No recent travel & transport from BBC stories as at 05:55 20 Apr 2025
15:09 Liskeard to Looe
15:41 Looe to Liskeard
16:35 Par to Newquay
17:55 Newquay to Par
10:57 Paignton to Exmouth
12:26 Exmouth to Paignton
April 20, 2025, 06:01:20 *
[96] RNLI station celebrates 10 years of saving lives - Portishead,...
[89] FOSS and FOSW validity - some quirks
[88] St Erth station - facilities, footbridge, improvements, incide...
[67] Fifteen years of the Transwilts CRP
[59] Wiltshire Day Rover - new multi-operator bus ticket
Author Topic: Train delays  (Read 7772 times)
simonw
« on: June 15, 2017, 22:27:19 »
Over the past several months, every evening the Crosscountry 16:30 train from BTM (Bristol Temple Meads (strictly, it should be BRI) but BTM is a commonly used alternative)) to Edinburgh has 'parked' outside BPW» (Bristol Parkway - next trains) for several minutes. Why? Is the timetable too tight, or are GWR (Great Western Railway) useless at running trains on time and freeing up platform 3?
Over the years, I have experienced many minutes on trains stuck outside stations waiting for platforms to be cleared, but only Reading station up to 2011/12 has equalled these delays in waiting for a platform.
Is there a known issue?
« Reply #1 on: June 15, 2017, 22:44:21 »
Today the 15:56 Cardiff to Paddington was 12 minutes late, and that held it up.   The Cardiff train was 6 minutes late yesterday, 4 minutes late on Tuesday (and the Edinburgh just 2 late), and Monday's delays were identical to Tuesday's.
simonw
« Reply #2 on: June 16, 2017, 09:26:24 »
Thanks for the update.
So the next question,
  • is the timetable too tight
  • are GWR (Great Western Railway) not capable of running to a timetable
  • does BPW» (Bristol Parkway - next trains) require more capactity
rower40
Turning signalling into a video game since 1988.
« Reply #3 on: June 16, 2017, 10:10:37 »
(Meekly holds hand up slowly.  Gets ready to run for cover...)
The timetable for Bristol Parkway shows:
1L74 (1524 Swansea to Paddington) arr 1630H, dep 1633 platform 3.
2D20 (1615 Bristol TM (Train Manager, or possibly Ticket Machine, depending on context) to Bristol Parkway) arr 1634 platform 4
1S55 (1425 Plymouth to Edinburgh) arr 1638, dep 1639H.
2D20 leaves Filton Abbey Wood at 1626H, and has a 3.5 minute pathing allowance approaching Bristol Parkway, so that it is meant to follow 1L74.
But the ARS (Automatic Route Setting) programming gets it wrong - it "thinks" that it can get 2D20 over the junction ahead of 1L74. If the signaller doesn't catch it in time, then 2D20 goes first, causing delay to 1L74, meaning it can't vacate its platform in time to prevent delay to 1S55.
But the good news: I'm doing a fix to the ARS logic (due to be installed in November) to sort this out.
« Reply #4 on: June 16, 2017, 11:03:51 »
Thanks Rower,
Please also could you have a look at the ARS (Automatic Route Setting) logic that holds traffic on the Down Relief at Didcot East Junction.  I have spent too many minutes of my life at that locality - often being passed by an Up Local (showing the route into Didcot is clear) yet continuing to wait for a further conflicting crossing on the junction ahead.  Like the love of God - it passeth all understanding.
« Reply #5 on: June 16, 2017, 11:21:53 »
Another place the ARS (Automatic Route Setting) seems slow on the uptake is coming into Padd on Line 6 waiting by Royal Oak LUL (London Underground Ltd) for a platform. The Down train seems to have gone past  a long time before we move.
simonw
« Reply #6 on: June 16, 2017, 11:33:26 »
Thanks rower for the update.
Obviously, as rail demand increases, some bright spark will have to consider someways to increase the capacity of places like BPW» (Bristol Parkway - next trains), possibly with A|B platforms.
chrisr_75
« Reply #7 on: June 16, 2017, 11:47:00 »
I believe the intent is to add a new platform at BPW» (Bristol Parkway - next trains)
« Reply #8 on: June 16, 2017, 13:53:35 »
Indeed, and there are closures in the 'reasonably near future' for at least some of the required work:
https://www.gwr.com/travel-updates/planned-engineering/autumn-upgrade-2017
« Reply #9 on: June 16, 2017, 14:07:08 »
The new platform won't help matters as it will be in the down direction.  The additional platform in the up direction was added a few years ago, but the movements described by rower40 are conflicting, so the two moves can't take place in parallel despite the extra platform.
« Reply #10 on: June 16, 2017, 14:09:39 »
If the new platform 1 is used for the terminators from the south, instead of platform 4, that would remove the conflicts. Whether it will be used that way is another matter.
chuffed
« Reply #11 on: June 19, 2017, 19:11:19 »
According to that esteemed organ of non fake news, otherwise known as the Bristol Evening Post, printed in Didcot.....Platform 11 at Temple Meads is closed because the heat has caused the expanding bitumen in the edging slabs to push them out of alignment, with the possibilty that trains could be scraped.
I wonder if they missed an extra letter p in that last word ?!
« Reply #12 on: June 19, 2017, 20:08:55 »
That's a very good point. Let's hope they do.
« Reply #13 on: June 19, 2017, 20:38:36 »
According to the signalling scheme plan I have seen there will be no connection from the Filton direction to allow northbound trains to directly access the new platform no.1
Health Warning: The plan I have seen is dated 2011 (yes, the new platform has been planned for that long!)
« Last Edit: August 20, 2017, 22:52:05 by Chris from Nailsea » Logged
« Reply #14 on: June 19, 2017, 22:20:10 »
Thanks for the clarification. (Though on a point of detail I didn't make the comments quoted as mine.)
