10:09 Gloucester to Westbury
13:50 Liskeard to Looe
14:22 Looe to Liskeard
10:55 Paignton to Exmouth
11:24 Exmouth to Paignton
13:18 Paignton to Exmouth
April 19, 2025, 11:14:42 *
Pages: 1 ... 50 51 [52] 53 54 ... 78
Author Topic: Great Western Main Line electrification - ongoing discussion  (Read 372325 times)
Western Pathfinder
« Reply #765 on: March 21, 2019, 19:00:26 »
Had HST (High Speed Train (Inter City class 43 125 units)) as Traction both ways between Bri and Tau yesterday Xcountry both ways.
« Reply #766 on: April 03, 2019, 12:15:46 »
Sunday sees the section between Wootton Bassett and just east of Chippenham (93m 31c) energised, with a view towards passenger authorisation at the end of the month.  This includes the 1 in 100 Dauntsey Bank which IETs (Intercity Express Train - replacement for HSTs (manufactured by Hitachi in Kobe, Japan)) on electric should fly up!
A shame Chippenham station itself isn’t included as that would probably save a further minute for departing IET trains to London, but the difference should still be felt.
« Reply #767 on: April 06, 2019, 11:22:00 »
Given that DfT» (Department for Transport - about) have approved a bit more electrification on the MML» (Midland Main Line. - about) there is potential for more parts of the GWML (Great Western Main Line) although I expect the Oxford "branch" to be done first.  Going past 93m 31c and through to Temple Meads is dependent on resolving the issues through Bath and the bridge at Chippenham
« Reply #768 on: April 06, 2019, 12:31:56 »
A quick google suggests that the difference in all-up mass between a full-length all-electric IEP (Intercity Express Program / Project. This will offer more capacity on routes, save money, give a consistent and safe service and meet customer requirements. Intended to replace HSTs.) train and a bi-mode is 23 tonnes. I wonder how far an electric train fitted with 23 tonnes of batteries could get?
You should be able to store well over 100 W-h/kg, so even if you could only have 15 tonnes of battery (assuming other kit would be needed to run them) you ought to be able to store at least 1.5MW-h, or - it I've understood this thread properly -  enough to keep a train (OK, a Pendolino - but close enough I hope) going at full pelt for about 15mins. Just a thought...
Celestial
« Reply #769 on: April 06, 2019, 19:42:14 »
15 mins doesn't sound like much compared to the flexibility that having the diesels brings, especially if you have to turn around and get the train back under the wires again.  That wouldn't even do Bristol Parkway to Temple Meads and back.
« Reply #770 on: April 06, 2019, 20:52:44 »
True but OTOH ('on the other hand') it wouldn't be going "full pelt" on that stretch, so presumably the batteries should last correspondingly longer (or a bit more, cos of V2 and all that).
Celestial
« Reply #771 on: April 06, 2019, 21:33:03 »
Maybe, but if they couldn't get to Swansea, Weston, Cheltenham or wherever then I'm not sure of the advantage. I think the original plan was to have some pure electrics when Bristol and Swansea were going to be electrified? That would have made sense, but to take out the diesels and replace with less flexible batteries now would seem to be spending a lot of money to reduce the capability of the trains.
« Reply #772 on: April 06, 2019, 23:11:46 »
It would get them all the way through Bath with a decent margin, and all the way through Chippenham. Most of the rest of the route could be wired without upsetting anyone...
« Reply #773 on: April 06, 2019, 23:27:54 »
Now what has happened to that idea of wiring up the cheaper and more straightforward sections to slingshot the trains with a boost of electricity ... talk was some of the stiff climbs on the Devon banks, but how about Batheaston to Thingley where we've had gawd knows how many closure weeks and money spent on lower the track through the tunnels for the electrics!    I suspect Oldfield Park to Keynsham might be possible too - not sure how easily that would plug into the local mains.
Adrian
« Reply #774 on: April 07, 2019, 08:46:55 »
I think there is most 'network benefit' in getting Bristol Temple Meads to Bristol Parkway electrified first (as it will also allow Cardiff to Bristol local services to go electric), followed by Temple Meads to Bath, then fill in the gap between Bath and Chippenham last.
As for battery electric trains, surely it is the Thames Valley branches where this is most readily applicable?  Do the trains spend long enough under the wires at the respective mainline stations to recharge for a round trip?  For the Windsor branch it is perhaps more realistic than Marlow, but presumably it doesn't actually cost much to string up the wires the short distance from Slough to Windsor?
« Reply #775 on: April 07, 2019, 10:12:59 »
As it currently stands, only the Marlow service spends any time under the wires at all - generally around 10 minutes each hour at Maidenhead, though it can be less than half of that in the peak hours.  The other stations at West Ealing, Slough and Twyford don't currently have any overhead wires on the bay platforms the trains use.  That's not to say short sections couldn't be added though of course.
Adrian
« Reply #776 on: April 07, 2019, 20:47:50 »
Seems surprising that they haven't wired everything in the vicinity of those stations (and might actually be useful) when in other places they are electrifying bits of line which will probably never see an electric train.  For instance, not just platforms 1 and 2 at Severn Tunnel Junction and a couple of hundred metres beyond, but also the freight line that bypasses those platforms.
« Reply #777 on: April 08, 2019, 10:14:24 »
There's usually some kind of reasoning behind it.  In the case of Severn Tunnel Junction then Platform 2 can be explained as it is sensible policy to wire a couple of hundred metres of diverging routes to prevent an electric train being wrong routed and subsequently stranded.  However, that logic isn't so easy to apply to Platforms 1 and the 'Down Relief' line that goes behind the station.
« Reply #778 on: April 09, 2019, 14:57:58 »
Sunday 21st April is the date for passenger authorisation according to a post on another forum.
onthecushions
« Reply #779 on: April 09, 2019, 18:46:55 »
The chief elements left out in my view are the Box and Middle Hill tunnels, just 5 miles further on; 3410 yards of mostly 1/100 with minimal ventilation for all those diesel fumes. I wonder whether that has been risk-assessed?
The terrain is quite flat and  undemanding from then on.
OTC
