« on: April 21, 2017, 20:40:24 » |
« Reply #1 on: April 21, 2017, 20:57:14 » |
18/18, though if some of the options had been less obvious then I may have struggled a little more.
« Last Edit: April 21, 2017, 21:25:04 by Adelante_CCT »
« Reply #2 on: April 21, 2017, 21:03:24 » |
I worked out the answer to each before scrolling down to the options. Lisa sitting beside me felt that I should have done better things with my life than learned the tube map! Still need to refer back to a real map to sort out my Kew Gardens from my Gunnersbury ...
« Reply #3 on: April 21, 2017, 21:18:18 » |
Hadn't thought of that one, I just happened to select Gunnersbury. Having checked I'm guessing the difference is the stepfree symbol.
« Reply #4 on: April 21, 2017, 21:26:11 » |
That could be it. I selected Kew Gardens because the I thought that the two lines should have been shown diverging just north of the station if it was Gunnersbury.
« Reply #5 on: April 21, 2017, 21:57:13 » |
In reality yes, Gunnersbury isn't far from Chiswick park but the lines on the map don't diverge until much further north.
« Reply #6 on: April 21, 2017, 22:06:54 » |
About 10 minute walk as I remember, but about half the times I walk out of Chiswick Park to get to Gunnerbury, I have heard a Richmond Train pass by on the other line!
Zoe
« Reply #7 on: April 21, 2017, 22:09:40 » |
I remember a challenge on the ITV gameshow "You Bet!" back in the early 1990s where a kid did this with the lines not even in colour. He not only had to identify the stations but also the lines shown.
« Last Edit: April 21, 2017, 22:17:27 by ZoĆ« »
« Reply #8 on: April 21, 2017, 22:18:36 » |
12/18. I struggled with the DLR▸ and Overground and also was confused by the Overground being a solid orange on a normal map and two orange lines here.
« Reply #9 on: April 21, 2017, 22:22:20 » |
I think a lot of our partners feel that about the time we spend on here!
« Reply #10 on: April 21, 2017, 23:48:05 » |
I think a lot of our partners feel that about the time we spend on here! Yep - mine too!
« Reply #11 on: April 22, 2017, 05:58:35 » |
The "definitive" map for this quiz is - I think - http://content.tfl.gov.uk/standard-tube-map.pdfYep, the one I got wrong was due to my consideration of the physical layout which the diagram doesn't reflect overtaking consideration of a wheelchair symbol. Oops - but then it's only a quiz!
« Reply #12 on: April 22, 2017, 07:12:02 » |
Smug  ... and sad!
« Reply #13 on: April 22, 2017, 08:25:47 » |
The "definitive" map for this quiz is - I think - http://content.tfl.gov.uk/standard-tube-map.pdfYep, the one I got wrong was due to my consideration of the physical layout which the diagram doesn't reflect overtaking consideration of a wheelchair symbol. Oops - but then it's only a quiz! Oh, I hadn't realised that some of the line colours on the tube map were different to the combined rail and tube map. http://content.tfl.gov.uk/london-rail-and-tube-services-map.pdfI guess it is to better differentiate all the different rail services. As an all zone travelcard holder this is the map I refer to most because if I am travelling to outside London I can see where zone 6 ends on each National Rail line and buy a ticket starting from the last station in the zone.
« Reply #14 on: April 22, 2017, 15:07:09 » |
16/18 I blame finger trouble for one I click before moving the highlight and the other was Gunnesbury I thought that the divergence was nearer the station. Should have paid more attention to the Wheelchair symbol.
