? I'm not sure I would....now if those alert buttons were in the seating areas and NOT in  just the vestibules, easily reached.
« Reply #3 on: September 04, 2018, 11:40:31 »
Yes, and there are even stronger reasons too. Stopping a tube train is a tunnel is never a good idea, as it makes whatever you do next more difficult and take much longer. Worse, while there is a small risk a passenger may go near the doors and fall out while the train is moving, there is a much larger risk someone will try to get out once it's stopped. I'm not sure how big the clearance is in Jubilee Line tunnels, but it's still a bad idea to go wandering off into it.
« Reply #4 on: September 04, 2018, 12:03:21 »
This incident was above ground, between Finchley Road & West Hampstead,....
« Reply #5 on: September 04, 2018, 12:06:00 »
(Sigh) reminds me of the shocking 20 years before the last of the LDs were withdrawn, and I used to travel in and out of Bristol swinging on the pole on the open platform. Didn't Routemasters have them too?
« Reply #6 on: September 04, 2018, 12:20:38 »
Ah - my mistake, Probably due to simultaneously reading the RAIB (Rail Accident Investigation Branch)'s NHG accident report (qv). Mind you, half the argument still applies.
CJB666
« Reply #7 on: September 04, 2018, 16:07:50 »
Seems like many station staff spend their working hours on Facebook or playing games or texting on smart phones. Maybe this has extended to the drivers too. In the US there have been a number of fatal crashes due to drivers (engineers.) texting whilst on the move, etc.
« Reply #8 on: September 04, 2018, 17:07:49 »
There was a previous case a bit like this, on a Victoria Line train leaving Warren Street (RAIB (Rail Accident Investigation Branch) report 13/2012). That involved the train operator overriding the doors closed interlock and forgetting to shut the doors. However, in that case the operator got very confused about how the system worked in its non-automatic modes while trying to cope with a persistent but apparently false alarm from the sensitive door edges.
Given the presence of a door interlock system, I can only see a failure of that system, or its being overridden by an operator, as being the cause this time.
