April 19, 2025, 21:28:06 *
Pages: 1 2 [3] 4 5 ... 7
Author Topic: Server issues  (Read 53724 times)
« Reply #30 on: November 02, 2018, 20:24:41 »
I am currently getting intermittent connection problems.  I assume that this is a related issue
Yes - I am working it.
Probably rebooting / may be down for an hour or two during the night.
« Reply #31 on: November 02, 2018, 20:59:39 »
Don’t fall asleep in the middle of it!
« Reply #32 on: November 03, 2018, 08:25:14 »
A clear restart / reboot during the night ... and I think we're running OK (famous last words!).
Technical note: The combination of software versions we're running with - old (open source) code logic on a bed of more recent operating system and utilities  - is not as stable as I would wish and occasional restarts tidy things up.   Work done to clear an instability the other day had left the restart procedure calling for a service that wasn't available so the other night the restart locked up while it waited - it timed out / gave up after 30 minutes or so; I made pessimistic provision in last night's estimates that this could happen again - however, it seems that the fix I had applied to replace the service call actually worked, so that the gap in service caused by the restart was/is no longer noticeable.
In English:  I can fall asleep quickly, but not as quickly as the server can restart  Grin Grin and in any case it's all working automatically again once the process is kicked off.
« Reply #33 on: November 03, 2018, 08:42:16 »
Famous last words, indeed ... I need to take a further look.   Good news is that the fiddling should not involve significant downtime.
« Reply #34 on: March 27, 2019, 14:24:03 »
Ooh ... good to see
Warning: this topic has not been posted in for at least 120 days.
Unless you're sure you want to reply, please consider starting a new topic.
when posting on the thread ... however, I've had a couple of funnies while doing some admin work and notice there's been a gap in posts - so have rebooted the server.   To some extent, this is a test post - as well as an apology if others have had issues.
IanL
« Reply #35 on: March 30, 2019, 20:27:28 »
Graham,
I am seeing some posts with just a white page, eg second page of the charlbury platform extensions is completely blank (white, no banner etc) but the index page is indicating that there are posts there.
Ian
« Reply #36 on: March 30, 2019, 20:39:42 »
Graham,
Ian
Odd.  Let me have a play.
« Reply #37 on: March 30, 2019, 21:04:52 »
Graham,
Ian
And if you say "print" ... you see the posts.  Noting an earlier post reporting problems with at attachment ... I suspect that's a clue.
I'm going to give you no confidence in what I'm doing by saying "never seen it do that before" ... but I am pretty sure the problem is limited to a single thread and won't spread.
Western Pathfinder
« Reply #38 on: March 30, 2019, 21:36:02 »
Just done the same with me 21:.33 pm.
« Reply #39 on: March 30, 2019, 21:39:48 »
Is that on the same thread?
http://www.firstgreatwestern.info/coffeeshop/index.php?topic=19529 works
http://www.firstgreatwestern.info/coffeeshop/index.php?topic=19529.15 fails
« Reply #40 on: March 30, 2019, 21:44:35 »
Graham,
Ian
Now noticing "e.g." - looking for further examples.
Western Pathfinder
« Reply #41 on: March 30, 2019, 21:46:34 »
Yes should have made it clear apologies.
« Reply #42 on: March 30, 2019, 21:52:12 »
Phew!  ... I have my suspicions / will look during the night when the forum is quiet and I can add test code and turn debug flags on.  If anyone has any further examples please let me know.
eXPassenger
« Reply #43 on: March 30, 2019, 22:43:38 »
Only page I have seen is page 2 of Charlbury.  It did not load last night, but I left it to see if it loaded today.
« Reply #44 on: March 31, 2019, 00:03:41 »
Graham,
Ian
I've had the same issue with that thread.  I was going to post that it looks like the end of March aspiration for the new platform extensions opening is heading towards an end of April one!
