No recent travel & transport from BBC stories as at 01:15 16 Apr 2025
 today - Walk from Chetnole
16th Apr (1987)
~ Tulyar arrives at Swanley New Barn Railway (link)
April 16, 2025, 01:27:38 *
[104] Spreading wings for a few days
[83] More than half of train travellers now use the railway for lei...
[78] Single scheme needed? So people know to show xtra consideratio...
[56] Isles of Scilly sea ferry and air services - merged posts
[56] North Cotswold line delays and cancellations - 2025
Pages: [1] 2 3 ... 16
Author Topic: Severn Beach Line; trains, performance, tickets and usage  (Read 74272 times)
chuffed
« on: July 03, 2017, 05:49:16 »
Much hailed announcement that these would be running from today [03 Jul 17 - RS]. However a look on RTT» (Real Time Trains - website) seems to indicate that it will be the usual 15x's.
« Last Edit: February 12, 2020, 09:53:06 by Red Squirrel » Logged
« Reply #1 on: July 03, 2017, 07:01:23 »
RTT» (Real Time Trains - website) just shows pathing, not what class will actually run, I expect it still to be turbos today.
« Reply #2 on: July 03, 2017, 08:28:58 »
The cascade has begun!
They are running on the branch today.  Although the first round trip was cancelled due to signalling problems and the second was slightly delayed by a door problem.
« Reply #3 on: July 03, 2017, 10:19:06 »
.... and at Severn Beach.
« Reply #4 on: July 03, 2017, 10:22:28 »
I see that the unit is a 166.  Is there an advertised first class on this service?  They are the only Turbos still to have a designated FC (First Class, or Fat Controller, or Football Club, depending on context) compartment - though now you have to guess which end.
« Reply #5 on: July 03, 2017, 10:36:06 »
Remaining first class accommodation has been declassified.
Longer term plan is to convert one of the former first class areas to a bike store.
« Reply #6 on: July 03, 2017, 10:54:09 »
Wow, really? That would be about the only thing that might make me lament the Turbos' departure from the Cotswolds...
« Reply #7 on: July 03, 2017, 12:56:39 »
Would the first trip have been non-Turbo had it run?   Suggestions elsewhere that it forms a service to Weston SM on return so isn't being 'Turbo-ised' in the first phase.
« Reply #8 on: July 03, 2017, 13:47:54 »
That's right. The first one is still a sprinter that runs through to weston
« Reply #9 on: July 03, 2017, 16:25:22 »
When I used to live in that neck of the woods I never liked catching that service. Often into Bristol TM (Train Manager, or possibly Ticket Machine, depending on context) on P10 or P12 right down to the country end. About as far as you can get from the station exit.
The Severn Beach - Weston-super-Mare weekday early AM used to be a single head code through service. A couple of years back it was split into two head codes for operational reasons despite the unit nearly always working through. Downside of that change was it no longer showed on booking systems as a through service, and with the wait at Bristol TM being 7 minutes it's no longer a valid connection. Unless you're in the know or the Guard/TE tells you.
PhilWakely
« Reply #10 on: July 03, 2017, 17:39:24 »
I read on journeycheck that the Severn Beach line was suffering delays due to 'congestion' at about lunchtime. I cannot imagine congestion on the Severn Beach line Huh?
« Reply #11 on: July 03, 2017, 17:58:26 »
The congestion was mainly at Clifton Down where the trains pass.  Successive trains were being held there while the previously delayed service made it back from Avonmouth.  Several services were turned short at Clifton Down in an attempt to get things back on time.
« Reply #12 on: July 03, 2017, 18:15:24 »
Some thought may need to be given to the signage on Platform 1 at Bristol Temple Meads.
A three car turbo has one set of doors past the "Passengers must not pass this point" sign.  Huh
« Reply #13 on: July 03, 2017, 18:16:08 »
It was the first I had heard of it.  I was told by a member of GWR (Great Western Railway) middle-management and am trying to find out more.
« Reply #14 on: July 03, 2017, 18:24:40 »
Presumably this is only for units transferring to Bristol, not the entire fleet?
