Travel & transport from BBC stories as at 12:35 20 Apr 2025
11:19 Swansea to London Paddington
09:45 Plymouth to Cardiff Central
11:25 Cardiff Central to Portsmouth Harbour
12:09 Portsmouth Harbour to Cardiff Central
12:25 Cardiff Central to Portsmouth Harbour
12:37 London Paddington to Swansea
April 20, 2025, 12:47:16 *
Pages: 1 ... 32 33 [34] 35 36 ... 45
Author Topic: 2018 cancellation and amendment log  (Read 139515 times)
phile
« Reply #495 on: September 02, 2018, 16:56:12 »
19:41 Westbury to Cheltenham Spa due 21:28
19:41 Westbury to Cheltenham Spa due 21:28 will be cancelled.
There will be nobody coming off the 1756 from Weymouth as that is cancalled as well
« Reply #496 on: September 03, 2018, 09:16:47 »
07:04 Westbury to Cheltenham Spa due 09:05
07:04 Westbury to Cheltenham Spa due 09:05 has been delayed between Westbury and Swindon and is now 16 minutes late.
This is due to this train being late from the depot.
xraydelta1
Newbie
« Reply #497 on: September 03, 2018, 09:23:53 »
This excuse is nonsense. It left 1 late from Salisbury and arrived 7 late into Westbury (having twiddled its thumbs at Dilton) as the signaller moved empty stock around in front of it for some reason, using the same platform. Then it got stuck behind a late running Paddington @ Chippenham.
Source: I was on it Wink
RA
« Reply #498 on: September 03, 2018, 13:25:26 »
5E17 is attributed as the cause of 11 minutes of the delay. This normally comes off of the rear of the 05:44 Bristol TM (Train Manager, or possibly Ticket Machine, depending on context) to Portsmouth service, being detached at Westbury. Today it appears that the set was outstabled at Westbury overnight (I suspect extra stock at Westbury overnight with the list of cancellations on Sunday) requiring an extra unscheduled empty stock move from the sidings. The signalling at Westbury doesn't allow a train to be routed into platform 3 from the Frome or Warminster lines if there are movements coming out of the sidings as there is insufficient overlap beyond the platform starting signal on platform 3 (this has been the case since the 1984 track rationalisation of the Westbury station area).
« Reply #499 on: September 03, 2018, 14:59:45 »
Shambolic.
Is there any reason why that train can't be DOO (Driver-Only Operation (that is, trains which operate without carrying a guard))?
Where I have seen DOO in use there have been mirrors and cameras that are missing all along the line, and fare collection systems which give nearly everyone an opportunity to purchase before they travel .....
As a follow up and from other research, I have just come across a page that maps where DOO is in use.
https://www.kingqueen.org.uk/category/accessibility/transport-accessibility/trains/
« Reply #500 on: September 03, 2018, 15:18:17 »
That signal positioning has also been a problem for HSTs (High Speed Train (Inter City class 43 125 units)) calling at Platform 3.  If it isn't showing a proceed aspect when the train arrives, the whole of an 8 carriage train won't fit on the platform. Trains used to stop with the powercar past the signal if it was cleared - not sure if they still do.
« Reply #501 on: September 03, 2018, 15:29:49 »
The junction at the north end of Westbury station is to be relayed over Christmas as the track has come to the end of its useful life.
There are calls for changes to the track and signalling layout to meet modern requirements    Does anyone know if the Christmas opportunity is being taken to resolve issues, or is a bull-at-a-gate approach, with it being relayed exactly as-is even knowing that there are elements of the layout that really need attention and could be dealt with as part of this process?
« Reply #502 on: September 03, 2018, 19:55:12 »
Could they also reopen the old platform 1 whilst they are at it? Too much to hope for I know. But with Westbury station completely closed over Christmas what a golden opportunity instead of having to close the station again at a later date to bring this platform back into use.
« Reply #503 on: September 03, 2018, 20:02:45 »
It's appearing that the left hand (regular renewal) and the right hand (upgrade) may not talk to each other - with the result that both waste money over the years.   I have a meeting set up next Monday - I hope I'm not told that we should have raised the idea before we knew there was an opportunity to raise the idea.
« Reply #504 on: September 04, 2018, 18:13:50 »
17:36 Swindon to Westbury due 18:17
17:36 Swindon to Westbury due 18:17 is being delayed at Swindon.
Can't have been too late - it was gone when I arrived at 17:48 ....
« Reply #505 on: September 04, 2018, 18:30:35 »
Systems claim it left at 17:49 - 13 minutes late.   Was 19 late by Chippenham.
Clan Line
« Reply #506 on: September 04, 2018, 21:21:17 »
http://www.firstgreatwestern.info/coffeeshop/index.php?topic=20116.msg245039#msg245039
« Reply #507 on: September 05, 2018, 07:21:30 »
07:04 Westbury to Cheltenham Spa due 09:05 will be diverted between Trowbridge and Chippenham.
It will no longer call at Melksham.
It will be delayed due to the diversion and is expected to be 9 minutes late.
Additional Information
Customers travelling from unstaffed stations are requested to make use of the Customer Help Point systems available, or contact National Rail Enquiries on 03457 484 950 detailing the total number of passengers travelling, and their intended destinations.
« Reply #508 on: September 05, 2018, 08:13:22 »
05:17 Gloucester to Southampton Central due 08:09
05:17 Gloucester to Southampton Central due 08:09 will be diverted between Chippenham and Trowbridge.
It will be delayed due to the diversion and is expected to be 7 minutes late.
« Reply #509 on: September 05, 2018, 08:43:11 »
07:33 Westbury to Swindon due 08:15
07:33 Westbury to Swindon due 08:15 has been delayed at Westbury and is now 37 minutes late.
