Travel & transport from BBC stories as at 12:35 20 Apr 2025
11:19 Swansea to London Paddington
09:45 Plymouth to Cardiff Central
11:25 Cardiff Central to Portsmouth Harbour
12:09 Portsmouth Harbour to Cardiff Central
12:25 Cardiff Central to Portsmouth Harbour
12:37 London Paddington to Swansea
April 20, 2025, 12:47:28 *
Author Topic: Train and bus companies working together at time of disruption  (Read 3472 times)
« on: August 28, 2018, 13:38:50 »
Obviously not thrilled at the broken down train blocking the line, but delighted to read that customers are able to use Faresaver buses - a good example of companies working together at times of disruption - THANK YOU to First and Faresaver for setting this arrangement up.
Delays to services between Chippenham and Trowbridge via Melksham
Due to a broken down train at Chippenham some lines are blocked. Disruption is expected until 14:00 28/08.
Train services between Chippenham and Trowbridge via Melksham may be delayed by up to 45 minutes.
Additional Information
Replacement road transport will operate between Swindon and Chippenham at 13:30. Customers are also able to use Faresavers bus routes X31 and X34.
« Last Edit: August 28, 2018, 14:08:30 by grahame » Logged
« Reply #1 on: August 28, 2018, 14:10:36 »
The train, the 10:35 from Paddington to Plymouth - diverted via Swindon due to Newbury works - came to a stand just after Chippenham shortly before 12 noon.  Two hours later it has just started moving back towards Chippenham as 5C78.  I am not sure what happened to the passengers.  I doubt it was really terminated at Swindon as it departed, as normal, as 1C78 on time.
10:35 London Paddington to Plymouth due 14:28
10:35 London Paddington to Plymouth due 14:28 was terminated at Swindon.
It will no longer call at Westbury, Castle Cary, Taunton, Tiverton Parkway, Exeter St Davids, Newton Abbot, Totnes and Plymouth.
Last Updated:28/08/2018 12:56
tomL
« Reply #2 on: August 28, 2018, 14:41:41 »
Looks like they were returned to Chippenham where the 12:30 Paddington to Penzance called additionally to pick them up.
phile
« Reply #3 on: August 28, 2018, 22:09:07 »
And then the 1230 ex Paddington arrived Penzance 130L due to complete failure approaching St Erth necessitating the Sleeper 57 to go from Penzance to assist
« Reply #4 on: August 29, 2018, 19:09:49 »
Sleeper left 82 mins late as a result and was still 20 minutes late when it arrived at Paddington.
« Reply #5 on: May 14, 2019, 11:08:27 »
Sadly, today the X31 is NOT offered with the line between Chippenham and Bath closed.   It's only the bus service that runs .... between Chippenham and Bath!!
Cancellations to services between Chippenham and Bath Spa
Following a fault with the signalling system between Chippenham and Bath Spa the line has now reopened.
Train services running through these stations may be cancelled, delayed by up to 30 minutes or diverted. Disruption is expected until 11:30 14/05.
Customer Advice
First Bus route 178: Bristol (Temple Gate) - Keynsham (Post Office), First Bus route 37: Bristol (Bus Station Bay 19) - Lawrence Hill (Station) - Keynsham - Bath (Bus Station), First Bus route D1: Bath (Bus Station) - Bradford on Avon - Trowbridge - Westbury - Warminster - Salisbury, First Bus route D2: Bath (Bus Station) - Frome (Market Place) and First Bus route D3: Bath (Bus Station Bay 14) - Melksham are conveying passengers via any reasonable route until further notice.
Robin Summerhill
« Reply #6 on: May 14, 2019, 20:49:41 »
Customer Advice
It might be pertinent that First Bus and GWR (Great Western Railway) are both part of First Group, which probably make inter-company co-operation easier.
It might also be pertinent that the problem was relatively short lived, with departures from CPM» (Chippenham - next trains) to BRI» (Bristol Temple Meads - next trains) being cancelled or diverted only between 0815 and 1015. In the reverse direction only the 0930 ex-Bristol was cancelled, presumably through lack of a train at BRI to operate it. Perhaps there was insufficient time to organise something with Faresaver, or perhaps nobody bothered, or perhaps (?) GWR got First to run a replacement bus service between Bath & Chippenham?
