Travel & transport from BBC stories as at 10:35 20 Apr 2025
09:47 Penzance to Plymouth
15:09 Liskeard to Looe
15:41 Looe to Liskeard
08:01 Weymouth to Cardiff Central
10:57 Paignton to Exmouth
11:25 Okehampton to Exeter Central
12:26 Exmouth to Paignton
April 20, 2025, 10:52:49 *
[102] Fortuitous connections ... and an App which fails to offer the...
[80] RNLI station celebrates 10 years of saving lives - Portishead,...
[74] FOSS and FOSW validity - some quirks
[73] St Erth station - facilities, footbridge, improvements, incide...
[56] Fifteen years of the Transwilts CRP
Pages: 1 ... 16 17 [18] 19 20 ... 45
Author Topic: 2018 cancellation and amendment log  (Read 139305 times)
« Reply #255 on: June 04, 2018, 18:03:42 »
No apologies needed, the train ran to time through that area anyway, did leave Westbury a few minutes late though
« Reply #256 on: June 05, 2018, 07:12:10 »
From JourneyCheck 05/06/2018
11:27 London Paddington to Penzance due 17:33
Additional 11:27 London Paddington to Penzance due 17:33 will be diverted between Reading and Taunton.
This is due to a problem currently under investigation.
Last Updated:05/06/2018 04:15
OK if this is an additional service and was planned to operate via Westbury but why put up the reason given over 7 hours before the service is due to commence operating rather than to admit to yet another f***-up.
« Reply #257 on: June 07, 2018, 16:13:10 »
17:36 Swindon to Westbury due 18:17
17:36 Swindon to Westbury due 18:17 will be cancelled.
This is due to a broken down train earlier today.
Additional Information
Customers at Swindon and Chippenham travelling to Trowbridge or Westbury should travel on the 18:00 Bristol Temple Meads service from Swindon (18:14 from Chippenham) and change at Bath Spa for the 18:36 service towards Portsmouth Harbour which calls at Trowbridge (18:54) and Westbury (19:01).
Customers travelling to Melksham should change at Chippenham and speak to station staff.
Customers at Melksham will be provided road transport from the station car park.
« Reply #258 on: June 07, 2018, 17:16:20 »
At least clear instructions were given on what to do or what’s been provided.
« Reply #259 on: June 07, 2018, 18:07:40 »
Totally agreed.
Having cut the timetabled service from 18 trains to 7 for engineering works, a further cut on the day to 6 - with the extra train being removed being the peak service - is a little frustrating!
« Reply #260 on: June 07, 2018, 21:46:02 »
« Reply #261 on: June 08, 2018, 06:43:09 »
4 Train Cancellations
06:06 Exeter St Davids to Exmouth due 06:38
07:04 Westbury to Cheltenham Spa due 09:05
07:33 Westbury to Swindon due 08:15
08:53 Swindon to Westbury due 09:41
"Fault with the signalling system" ....
« Reply #262 on: June 08, 2018, 07:55:32 »
Alterations to services at Swindon
Due to a fault with the signalling system at Swindon fewer trains are able to run on some lines.
Train services running through this station may be delayed by up to 20 minutes or revised. Disruption is expected until 09:30 08/06.
Owing to signalling problems in the Swindon area the number of trains passing through the station has had to be reduced either by cancellation of diversion via alternative routes. This will affect services between London Paddington and Bristol Temple Meads, London Paddington and South Wales & Swindon and Westbury via Melksham.
Those services still operating through the Swindon area will be subject to delay.
Last Updated:08/06/2018 07:47
« Reply #263 on: June 08, 2018, 07:59:54 »
Axle counters have failed around Wootton Bassett Junction.
Paddington-Cardiff shuttles also cancelled.   Alternate Bristol TM (Train Manager, or possibly Ticket Machine, depending on context)-Paddington services diverted via Newbury.
« Reply #264 on: June 09, 2018, 19:37:32 »
19:32 Westbury to Swindon due 20:22
19:32 Westbury to Swindon due 20:22 will be cancelled.
Customers at Westbury and Trowbridge travelling to Chippenham or Swindon should travel on the 19:45 Bristol Temple Meads service (19:51 from Trowbridge) and change at Bath Spa for the 20:49 service to London Paddington which calls at Chippenham (21:00) and Swindon at 21:15.
Customers at Westbury and Trowbridge travelling to Melksham should contact station staff or use the Customer Help-Point.
Customers at Melksham will be provided road transport to Chippenham from the station car park.
Last Updated:09/06/2018 16:46
20:35 Swindon to Westbury due 21:20
20:35 Swindon to Westbury due 21:20 will be cancelled.
Customers should use the next service, the 21:10 from Swindon, which calls at Chippenham (21:27), Melksham (21:36), Trowbridge (21:46), Westbury (21:53).
« Reply #265 on: June 18, 2018, 18:52:27 »
18:32 Westbury to Swindon due 19:21
18:32 Westbury to Swindon due 19:21 is being delayed at Westbury and is now expected to be 21 minutes late.
This is due to train crew being delayed.
Thank you for letting us know ... not a huge problem if the WebTIS is working.
RA
« Reply #266 on: June 19, 2018, 00:11:47 »
For the record, it was diverted via Bathampton (fail to call at Melksham) as it missed its path on the single line.
« Reply #267 on: June 19, 2018, 07:35:26 »
Most of the day like this:
Facilities on the 17:36 Swindon to Westbury due 18:17.
Will be formed of 1 coach instead of 2.
Last Updated:19/06/2018 06:42
NOT appropriate for the 15:18 or the 17:36 off Swindon
« Reply #268 on: June 19, 2018, 07:49:11 »
Not just the IETs (Intercity Express Train - replacement for HSTs (manufactured by Hitachi in Kobe, Japan)) being cut in half then!
« Reply #269 on: June 19, 2018, 08:05:02 »
With more of the 153s going off lease soon the concern is one coach may turn into no coaches.
