No recent travel & transport from BBC stories as at 06:55 08 Jan 2025
8th Jan (1991)
06:30 Looe to Liskeard
07:20 Liskeard to Looe
07:54 Looe to Liskeard
08:30 Liskeard to Looe
09:05 Looe to Liskeard
09:36 Liskeard to Looe
10:08 Looe to Liskeard
10:36 Liskeard to Looe
11:06 Looe to Liskeard
06:00 London Paddington to Penzance
08:35 Plymouth to London Paddington
January 08, 2025, 07:04:04 *
[192] Coastal walks - station to station
[169] 'Railway 200' events and commemorations 2025
[74] Fatal Oxfordshire train crash remembered 150 years on
[67] Warnings of snow, wind and rain across the UK for New Year
[45] Oxford station - facilities, improvements, parking, incidents ...
[34] Senior Railcard - ongoing issues, merged posts
Author Topic: Reading to Guildford - signal failure / closed all day?  (Read 12607 times)
« on: September 14, 2016, 07:55:57 »
Ouch............
Cancellations to services between Reading and Guildford
Due to a fault with the signalling system between Reading and Guildford all lines are closed.
Train services running to and from these stations may be cancelled or revised. All stations between Reading and Guildford will not be served. Disruption is expected until the end of the day.
« Reply #1 on: September 14, 2016, 09:00:44 »
GWR (Great Western Railway) website says..
No trains between Reading and Guildford until the end of service
Uh oh, I've already bought my ticket from Bookham to Gatwick via Dorking for later today. I may have to travel via Clapham Junction instead Sad  I don't particularly want to get on a crowded Southern service in the evening peak with a suitcase.
At the moment the next 3 direct trains are cancelled, I hope there is some sort of a service Guildford to Gatwick later.
That must be a severe failure if it can't be fixed today.
« Reply #2 on: September 14, 2016, 09:28:04 »
The words are a bit misleading - the gap is between Wokingham and Ash, with the overlapping SWT (South West Trains) services still running (though not bang on time just now). One cancellation code on RTT» (Real Time Trains - website) is "This service was cancelled between Guildford and Reading due to a power supply failure (II)" - which may explain why it's a bit more than the usual waggle-the-wires-or-hit-it-with-a-spanner kind of fault.
There is something like a half service from Guildford to Redhill, but not running to Gatwick. Presumably that means they only have the (two?) trains that stable at Gatwick/Redhill, as none got out from Reading this morning. How long will their fuel last?
« Reply #3 on: September 14, 2016, 09:41:00 »
In cases like this, couldn't they get fuel from Eastleigh? SWT (South West Trains) must fuel somewhere within reach?
« Reply #4 on: September 14, 2016, 11:15:19 »
Will have to keep an eye on live train running for the GWR service but looks like I might be travelling via Horsham. Don't particularly want to rely on Southern at the moment but I guess I may have no choice
« Reply #5 on: September 14, 2016, 11:46:50 »
They could run to Selhurst for fuel, or back to Reading via Woking and Basingstoke, having been route cleared for both a couple of years ago for one of the big Reading blockades.  But would there be any driver route knowledge?
SWT's nearest fuelling facility is Fratton.  Eastleigh Works or TRSMD (Traction & Rolling Stock Maintenance depot) can fuel units but they have nothing to do with SWT in normal circumstances.
Fourbee
« Reply #6 on: September 14, 2016, 12:15:54 »
Line expected to reopen shortly according to journeycheck.
« Reply #7 on: September 14, 2016, 12:38:05 »
Reports elsewhere that they are using temporary block working (TBW (Temporary Block Working)) - is that effectively hand signalling?
Said that the service will be operated in two sections with a change at Guildford to prevent delays on the damaged section affecting the whole route.   In other words maintaining normal timings at the Redhill end.
« Reply #8 on: September 14, 2016, 13:00:40 »
It's used when two or more consecutive signals need to be passed at red and eliminates the need to stop the train at every signal as the driver can proceed (50 mph) max until whenever the last affected signal is.
A handsignaller is positioned at each end and a certificate is issued to the driver giving details of the signals to be passed at danger and other issues.
The longer the block, the less frequently the trains can run as only one can be in section at a time, though if it's a really long section of failed signals then you could split it up into two or more TBW sections, though that of course demands more staff.
chrisr_75
« Reply #9 on: September 14, 2016, 14:05:30 »
If I remember correctly, the same procedure as was employed during the groundwater flooding a couple of winters back between PAD» (Paddington (London) - next trains) & RDG(resolve)?
« Reply #10 on: September 14, 2016, 14:17:04 »
Yes, it was for a few days, before the extended block section was introduced (with out of use bagged over intermediate signals) which was controlled 'normally' by the signallers.
« Reply #11 on: September 14, 2016, 15:53:49 »
Just arrived at Reading on a service from Bristol and there was no announcement advising pax for Gatwick to stay on board, although National Rail is advising that this routing is available (and presumably recommended).
« Reply #12 on: September 14, 2016, 18:40:19 »
Elsewhere I've read a mile of signalling cabling needed renewing due to damage. The damage wasn't specified, but I did wander if cable theft was involved.
« Reply #13 on: September 14, 2016, 18:43:44 »
I understand the cable was still in place but had "deteriorated".
