Travel & transport from BBC stories as at 01:55 21 Apr 2025
* Gatwick worst airport in UK for flight delays
21st Apr (1958)
21/04/25 23:30 Cardiff Central to Bristol Temple Meads
21/04/25 05:40 Penzance to Cardiff Central
21/04/25 05:47 Exeter St Davids to Cardiff Central
21/04/25 05:53 Bristol Temple Meads to Cardiff Central
21/04/25 05:58 Westbury to Cardiff Central
21/04/25 06:01 Portsmouth Harbour to Cardiff Central
21/04/25 06:28 Bristol Temple Meads to Cardiff Central
21/04/25 06:40 Penzance to Cardiff Central
21/04/25 06:44 Exeter St Davids to Cardiff Central
21/04/25 06:59 Westbury to Cardiff Central
21/04/25 07:20 Portsmouth Harbour to Cardiff Central
21/04/25 07:40 Penzance to Cardiff Central
21/04/25 08:19 Taunton to Cardiff Central
21/04/25 08:23 Portsmouth Harbour to Cardiff Central
21/04/25 09:23 Portsmouth Harbour to Cardiff Central
21/04/25 10:23 Portsmouth Harbour to Cardiff Central
21/04/25 10:50 Penzance to Cardiff Central
21/04/25 10:52 Plymouth to Cardiff Central
21/04/25 11:23 Portsmouth Harbour to Cardiff Central
21/04/25 12:23 Portsmouth Harbour to Cardiff Central
21/04/25 13:11 Taunton to Cardiff Central
21/04/25 13:23 Portsmouth Harbour to Cardiff Central
21/04/25 14:23 Portsmouth Harbour to Cardiff Central
21/04/25 14:49 Plymouth to Cardiff Central
21/04/25 15:15 Taunton to Cardiff Central
21/04/25 15:23 Portsmouth Harbour to Cardiff Central
21/04/25 16:24 Portsmouth Harbour to Cardiff Central
21/04/25 17:24 Portsmouth Harbour to Cardiff Central
21/04/25 18:00 Cardiff Central to Penzance
21/04/25 18:24 Portsmouth Harbour to Cardiff Central
21/04/25 19:00 Cardiff Central to Penzance
21/04/25 19:23 Portsmouth Harbour to Cardiff Central
21/04/25 20:00 Cardiff Central to Taunton
21/04/25 20:59 Cardiff Central to Bristol Temple Meads
21/04/25 22:00 Cardiff Central to Bristol Temple Meads
21/04/25 22:30 Cardiff Central to Bristol Temple Meads
April 21, 2025, 02:03:54 *
Author Topic: Let's frighten people ...  (Read 3004 times)
« on: November 28, 2017, 06:21:36 »
05:17 Gloucester to Southampton Central due 08:09
05:17 Gloucester to Southampton Central due 08:09 will be cancelled.
Yikes - that's a lot of key commutes!
An additional train service has been planned to operate as shown 05:17 Gloucester to Southampton Central due 08:09.
Will be formed of 1 coach instead of 2.
OK ... so it is running - just shorter.
That will be very packed indeed from Warminster to Salisbury, and from Romsey to Southampton.  It runs pretty close to the path used in "normal" hours by the Cardiff to Portsmouth service, but it's too early in the morning for that service to have woken from its slumbers!   Wink
Good case in future timetables when the Gloucester to Swindon leg becomes a through IET (Intercity Express Train - replacement for HSTs (manufactured by Hitachi in Kobe, Japan)) to London for the Cardiff to Portsmouth to take over south of Trowbridge in its regular pattern, and the Swindon - Southampton leg to drop back around 20 minutes, feeding into the Three Rivers service from Salisbury.
« Reply #1 on: November 28, 2017, 06:50:27 »
Noting that JourneyCheck tells us that there's a new train if we know where to look, OpenTrainTimes is showing 9M02 (its new calling code) between Melksham and Trowbridge as I write, and Tiger is showing it as normal.   However, I understand that text messages sent out to tell of its cancellation as 2M02 didn't notify of a new train in its place, and that it's shown as cancelled on the app;  nice way to reduce passenger numbers to fit into a 153, I suppose!
rogerw
« Reply #2 on: November 28, 2017, 08:59:14 »
Another example of the recurring problem of the inability of 153s to use platform 3 at Salisbury
phile
« Reply #3 on: November 28, 2017, 15:47:47 »
I have tweeted GWR (Great Western Railway) on more than one occasion to point out that this duplication of trains when headcode changed to Class 9 but the Tweeter people are the "messengers" and not the people who are behind decisions.   I suggested that they just didn't publish it in the public domain to avoid unnecessary confusion but the reply eventually received was that it was automatically generated.   That doesn't wash because whenever a Turbo is put on a Cardiff run and has to be amended to run as a Class 9 due to the restriction through Platform 1 at Newport, these instances haven't been shown on Journey Check.
