No recent travel & transport from BBC stories as at 09:55 10 Jan 2025
08:36 Redhill to Reading
10:38 Bristol Temple Meads to Worcester Foregate Street
January 10, 2025, 10:05:57 *
[79] Ryanair sues 'unruly' passenger over flight diversion
[69] Thumpers for Dummies
[56] Westminster Hall debate : Railway services to South West
[52] Railcard Prices going up
[44] Mick Lynch announces retirement as head of RMT
Author Topic: Cycles to / from Heathrow  (Read 7169 times)
CJB666
« on: June 07, 2018, 09:42:44 »
It has long been an issue that you can't cycle to / from the central area of Heathrow. The side entrance tunnels have long been blocked off, and cycles are banned from the two main traffic tunnels.
Whilst it may be possible to catch the HCon service, since the TfL» (Transport for London - about) take-over, this is now so unreliable, being cancelled at every whim, that cyclists would be stupid to rely on it.
The new TfL trains still can't get into Heathrow due to defective signalling systems that no-one can solve.
HEX is grossly over-expensive for what it is - does it take cycles - if at all?
And do the inter-terminal shuttles - HEX and HCon - take cycles?.
Heathrow - the 100% foreign-owned 'duty-free' hypermarket with a sideline in air transport - has now been granted the third runway; but one of the requirements is to improve public transport to / from the Airport.
If current provisions for cyclists are anything to go by there's still a lot of improvements required.
So how can cyclists get to / from the Airport - cheaply?
« Last Edit: June 07, 2018, 09:53:20 by CJB666 » Logged
« Reply #1 on: June 07, 2018, 12:25:59 »
They can't - and frankly, the purpose of Heathrow is to fly. There is free transport laid on for employees there. Why would you cycle as you can't carry sensibly any amount of baggage sufficient to be useful, like overnight bags or larger.
They are also a security risk as explosives can be packed into their frame. I suspect that is the real reason.
« Reply #2 on: June 07, 2018, 13:14:29 »
You can fit a surprising amount in a couple of pannier's, Chris, though I do take your general point.   Wink
patch38
« Reply #3 on: June 07, 2018, 13:47:11 »
Echoing CJB's question; what happens if you arrive at T2 or T3 with your bike and panniers in the hold, all set for a pleasant cycling tour of our lovely country? How  do you get out of the central area? Presumably one of the bus shuttles will take bikes? Not a problem for T4 or T5 of course.
CJB666
« Reply #4 on: June 07, 2018, 13:55:38 »
The cyclists are of course staff or intending tourists on a cycling holiday overseas. Actually I am also asking because I want to fly to New Zealand next Christmas for an extended tour of both Islands.
« Reply #5 on: June 07, 2018, 14:29:55 »
In whih case, your bikes will go as freight and you won't be chec,king them in, I think, but delivering them to a freight handler.
Or carrying them as they'll need to be boxed up
« Reply #6 on: June 09, 2018, 10:16:38 »
I used to cycle or walk through that tunnel and it was very convenient when I worked there. I think the airport provided a free shuttle bus for cyclists and pedestrians when it closed but that has been replaced by free travel on local buses for those on foot into the airport now. I have no idea what cyclists (normally airport workers) do now. With the reconstruction of T2 and closure of T1 I'm sure the cycle storage area in between that I used is probably not there any more.
« Reply #7 on: June 09, 2018, 12:04:50 »
I just had a look at Heathrow's websites, starting with the recruitment one. That adopts HAL's current slogan of "making every journey better" in various guises, using "your journey" for the process of getting a job. But even in the FAQs (Frequently Asked Questions) under the "your journey" tab there's nothing about travel to work! All I found was the advice to leave plenty of time when going for interview, though that  would be to Compass House which is outside the airport perimeter.
One the main site they now have a journey planner. That does offer cycle as a mode, and giving it Hayes to T2 it sends you down the obvious road routes and through the tunnel. But then, at the bottom of the "details" page, there's an orange warning that says "Bicycling directions are in beta. Use caution – This route may contain streets that aren't suited for bicycling."
But I'm sure in the past I have found advice for employees about their travel to Heathrow, so it may still be hiding somewhere.
« Last Edit: June 09, 2018, 12:23:44 by stuving » Logged
« Reply #8 on: June 09, 2018, 12:53:30 »
Of course you can! Thousands of cycle tourists carry tents, sleeping bags, panniers upon panniers. Have a look at the travelogues over at crazyguyonabike.com for examples - the top journal at the time of writing was https://www.crazyguyonabike.com/doc/page/?o=1mr&page_id=542429&v=KU, which is a good example.
Cycling out of Heathrow comes up regularly on bike touring forums such as CGOAB. Generally the best options are either Heathrow Connect (or the Sweaty Betty Line or whatever it is this week), or one of the express coaches: both RailAir and the Oxford Airline take bikes. These have the added advantage for the cycle tourist that they speed you out of the West London suburbs and closer to enjoyable cycling territory.
CJB666
« Reply #9 on: June 10, 2018, 05:05:20 »
Sweaty Betty Line
 = Tin Lizzie Line
« Reply #10 on: June 10, 2018, 05:47:23 »
They can't - and frankly, the purpose of Heathrow is to fly. There is free transport laid on for employees there. [snip]
Of course you can! Thousands of cycle tourists carry tents, sleeping bags, panniers upon panniers. [snip]
What about walking to Heathrow if you live on the periphery?
I recall talking with a chap who was on one of our courses a number of years back ... and he was taking a flying visit - literally - so see his mum that weekend.
Me:   "How will you get from the airport - will she pick you up?"
He:   "I will walk"
Turns out she lived in a cottage about 400 yards from the terminal (I suspect there is just one terminal) at Benbecula.
« Reply #11 on: June 10, 2018, 06:59:25 »
He:   "I will walk"
A while ago when I was in Australia I landed at Uluru and walking from the aircraft to the terminal building passengers passed a well maintained garden with trees and tropical plants and a wooden entrance gate proclaiming "PRIVATE" and within the trees a beautiful homestead bungalow could be seen which happened to be the Airport Managers "tied cottage".
« Reply #12 on: June 10, 2018, 20:57:39 »
He:   "I will walk"
You can walk or cycle to Terminals 4 and 5 as they are on the perimeter but access to T2 and T3 is currently not possible. You can park your bike at Heathrow Academy which is on the northern perimeter and then take a free bus into the central area.
Cycle parking
There is currently no direct cycle route to Terminals 2 and 3 due to construction work to the main road tunnel. Bicycles can be parked in racks at the Heathrow Cycle Hub, where free local buses operate to the terminals.
View bus route map  (155KB)
Free cycle parking is available at:
Terminals 2 and 3: The Cycle Hub, Heathrow Academy, Newall Road, Hounslow, Middlesex, TW6 2AP
Terminal 4: Cycle parking is opposite the arrivals forecourt
Terminal 5: Cycle parks are provided at either end of the terminal building.
Bikes can also be safely stored in the left baggage office for up to 90 days.
Please note that for security reasons, bicycles will be removed if not parked in the designated areas.
View map of Heathrow cycle parks  (1.6MB PDF)
« Reply #13 on: June 14, 2018, 16:27:24 »
Cycle parking
https://www.heathrow.com/transport-and-directions/cycling
