April 20, 2025, 22:59:31 *
Author Topic: Definition of services  (Read 8030 times)
Nigel53
Jr. Member
« on: November 23, 2016, 15:28:55 »
I notice that Great Western offer compensation on a different basis for "High Speed services" and "London-Thames Valley services" (they also quote performance figures separately) but nowhere can I see a definition of these. Specifically, which does a journey between Paddington and Reading count as, since (with anything but an advance ticket) you can use any train that happens to stop at Reading?
« Reply #1 on: November 23, 2016, 15:43:00 »
Old LTV (London [and] Thames Valley) Thames Trains services & HST (High Speed Train (Inter City class 43 125 units)) services. Then a third is old Wessex route services.
I don't know which LTV or HST groups Reading seasons fall in. For individual journeys, this is why you have to add the service you were traveling on
Nigel53
Jr. Member
« Reply #2 on: November 24, 2016, 15:49:01 »
That gets tricky if you intended to travel on one service, but took another because the first was delayed or cancelled - or if they happened to run a 125 on a service to Oxford that probably wouldn't have used such a train but for service disruptions. Surely compensation should be by route travelled and nothing more? In the case of a single journey, it's impossible to prove which train you travelled on anyway, since the ticket barriers at Reading swallow the ticket if that's your final destination.
« Reply #3 on: November 24, 2016, 15:58:19 »
The compensation will be the same regardless, based on the price paid, thinking about this. It doesn't actually matter.
Nigel53
Jr. Member
« Reply #4 on: December 09, 2016, 12:28:23 »
But my point was that, going by what their policy said, that isn't the case.
For example: 45 minutes delay on HST (High Speed Train (Inter City class 43 125 units)) - no compensation, but 45 minutes delay on LTV (London [and] Thames Valley) - 50% compensation.
old original
« Reply #5 on: December 09, 2016, 17:14:51 »
AIUI ('as I understand it') compensation on season tickets falls into one of the six areas, High-speed services, London Thames Valley, Bristol suburban services, Devon services, Plymouth and Cornwall services and South Wales - South Coast services.
Each and every possible journey will fall into one of these, but which one? For that, each station ticket office should have a list. The one I've seen runs to a couple of dozen pages of small print. Logic?? Well what do you expect.....
As an example all journeys within Cornwall fall into the Plymouth and Cornwall group BUT for a journey from a station in Cornwall to/from Plymouth, that falls into the High-speed services group
Discuss
Nigel53
Jr. Member
« Reply #6 on: December 09, 2016, 21:38:49 »
Should the information - confusing though it may be - not also be available online?
« Reply #7 on: December 12, 2016, 11:14:46 »
You haven't mentioned using a season, so I won't complicate matters by answering for those as they fall under different rules.
Indeed - so if you want to benefit from better compensation, use the non-HST services from Reading. But you probably won't, because they're slower in general, and less comfortable.
Nigel53
Jr. Member
« Reply #8 on: December 12, 2016, 15:18:12 »
Thanks - as you supposed, I don't use a season ticket. It's still a bit confusing, though, as there seem to be four different types of service from Paddington to Reading:
1. The 125s that carry on to the west or southwest, taking about 25 minutes - plainly they count as HST (High Speed Train (Inter City class 43 125 units)), from what you said
2. The services to Oxford that also stop at Slough (e.g. the 2048), taking about 33 minutes
3. Services terminating at Reading with one or two stops like Maidenhead and Twyford (e.g. the 2018), taking about 42 minutes
4. The services that take about an hour and stop everywhere - plainly these are LTV (London [and] Thames Valley) ones, and I'd never use them if the others were running
The question is, what do 2 and 3 count as?
« Reply #9 on: December 12, 2016, 15:19:38 »
LTV (London [and] Thames Valley), unless they head along the Cotswold Line to Hereford, then I think they come under HST (High Speed Train (Inter City class 43 125 units))
