Travel & transport from BBC stories as at 18:15 20 Apr 2025
* Coastguard search for man missing from yacht in sea
18:23 Swansea to London Paddington
April 20, 2025, 18:17:28 *
[178] Fortuitous connections ... and an App which fails to offer the...
[105] RNLI station celebrates 10 years of saving lives - Portishead,...
[54] FOSS and FOSW validity - some quirks
[44] More than half of train travellers now use the railway for lei...
[41] Eyesight rules for motorists unsafe, says coroner
Author Topic: Paddington platform 9 closed 08/08/2018  (Read 6683 times)
« on: August 08, 2018, 05:58:38 »
JourneyCheck informing that platform 9 at PAD» (Paddington (London) - next trains) is closed some services being terminated at Reading, mainly Bedwyn services when I checked.
a-driver
« Reply #1 on: August 08, 2018, 07:54:56 »
Defective longitudinal timbers on Platform 9.
« Reply #2 on: August 08, 2018, 08:00:14 »
This time the fault was spotted before a train fell off.  Wink
onthecushions
« Reply #3 on: August 08, 2018, 10:34:23 »
Well spotted.
Could have been a repeat of:
https://www.bbc.co.uk/news/uk-england-london-42078931
One wonders whether such track bases are laterally weak, compared with a conventional sleeper/cross-tie?
OTC
« Reply #4 on: August 08, 2018, 11:41:07 »
Begs the question whether the inspection regime is still failing.
Should it not be proactive, finding and fixing faults during quiet hours, rather than reactive and shutting a platform through a weekday rush hour?
« Reply #5 on: August 08, 2018, 13:41:30 »
I saw it being inspected around lunchtime on Monday by a lone NR» (Network Rail - home page) engineer, so I assume the closure was as a result of this activity. I was surprised at the time as OpenTimeTrains did not show the track as blocked.
« Reply #6 on: August 08, 2018, 21:36:09 »
OTT (Open Train Times website, or possibly 'over the top', depending on context) maps did show the line into P9 as 'SHUT' earlier in the day.
« Reply #7 on: August 09, 2018, 05:48:58 »
Repair work is continuing with the hope Platform 9 can be reopened towards the end of the morning peak.
dviner
« Reply #8 on: August 09, 2018, 19:28:12 »
Well, it looks as though the amount of work required in order to fix the fault would have exceeded any available "quiet hours", so disruption was on the cards. If that's the case, then you just have to bite the bullet and get on with it.
« Reply #9 on: August 09, 2018, 20:37:34 »
I appreciate its the modern way that such relatively minor works require all sorts of assessments, costings, briefings, etc. All checked and doubled checked. And not least, available staff to do the job.
But, just for comparison. In 1892, 117 miles of GWR (Great Western Railway) broad gauge track, across the network, including main and branch lines, was converted to standard gauge in one weekend. Work started after the last express from Paddington to the west on Friday night, and was completed in time for the first Monday morning express.
Now surely, despite modern requirements, a short defective length of track and its supporting timbers can be identified and replaced in one overnight possession. Its not as if the fault was in a difficult hard to access location.
« Reply #10 on: August 10, 2018, 09:23:25 »
If you read about some of the preparations carried out in advance of the 1892 works I think they would have significantly compromised the safety of passengers and I am surprised there were no accidents in the days or weeks either side. I recall reading that ballast was dug out, alternate cross timbers cut. I hope there were speed limits in force.
« Reply #11 on: August 12, 2018, 08:56:35 »
In 1892 there was little or no regard for the safety of track workers, things were only slightly better for the safety of passengers.   In the last 6 or so years a process called Adjacent Line On (ALO) has been brought in.  This requires certain safety measure to be in place to protect both passage of trains on an adjacent line and of the staff working on the line closed to traffic.  In the situation such as Platform 9 at Padd you could not meet the ALO requirements with platform 10 open.
Funding of such repairs is not a major issue, every Route Asset Manager has a "Reactionary Works Budget" also Route Managieing Directors can authorise overspends in such circumstances.
« Reply #12 on: August 12, 2018, 09:35:59 »
We seem to be discussing this in two seperate threads.
ET, what I have commented on elsewhere is why the track was allowed to get so bad in the first place?  Surely the infrastructure inspection regieme should have picked it up, and planning taken place to undertake the work in a timely manner, been to the forefront of NRs» (Network Rail - home page) responsibilities?
« Last Edit: August 12, 2018, 12:43:38 by SandTEngineer » Logged
CJB666
« Reply #13 on: August 23, 2018, 06:39:45 »
Remember when a few years back a SWT (South West Trains) train derailed at Windsor and Eton Riverside station due to rotten sleepers and the rails spreading apart out of guage. A bit like Network Rail management - rotten to the core.
https://www.gov.uk/raib-reports/derailment-at-windsor-and-eton-riverside-station
